openHAB 4.2 Milestone discussion
:+1: I have to admit that I only upgraded my (Linux) production system this evening. I’ve been running 4.2 snapshot versions on my (Windows) development system since the beginning, but never saw this exception before.
I see.
After updating to RC1 still the same, because I have a directory in the openhab conf directory.
seb@odroidc4:/etc/openhab$ ll -la | grep _infdb
drwxrwxr-x   3 openhab    openhab   4096 Jun 30 18:34 _infdb/
What user is running openhab?
Should be ā€œopenhabā€:
Seeing this now on startup
[WARN ] [service.spi.util.WebContainerManager] - Can't get a WebContainer service from {org.osgi.service.http.HttpService, org.ops4j.pax.web.service.WebContainer}={org.ops4j.pax.web.log.ncsa.extended=true, org.ops4j.pax.web.ssl.keystore.password=********, service.scope=bundle, org.ops4j.pax.web.ssl.key.password=********, org.ops4j.pax.web.session.cookie.name=JSESSIONID, org.osgi.service.http.connector.name=default, org.ops4j.pax.web.enc.iterationcount=1000, org.ops4j.pax.web.log.ncsa.file=yyyy_mm_dd.request.log, org.ops4j.pax.web.server.eventDispatcherThreadCount=1, org.osgi.service.http.checkForwardedHeaders=false, org.ops4j.pax.web.enc.suffix=), org.ops4j.pax.web.digestAuth.maxNonceAge=60000, org.ops4j.pax.web.ssl.ciphersuites.included=, org.ops4j.pax.web.session.url=jsessionid, org.ops4j.pax.web.formAuth.errorRedirect=false, org.ops4j.pax.web.ssl.ciphersuites.excluded=^.*_(MD5|SHA|SHA1)$,^TLS_RSA_.*$,^SSL_.*$,^.*_NULL_.*$,^.*_anon_.*, org.ops4j.pax.web.enc.prefix=ENC(, org.ops4j.pax.web.server.maxThreads=50, org.ops4j.pax.web.validatePeerCerts=false, service.id=163, org.ops4j.pax.web.session.cookie.maxAge=-1, org.ops4j.pax.web.ssl.truststore.password=********, org.ops4j.pax.web.ssl.session.cacheSize=-1, org.ops4j.pax.web.ssl.truststore.type=JKS, org.ops4j.pax.web.ssl.keystore.type=JKS, org.ops4j.pax.web.ssl.session.enabled=true, org.ops4j.pax.web.ssl.protocol=TLSv1.3, org.osgi.service.http.port=8080, org.ops4j.pax.web.log.ncsa.file.date.format=yyyy-MM-dd, org.ops4j.pax.web.ssl.renegotiationLimit=-1, org.osgi.service.http.secure.enabled=true, org.osgi.service.http.enabled=true, org.ops4j.pax.web.server.idleTimeout=300000, org.ops4j.pax.web.log.ncsa.retaindays=90, org.ops4j.pax.web.log.ncsa.logtimezone=GMT, org.ops4j.pax.web.enc.algorithm=PBEWithHmacSHA256AndAES_128, org.ops4j.pax.web.validateCerts=false, org.ops4j.pax.web.config.files=/usr/share/openhab/runtime/etc/jetty.xml, org.ops4j.pax.web.ssl.renegotiationAllowed=true, org.ops4j.pax.web.digestAuth.maxNonceCount=1024, org.ops4j.pax.web.enableOCSP=false, org.ops4j.pax.web.ssl.clientauth.needed=false, org.ops4j.pax.web.enc.enabled=false, org.osgi.service.http.port.secure=8443, javax.servlet.context.tempdir=/var/lib/openhab/tmp, org.ops4j.pax.web.enableCRLDP=false, org.ops4j.pax.web.server.connector.idleTimeout=30000, org.ops4j.pax.web.session.timeout=10, org.ops4j.pax.web.ssl.clientauth.wanted=false, org.ops4j.pax.web.ssl.protocols.excluded=SSL,SSLv2,SSLv2Hello,SSLv3, service.bundleid=232, org.ops4j.pax.web.server.minThreads=2, org.ops4j.pax.web.session.cookie.secure=false, org.ops4j.pax.web.enc.masterpassword=********, org.ops4j.pax.web.log.ncsa.append=true, org.osgi.service.http.secure.connector.name=secureDefault, org.ops4j.pax.web.ssl.session.timeout=-1, org.ops4j.pax.web.listening.addresses=0.0.0.0, org.ops4j.pax.web.log.ncsa.buffered=true, org.ops4j.pax.web.session.cookie.sameSite=unset, org.ops4j.pax.web.log.ncsa.enabled=false, org.ops4j.pax.web.ssl.protocols.included=, org.ops4j.pax.web.session.cookie.httpOnly=true, org.ops4j.pax.web.server.showStacks=false}
After a reboot it’s gone
Don’t see it anymore @Lolodomo
Updated to 4.2.0.RC1 yesterday, and the Shelly binding seems to be pretty broken now and unusable.
