Openhab 4.3 AVM Binding
After I upgrade my fritzbox to 8.0.2 the Bindung is no longer working.
see follow:
2025-02-16 20:56:45.423 [DEBUG] [l.discovery.AVMFritzDiscoveryService] - Discovered unsupported device: [ain=xxxxxxxxxxx,bitmask=320,isHANFUNDevice=false,isHANFUNButton=false,isHANFUNAlarmSensor=false,isButton=false,isSwitchableOutlet=false,isTemperatureSensor=true,isHumiditySensor=false,isPowermeter=false,isDectRepeater=false,isHeatingThermostat=true,hasMicrophone=false,isHANFUNUnit=false,isHANFUNOnOff=false,isDimmableLight=false,isColorLight=false,isHANFUNBlind=false,id=49,manufacturer=AVM,productname=FRITZ!Smart Thermo 301,fwversion=05.21,present=1,name=FRITZ!DECT 301 UG Küche,battery=30,batterylow=1,null,null,null,[tist=42,tsoll=42,absenk=32,komfort=42,lock=0,devicelock=0,errorcode=0,batterylow=1,windowopenactiv=0,windowopenactiveendtime=0,boostactive=0,boostactiveendtime=0,battery=30,nextchange=[endperiod=1739736000,tchange=32],summeractive=0,holidayactive=0],[celsius=21.0,offset=-2.0],null,null,null,null,null]
After I Switch To Debug Mode…
Not supported, why?
Currently i have the same issue on FB7490 with OS 7.60. It worked before but since update i also get :slight_smile:
Blockquote
[DEBUG] [l.discovery.AVMFritzDiscoveryService] - Discovered unsupported device: [ain=09995 0736001,bitmask=320,isHANFUNDevice=false,isHANFUNButton=false,isHANFUNAlarmSensor=false,isButton=false,isSwitchableOutlet=false,isTemperatureSensor=true,isHumiditySensor=false,isPowermeter=false,isDectRepeater=false,isHeatingThermostat=true,hasMicrophone=false,isHANFUNUnit=false,isHANFUNOnOff=false,isDimmableLight=false,isColorLight=false,isHANFUNBlind=false,id=18,manufacturer=AVM,productname=FRITZ!Smart Thermo 301,fwversion=05.21,present=1,name=FRITZ!DECT 301 #Kanner,battery=100,batterylow=0,null,null,null,[tist=45,tsoll=31,absenk=28,komfort=42,lock=0,devicelock=0,errorcode=0,batterylow=0,windowopenactiv=0,windowopenactiveendtime=0,boostactive=0,boostactiveendtime=0,battery=100,nextchange=[endperiod=0,tchange=42],summeractive=0,holidayactive=0],[celsius=22.5,offset=-1.0],null,null,null,null,,null]
Blockquote
Hi, I do have created a bug issue on the github page of the binding. Became I am not able to discover nor switch my Fritz DECT switches anymore.
I suspect the rootcause is the reworked SmartHome area that does come with the latest updates of fritz OS.
Unfortunately I didn’t received any comment so far. To me it is not understandable why a breaking change find its way into a release of fritzOS. But I have to admit that I didn’t research if AVM advertised that change in the past.
Any Feedback fromm Bug Report?
unfortunately not
I only have a couple of dect devices and replaced them with zigbee or zwave. more or less using the advantages an open platform like openhab offers. not willing to spend more time if code maintainer is not interested or able to keep work going.
I’ve noticed that some DECT 200s work, but others don’t. It’s possible that this has something to do with the hardware revision.
