Hi All,
I hope someone can help me, I installed openHAB using docker on my RPI 4B running Ubuntu 22.04, after installing the openHAB cloud connector via UI, there was no openhab folder created in my /var/lib/ i also checked the /opt/userdata but both directories are empty, the log files don’t really provide any hints as the only entry on are as below :
openhab console : after i try to uninstall and install the add-on from the UI
14:54:08.121 [INFO ] [.io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
14:54:42.005 [WARN ] [.io.openhabcloud.internal.CloudClient] - Error connecting to the openHAB Cloud instance: not authorized. Reconnecting after 2829 ms.
14:54:45.397 [WARN ] [.io.openhabcloud.internal.CloudClient] - Error connecting to the openHAB Cloud instance: try again in 56 seconds. Reconnecting after 4930 ms.
14:54:50.859 [WARN ] [.io.openhabcloud.internal.CloudClient] - Error connecting to the openHAB Cloud instance: try again in 51 seconds. Reconnecting after 5533 ms.
14:54:56.908 [WARN ] [.io.openhabcloud.internal.CloudClient] - Error connecting to the openHAB Cloud instance: try again in 45 seconds. Reconnecting after 15345 ms.
openhab> feature:list | grep cloud
openhab-binding-icloud │ 4.1.1 │ x │ Started │ openhab-addons-4.1.1 │ iCloud Binding
openhab-binding-melcloud │ 4.1.1 │ │ Uninstalled │ openhab-addons-4.1.1 │ MELCloud Binding
openhab-binding-mielecloud │ 4.1.1 │ │ Uninstalled │ openhab-addons-4.1.1 │ Miele Cloud Binding
openhab-misc-openhabcloud │ 4.1.1 │ x │ Started │ openhab-addons-4.1.1 │ openHAB Cloud Connector
the logs from ubuntu are as below :
Jan 25 18:43:03 raspberrypi dockerd[1102]: time=“2024-01-25T18:43:03.541856210Z” level=warning msg=“ShouldRestart failed, container will not be restarted” container=989f40f2e21805e44aa57f2b229a2c9d296edaac556da0ca08dfc46f9b4be3d0 daemonShuttingDown=false error=“restart canceled” execDuration=8m23.968861921s exitStatus=“{137 2024-01-25 18:43:03.468973603 +0000 UTC}” hasBeenManuallyStopped=true restartCount=0
Jan 25 18:43:03 raspberrypi containerd[808]: time=“2024-01-25T18:43:03.820422517Z” level=info msg=“loading plugin "io.containerd.event.v1.publisher"…” runtime=io.containerd.runc.v2 type=io.containerd.event.v1
Jan 25 18:43:03 raspberrypi containerd[808]: time=“2024-01-25T18:43:03.820704069Z” level=info msg=“loading plugin "io.containerd.internal.v1.shutdown"…” runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Jan 25 18:43:03 raspberrypi containerd[808]: time=“2024-01-25T18:43:03.820753753Z” level=info msg=“loading plugin "io.containerd.ttrpc.v1.task"…” runtime=io.containerd.runc.v2 type=io.containerd.ttrpc.v1
Jan 25 18:43:03 raspberrypi containerd[808]: time=“2024-01-25T18:43:03.821565150Z” level=info msg=“starting signal loop” namespace=moby path=/run/containerd/io.containerd.runtime.v2.task/moby/989f40f2e21805e44aa57f2b229a2c9d296edaac556da0ca08dfc46f9b4be3d0 pid=14255 runtime=io.containerd.runc.v2
Jan 25 18:43:03 raspberrypi systemd[1]: run-docker-runtime\x2drunc-moby-989f40f2e21805e44aa57f2b229a2c9d296edaac556da0ca08dfc46f9b4be3d0-runc.XXkoGY.mount: Deactivated successfully.
Jan 25 18:43:03 raspberrypi systemd[1]: Started libcontainer container 989f40f2e21805e44aa57f2b229a2c9d296edaac556da0ca08dfc46f9b4be3d0.
Jan 25 18:45:01 raspberrypi CRON[15031]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
is there anywhere else i could look to get the secret and UUID so i can sign up for myopenhab? i installed my openhab via docker and followed the instructions from this link : Docker | openHAB
other than that, openhab works seamlessly, i just want to use the cloud connector to explore more functions for my Echo Dot
