There are no changes to the documentation that indicate that this is no longer a supported scenario, and indeed the sitemap colouring still works as expected, just I’m getting log growth.
Hi!
Since OH4.1 I have some strange calculations in DSL rules with temperatures.
It seems temperature calculations do not respect anymore what is indicated here
In particular, calculating an average temperature with (5|°C + 10|°C) / 2 does not work anymore (I don’t obtain 7.5°C).
what is the workaround to be able to multiply or divide Celsius temperature with 0°C as the reference point (and not 0K as it seems to be now) ?
This ‘Release discussion’ thread is to exclusively discuss (potential) issues that were introduced in OH 4.1 since the last release OH 4.0.
It’s also about software issues in openHAB itself, it is not about migration in general and not about (self-made) rules or other issues that are individual to your setup.
Please double check against these questions before posting here and mind general posting rules, too.
If in doubt, open your own thread to ask and discuss to find out if it’s really an issue caused by the latest software or if it could be an individual issue, in case of the latter please stay with your own thread.
I’m sorry to remind of this. However, if we all don’t come up with a fair amount of discipline this thread is quickly becoming an unreadable mess.
and so the question I asked is also related to this specific release. The change that was done is likely to break rules of many users and the change has not been documented.
I perceived your answer as rude. I’m just a standard user of openHAB, I’m not familiar with the exact policy of the community forum.
2023-12-29 17:19:17.596 [INFO ] [internal.service.FeaturesServiceImpl] - Adding features: system/[4.4.4,4.4.4],feature/[4.4.4,4.4.4],deployer/[4.4.4,4.4.4],diagnostic/[4.4.4,4.4.4],bundle/[4.4.4,4.4.4],ssh/[4.4.4,4.4.4],log/[4.4.4,4.4.4],eventadmin/[4.4.4,4.4.4],openhab-runtime-base/[4.1.0,4.1.0],instance/[4.4.4,4.4.4],config/[4.4.4,4.4.4],framework/[4.4.4,4.4.4],shell/[4.4.4,4.4.4],kar/[4.4.4,4.4.4],openhab-runtime-ui/[4.1.0,4.1.0],service/[4.4.4,4.4.4],jaas/[4.4.4,4.4.4],package/[4.4.4,4.4.4]
2023-12-29 17:19:20.271 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
org.apache.karaf.features.internal.util.MultiException: Error:
Error downloading mvn:org.apache.karaf.wrapper/org.apache.karaf.wrapper.core/4.4.4
at org.apache.karaf.features.internal.download.impl.MavenDownloadManager$MavenDownloader.<init>(MavenDownloadManager.java:91) ~[?:?]
at org.apache.karaf.features.internal.download.impl.MavenDownloadManager.createDownloader(MavenDownloadManager.java:72) ~[?:?]
at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:474) ~[?:?]
at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:469) ~[?:?]
at org.apache.karaf.features.internal.region.SubsystemResolver.resolve(SubsystemResolver.java:223) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:399) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.handlePrerequisites(Deployer.java:1121) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:394) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1069) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:1004) ~[?:?]
at java.lang.Thread.run(Thread.java:833) [?:?]
Suppressed: java.io.IOException: Error downloading mvn:org.apache.karaf.wrapper/org.apache.karaf.wrapper.core/4.4.4
at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:77) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
Caused by: java.io.IOException: Error resolving artifact org.apache.karaf.wrapper:org.apache.karaf.wrapper.core:jar:4.4.4: [Could not find artifact org.apache.karaf.wrapper:org.apache.karaf.wrapper.core:jar:4.4.4 in openhab (https://openhab.jfrog.io/openhab/libs-release/)]
No, not really. I had to reinstall my server which was running in 4.0x and I installed 4.1
Unfortunately I had installed first the last 3.x version and then upgraded to 4.1. Afterwards I restored the Influxdb (which should have been with data from 4.0).
But thanks for the link, I had overlooked it. I will restore these values again with type conversation.
You are, correct, this is not working anymore that way. Temperature calculations had loads of problems and a compromise had to be made to solve most. If you add unit values you need to make sure the second argument is a relative value, and for temperatures, that can only be in Kelvin.
