I have upgraded my openhab to 4.1.0 and I noticed that the item that tracks of the time remaining for my dryer was not displaying correctly in my habpanel dashboard. The value it shows is always in seconds, no matter what I do.
My item:
Number:Time Dryer_RemainingProgramTimeState "[%.1f %unit%]" {channel="homeconnect:dryer:api_bridge_at_home:dryer1:remaining_program_time_state"}
The input is values in seconds. If I put a dummy in habpanel linking to this item it will for example say: “90 s”. However if I change the item to “[%.1f min]” the item in habpanel will show “90 min”. If I change the format in habpanel itself the same thing happens
Does anyone know / see what I’m missing?
Edit:
I found out that if I change the item with {unit=“min”, channel…} it will than do the correct transformation and display minutes instead of seconds
