Since I switched from OH 4.0.4 to OH 4.2.1 the state of my Shelly thing shelly:shellyplug-s:xxxxxx of a currently unplugged Shelly plug bounces between ONLINE an OFFLINE.
I am checking the state in a rule to see if an electrical heating is plugged in or not.
Here is relevant entry from the log - the last two entries are coming from my rule:
2024-09-12 12:43:50.451 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellyplug-s-xxxxxx: Status update triggered thing initialization
I’m monitoring my shellies too since I have moved to 4.2.1. In 4.2.1 an update of statusInfo is also triggered as update of thing state.
I’m using “debounce add on” to get stable state of unplugged (not connected) shellies. Please have a look at Physical entities “lost in space”
Hey Manfred, thanks for you help. Based on your info I implemented the debouncing.
I am currently ordering a Zigbee2MQTT device because the Zigbee support of my Amazon Echo device does not seem work in OpenHAB any more, so the info about Zigbee2MQTT comes handy as well.
Using local control of your zigbee devices is best choice!
Im using Sonoff Zigbee Dongle E for my zigbee2mqtt instance. You might have to flash the dongle, which is well described in Supported adapters.