I have not yet gone to 4.1, still on 4.1M5 and have this working DSL code to raise or lower a setpoint by 1 degree F. (Had @rossko57 help in the setup) Do I need to change the degree to .55555 K? My device only accepts even degrees, so precision could be an issue also? Suggestion for how this is supposed to work now?
rule "Furnace_Optimization"
Item UpstairsThermostat21_ThermostatOperatingState changed
// If upstairs is heating and main is in heating mode raise setpoint 1 °F, once upstairs is off reduce 1 °F
var upstate = UpstairsThermostat21_ThermostatOperatingState.state as Number
var mainmode = MainThermostat14_ThermostatMode.state as Number
var mainsetpointnow = (MainThermostat14_SetpointHeating.state as QuantityType<Temperature>).toUnit("°F")
if( upstate == 1 && mainmode == 1) {
var mainsetpointnew = mainsetpointnow + 1|°F
Thread::sleep(1500)
MainThermostat14_SetpointHeating.sendCommand(mainsetpointnew as Number)
else{
if( upstate == 0 && mainmode == 1) {
var mainsetpointnew = mainsetpointnow - 1|°F
Thread::sleep(1500)
MainThermostat14_SetpointHeating.sendCommand(mainsetpointnew as Number )
That should still work. I was wrong in the previous comment. It is the division that does not work anymore as expected. If you divide, it is assuming absolute values now.
running into an issue with the upgrade from 4.0.x to 4.1. Somehow the entire website no longer works at all. I also see these warnings when booting the system:
2023-12-31 22:12:08.953 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/events's Observer
2023-12-31 22:12:08.955 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/events's Observer
2023-12-31 22:12:08.974 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/addons/binding-broadlinkthermostat's Observer
2023-12-31 22:12:08.975 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/addons/binding-broadlinkthermostat's Observer
2023-12-31 22:12:09.807 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/events's Observer
2023-12-31 22:12:09.817 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/events's Observer
2023-12-31 22:12:09.848 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/events's Observer
2023-12-31 22:12:09.850 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/events's Observer
2023-12-31 22:12:09.853 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/events's Observer
2023-12-31 22:12:09.859 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/addons/binding-broadlinkthermostat's Observer
2023-12-31 22:12:09.866 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/addons/binding-broadlinkthermostat's Observer
2023-12-31 22:12:09.866 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/events's Observer
2023-12-31 22:12:09.873 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/events's Observer
2023-12-31 22:12:09.879 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/addons/binding-broadlinkthermostat's Observer
2023-12-31 22:12:09.886 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/addons/binding-broadlinkthermostat's Observer
2023-12-31 22:12:11.861 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/events's Observer
2023-12-31 22:12:11.865 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/events's Observer
2023-12-31 22:12:11.871 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/events's Observer
2023-12-31 22:12:11.876 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/addons/binding-broadlinkthermostat's Observer
2023-12-31 22:12:11.879 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/events's Observer
2023-12-31 22:12:11.881 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/addons/binding-broadlinkthermostat's Observer
2023-12-31 22:12:11.897 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/addons/binding-broadlinkthermostat's Observer
2023-12-31 22:12:14.143 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/addons/binding-broadlinkthermostat's Observer
2023-12-31 22:12:14.147 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/addons/binding-broadlinkthermostat's Observer
2023-12-31 22:12:14.155 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/addons/binding-broadlinkthermostat's Observer
2023-12-31 22:12:14.157 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/addons/binding-broadlinkthermostat's Observer
2023-12-31 22:12:15.910 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/events's Observer
2023-12-31 22:12:15.911 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/events's Observer
2023-12-31 22:12:15.915 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/events's Observer
2023-12-31 22:12:15.918 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/events's Observer
2023-12-31 22:12:15.924 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/events's Observer
2023-12-31 22:12:15.934 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/addons/binding-broadlinkthermostat's Observer
2023-12-31 22:12:15.935 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/addons/binding-broadlinkthermostat's Observer
2023-12-31 22:12:15.936 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/addons/binding-broadlinkthermostat's Observer
2023-12-31 22:12:15.939 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://homecontrol:8080/rest/addons/binding-broadlinkthermostat's Observer
and there is also this line which I don’t understand:
2023-12-31 22:13:05.578 [WARN ] [ty.util.ssl.SslContextFactory.config] - Trusting all certificates configured for Client@e3a3d[provider=null,keyStore=null,trustStore=null]
2023-12-31 22:13:05.580 [WARN ] [ty.util.ssl.SslContextFactory.config] - No Client EndPointIdentificationAlgorithm configured for Client@e3a3d[provider=null,keyStore=null,trustStore=null]
Using docker on RPI4-64bit. Update went smoothly, however, Basic UI is broken: It now shows 3 columns instead of the usual two. Is that is a feature ? Tested it in a private Firefox window.
Also one icon is missing: Url: /icon/bathroom?iconset=classic&format=svg&anyFormat=true&state=UNDEF
Right, my bad. I fix the icon, but I wonder why I never noticed that before.
About the columns: I looked at the docs, but I could not find how to limit the columns to two. Any idea how I would do this with a textual configuration ?
