openHAB 4.1 Release discussion
I tried upgrading from latest 4.0.1 to 4.1
  • Raspberry with openHABian
  • apt-get update + upgrade
  • OH 4.1 was installed by this
  • OH start failed
  • openhab-cli clean-cache
  • removed additional addons from addons folder
    the log now shows
2024-01-01 15:10:10.326 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
java.lang.IllegalStateException: Resource has no uri
	at org.apache.karaf.features.internal.service.Deployer.getBundleInputStream(Deployer.java:1631) ~[?:?]
	at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:904) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1069) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:1004) ~[?:?]
nothing else
reboot, same problem
EDIT: Resetting file permissions and reinstalling Java 17 with openhabian-config doesn’t fix the problem
EDIT2: doing openhab-cli clean-cache 2 more times solved it :cowboy_hat_face:
Good job! Congra!
It seems everything works fine on Windows.
But when we can expect new version of OSHI in the next release?
What’s OSHI?
Has been fixed and will be included in the next 4.1 patch.
GitHub - oshi/oshi: Native Operating System and Hardware Information
The systeminfo binding apparently relies on OSHI 6.2.2.
I know that. I see what is in the build 4.1. I’m asking about newst version eg. 6.4.10…
Don’t hesitate to contribute this change, checking first that moving to 6.4.10 does not break anything in the binding.
And why do you ask ?
Is there something missing from the ā€žolderā€œ release?
Yes, on the Windows (11) platform there is still problem with thing systeminfo and sensors. CPU temperature and fan speed information.
I wrote about that in this topic:
[SOLVED] After restart, Systeminfo binding does not provide CPU-temp any longer - Add-ons / Bindings - openHAB Community
As I read on OSHI gitHub, there was a problem with path on windows platform and members of OSHI wrote that the problem should be now resolved. That why I’m asking about upgrade OSHI component in the next OH version.
Iā€˜ll have look
This sounds reasonable.
https://github.com/openhab/openhab-addons/pull/16197
You can find a test-bundle here. It probably also works on 4.1, uninstall the binding and drop the jar in your addons folder.
Unfortunately the same CPU temp - UNDEF :frowning: In the log:
[til.platform.windows.WmiQueryHandler] - COM exception querying MSAcpi_ThermalZoneTemperature, which might not be on your system. Will not attempt to query it again. Error was -2147217396: Failed to enumerate results.
Do you have a link to the issue in OSHI?
I’m very sorry, it was some time ago and I can not find it in the browser history, but that does not change the fact that this binding does not work for the entire section ā€œsensorsā€, everything else in this binding works. Strangely enough hardwareinfo or other open source soft shows and temperature and fan speed on windows.
oh my gosh, what is doing on. I got some notyfication in bindings. I see 9 notyfications on MQTT and after click I see some elements to add from systeminfo, but from…HomeAssistant…
Platform Windows 11 of course + OH 4.1
OH_4-1_Windows
I guess you enabled the homeassistant discovery protocol on your NAS. That’s all. Items that follow the homeassistant convention can be auto-discovered and configured.
Thank you all for the OH 4.1 release. The upgrade was easy. I moved to new hardware and therefor had problems with the blink binding. I used the blink add-on org.openhab.binding.blink-4.1.0-SNAPSHOT.jar on the old system. On the new system I tried to add the blink binding but it installed ā€œBlink 3.3ā€ which does not work. I removed ā€œBlink 3.3ā€ and installed org.openhab.binding.blink-4.1.0-SNAPSHOT.jar on the new system. This version works even with some ā€œservlet nameā€ errors. Is it possible to integrate org.openhab.binding.blink-4.1.0-SNAPSHOT.jar into OH 4.1 instead ā€œBlink 3.3ā€?
This binding seems to not be part of the official openHAB distribution.