For all non-battery Shelly devices (Updated: My battery devices are handled by MQTT), the Shelly binding reports errors like
  • COMMUNICATION_ERROR ā€œVerbindung zu GerƤt fehlgeschlagenh: API Timeout forā€
  • COMMUNICATION_ERROR Verbindung zu GerƤt fehlgeschlagenh: java.lang.IllegalArgumentException: Unsupported Auth type/algorithm requested by device(class java.lang.IllegalArgumentException)
The binding also seems to DoS my shelly devices, some became unresponsive last nighty :thinking:
What was your previous version ? I do not see recent merges for Shelly.
this issue is still there
Before I had the last stable version of Openhab 4.1.x. I didn’t try any other Milestone version before. So maybe the problem has been introduced with [shelly] Various small fixes for BLU HT, Range Extender, Plus 10V, TRV set temp by markus7017 Ā· Pull Request #16746 Ā· openhab/openhab-addons Ā· GitHub with 4.2.0.M4? All I can say is that with 4.1.x all my 15 shelly devices were working and now 80% all are broken.
Pinging @markus7017 for the Shelly problems.
I see now also this warning
Failed to use TransformationStep{serviceName='JS', function='| (parseFloat(input) > 0) ? input : 0'}, service not found
All these PR’s were merged since 4.1:
https://github.com/openhab/openhab-addons/pulls?q=is%3Apr+in%3Atitle+shelly+milestone%3A4.2+is%3Aclosed+-label%3Adocumentation%2Cpatch
When @markus7017 is available, he will probably need debug or trace logs. Can you provide those?
log:set trace org.openhab.binding.shelly
I guess you just have a wrong channel link somewhere that you have to fix. Nothing that we can fix in the software. You can also try the new health checks feature available in Main UI.
If you change the items file…the old link is still there and not deleted only after cleaning the cache its deleted…the non existing item is also listes in the health check…
Is it clear now @Lolodomo
sudo apt install openhab=4.2.0~M2-1 openhab-addons=4.2.0~M2-1
Shelly binding works in M2, all things are online.
sudo apt install openhab=4.2.0~M3-1 openhab-addons=4.2.0~M3-1
Shelly binding is broken after update to M3. Knowing that, it must be some change in M3. So either 16625 or 16744.
I will now update to RC1 again, and try to come up with some debug log.
No, I am running M3 on two different locations with >50 Shelly devices, mains and battery powered. Donā€˜t see any problems.
Shelly trace logs, filtered for shelly device shelly25-relay-98f4acf2a04c to reduce logs.
Device ID and IP addresses are obfuscated.
shelly-4.2.0.m3-trace.log (5.4 KB)
The thing is defined like this:
Thing shelly:shelly25-relay:98f4acf2a04c "Wohnzimmer - Lampe" @ "Wohnzimmer" [deviceIp="192.168.5.221"]
Username and password are defined in the global binding config and are correct.
This shelly device is a SHSW-25 / Shelly 2.5 with the latest firmware 20230913-112234/v1.14.0-gcb84623
I really wonder what is happening there. I have installed RC1 on a brand new Ubuntu VM and I’m not able to get an AccessDeniedException.
After chmod a-r I finally managed reproduce it. So it sure is a rights issue. I have prepared a fix which will log
15:36:46.003 [WARN ] [yaml.internal.YamlModelRepositoryImpl] - Failed to process /etc/openhab/.git: AccessDeniedException
instead of the stacktrace.
