Thanks for that milestone update. Really good job.
What I have found during the first run:
- frontail
2024-03-03 22:01:59.172 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed to refresh bundles after processing config update
org.apache.felix.resolver.reason.ReasonException: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=kar; type=karaf.feature; version="[4.4.4,4.4.4]"; filter:="(&(osgi.identity=kar)(type=karaf.feature)(version>=4.4.4)(version<=4.4.4))" [caused by: Unable to resolve kar/4.4.4: missing requirement [kar/4.4.4] osgi.identity; osgi.identity=org.apache.karaf.kar.core; type=osgi.bundle; version="[4.4.4,4.4.4]"; resolution:=mandatory [caused by: Unable to resolve org.apache.karaf.kar.core/4.4.4: missing requirement [org.apache.karaf.kar.core/4.4.4] osgi.wiring.package; filter:="(&(osgi.wiring.package=org.osgi.framework)(version>=1.0.0)(!(version>=3.0.0)))" [caused by: Unable to resolve org.eclipse.osgi/3.18.0.v20220516-2155: missing requirement [org.eclipse.osgi/3.18.0.v20220516-2155] osgi.ee; filter:="(| (&(osgi.ee=JavaSE)(version=1.8)) (&(osgi.ee=JavaSE/compact1)(version=1.8)) )"]]]
at org.apache.felix.resolver.Candidates$MissingRequirementError.toException(Candidates.java:1341) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.resolver.ResolverImpl.doResolve(ResolverImpl.java:433) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.resolver.ResolverImpl.resolve(ResolverImpl.java:420) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.resolver.ResolverImpl.resolve(ResolverImpl.java:374) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.karaf.features.internal.region.SubsystemResolver.resolve(SubsystemResolver.java:256) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:399) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1069) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:1004) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) [?:?]
at java.lang.Thread.run(Thread.java:840) [?:?]
Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve kar/4.4.4: missing requirement [kar/4.4.4] osgi.identity; osgi.identity=org.apache.karaf.kar.core; type=osgi.bundle; version="[4.4.4,4.4.4]"; resolution:=mandatory [caused by: Unable to resolve org.apache.karaf.kar.core/4.4.4: missing requirement [org.apache.karaf.kar.core/4.4.4] osgi.wiring.package; filter:="(&(osgi.wiring.package=org.osgi.framework)(version>=1.0.0)(!(version>=3.0.0)))" [caused by: Unable to resolve org.eclipse.osgi/3.18.0.v20220516-2155: missing requirement [org.eclipse.osgi/3.18.0.v20220516-2155] osgi.ee; filter:="(| (&(osgi.ee=JavaSE)(version=1.8)) (&(osgi.ee=JavaSE/compact1)(version=1.8)) )"]]
... 12 more
Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve org.apache.karaf.kar.core/4.4.4: missing requirement [org.apache.karaf.kar.core/4.4.4] osgi.wiring.package; filter:="(&(osgi.wiring.package=org.osgi.framework)(version>=1.0.0)(!(version>=3.0.0)))" [caused by: Unable to resolve org.eclipse.osgi/3.18.0.v20220516-2155: missing requirement [org.eclipse.osgi/3.18.0.v20220516-2155] osgi.ee; filter:="(| (&(osgi.ee=JavaSE)(version=1.8)) (&(osgi.ee=JavaSE/compact1)(version=1.8)) )"]
... 12 more
Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve org.eclipse.osgi/3.18.0.v20220516-2155: missing requirement [org.eclipse.osgi/3.18.0.v20220516-2155] osgi.ee; filter:="(| (&(osgi.ee=JavaSE)(version=1.8)) (&(osgi.ee=JavaSE/compact1)(version=1.8)) )"
... 12 more
- Linux console
[openHAB] Listing important changes for version 4.2.0:
Warning: AndroidTV Binding: The thing configuration of 'port' has been renamed and split to 'googletvPort' and 'shieldtvPort'
Warning: ISM8 Binding: Most channels have changed and are now using Units of Measurements. Items must be adapted and the things must be recreated.
[openHAB] Running JSON Database upgrade tool (${OPENHAB_RUNTIME}/bin/upgradetool.jar).
[main] INFO org.openhab.core.tools.internal.Upgrader - Already executed 'itemCopyUnitToMetadata' on 2023-05-25T09:21:38.100603537+02:00[Europe/Warsaw]. Use '--force' to execute it again.
[main] INFO org.openhab.core.tools.internal.Upgrader - Already executed 'linkUpgradeJsProfile' on 2023-05-25T09:21:38.225637426+02:00[Europe/Warsaw]. Use '--force' to execute it again.
[main] INFO org.openhab.core.tools.internal.Upgrader - Upgrading script profile configuration in database '/var/lib/openhab/jsondb/org.openhab.core.thing.link.ItemChannelLink.json'
Exception in thread "main" java.lang.NullPointerException: Cannot invoke "String.matches(String)" because "profileName" is null
at org.openhab.core.tools.internal.Upgrader.lambda$6(Upgrader.java:263)
at java.base/java.lang.Iterable.forEach(Iterable.java:75)
at org.openhab.core.tools.internal.Upgrader.linkUpgradeScriptProfile(Upgrader.java:259)
at org.openhab.core.tools.UpgradeTool.main(UpgradeTool.java:87)
[openHAB] WARNING: internal database upgrade tool failed.
[openHAB] please check the openHAB website (www.openhab.org) for upgrade requirements.
Setting up openhab-addons (4.2.0~M1-1) ...
Updating FireMotD available updates count ...
2024-03-03_22:00:40_CET [openHABian] Checking for default openHABian username:password combination... OK
2024-03-03_22:00:40_CET [openHABian] We hope you got what you came for! See you again soon ;)
- MainUI pages icons are displayed in full size of the picture but it should be resized to icon size near the page name (checked on FF and Chrome).
I am on opehabian on RPi4
