It doesn’t help because it ends up in configuration properties, not the thing properties. Could be that is by design or a bug in core, but not easy to fix for sure.
Yes that’s true,I believe you can’t set thing properties like that in thing file, only configuration parameters.
By the way, I believe you found how to fix the issue now.
Whatever you fixed here, it works
All things are back online.
Here is the fix
It would be good if someone who uses UI and at least someone who uses gen 2 devices can check if I broke something there.
Will check in a couple of minutes….
Upgraded one of my installations to RC1 and then updated shelly Binding to your patched version.
Not a single shelly device, all Gen2 UI configured is coming online: HANDLER_MISSING_ERROR
Can you send the YAML? I‘ll check that
Something strange is happening here.
Update of shelly binding resulted in handler missing error and bundle list showed it as a smarthomej binding.
Removed the bundle and installed it again (bundle:install) and now Shellys are back online
UID: shelly:shellyplus1pm:10061cca9514
label: Shelly Plus1PM Bedroom (shellyplus1pm-10061cca9514@192.168.1.59)
thingTypeUID: shelly:shellyplus1pm
configuration:
enableBluGateway: false
deviceIp: 192.168.1.59
updateInterval: 60
enableRangeExtender: false
That‘s really strange. There has never been a smarthome/j Shelly binding. What is returned by list -s | grep shelly
now?
After a bundle:install from your download link, it is reported correct.
As said, something strange here. Had y couple of unrelated error message…
I might have mixed up thing. Now it is showing
334 x Active x 80 x 4.2.0.RC1 x org.openhab.binding.shelly
openhab> update org.openhab.binding.shelly http://download.smarthomej.org/org.openhab.binding.shelly-4.2-SNAPSHOT.jar
334 │ Active │ 80 │ │ mvn:org.openhab.addons.bundles/org.openhab.binding.shelly/4.2.0.RC1
Are you using Gen1 or Plus/Pro (Gen 2/3) devices?
Discovered by UI or defined in .things?
According to this post, only Gen1 with textual config
@hmerk Do you have textual configurations? (.things)
I updated the DEV build with a changed initialization if deviceGeneration property is not set (as usually with .things file definitions). Who can verify
a) That things defined in .things work properly
b) and thiose discovered and added by the UI
c) a complex config with a mix on Gen 1 and Gen 2 - what happens after upgrading the binding
b) is my standard test case and works in my dev and prod setup
c) was done the last days multiple times and works, but based on the DEV build not RC2
For a) I have no setup
No, completely UI based….
ok, I did a simple test with Shelly 1 and the new version initializes a Shelly 1 defined in .things and multiple Gen2 UI-based, so seems to fix the problem
A change, even if possibly not yet perfect, was merged. A new RC2 should be built in the coming hours. So Shelly users, please try 4.2 RC2 when available to confirm that it works well.
I’ll publish RC2 in the early afternoon - stay tuned!
Within my setup (not RC2) I verified a combination of
- Shelly 1 defined in .things (Gen1)
- Shelly Plus Plug in .things (Gen2)
- A Shelly 1 and a 2.5 discovered by UI (Gen 1)
- A mix of Gen 2 and Gen 3 devices discovered by the UI
so far all looks good with the fix.
