I have integrated Bosch washer, disher and dryer. All works OK.
My state from e.g. washing temperature looks like: LoundryCare.Washer.EnumType.Temperature.GC60
For short state like 60 Celsius I can use map transformation.
How can I shorten item state with another OH4 transformation method (script) please ?
Thanks for help.
The tutorials and solutions category is for posting a solution, not for asking for one. I’ve move this to a more appropriate category.
The easiest would probably be to use a REGEX Transform.
To get just the number at the end it’s a simple REGEX(.*C([\d]+)) for the temperature and REGEX(.*M([\d]+)) for the speed.
If you apply these at the Channel or in a transform profile you can make Spin Speed be a Number:Frequency and the Washing Program Temperature be a Number:Temperature type Item. Then it can be used in math in rules and such much more easily.
