Ok, you have a point. I probably don’t value it that much because it’s been like that on rules DSL ever.
But I don’t see this to be valueable enough to change the recommendation. And it’s a bug that needs fixing. Upscaling hardware/OS/middleware is just a workaround.
32 and 64 bit openHABian are available, and we’ll have to keep providing 32bit builds for owners of RPi 2 and older hardware.
Agreed, and we even have someone from the GraalVM development team on our issue helping out. But OH’s way of using GraalVM is a use case they never considered and is definitely not in their main path. The only solution thus far is “use a 64-bit JRE or GraalVM”. If it is a bug and it’s a bug in the upstream… , what can we do about it beyond taking their recommendation?
I think my main point is the blanket black and white “use 32-bit, don’t even consider 64-bit” is more of a gray area. The fact that you support a 64-bit openHABian also is an indicator that there is some gray area here.
I’m not recommending 32-bit be dropped or even that we don’t recommend 32-bit first. But I wonder if a more nuanced warning should be offered. Currently the section says:
64 bit?
RPi 3 and 4 have a 64 bit processor and you may want to run openHAB in 64 bit. Be aware that running in 64 bit has no relevant advantages but a major drawback: increased memory usage. That is not a good idea on a heavily memory constrained platform like a RPi.
On x86 hardware, 64 bit is the standard.
My biggest concern is the “no relevant advantages”. Maybe we can replace that with something like
Be aware that running 64 bit has a major drawback: increased memory usage. This can be a problem on a memory constrained platform like an RPi running openHAB which required a large amount of memory. Any reason to run on 64 bits needs to be weighted against this limitation.
I don’t particularly like the specific wording I’ve come up with but I think that gets my point across. Then in the Blockly and JS Scripting docs we can offer, “if you are on an RPi 4/5 with 4GB+ RAM and little else running on the machine, 64 bit is recommended. If you are on an RPi 3 or otherwise memory constrained, sorry, you are kind of out of luck and have to live with the slow initial load of Blockly and JS Scripting rules.”
Compare to previous images where the 32-bit and 64-bit image are nearly of the same size this time ( bookworm release 1.9 ) the 64-bit image is only about half of the size of the 32-bit image.
Is this expected ?
