openHAB 5.0 Release Discussion
Sure:
Thing
UID: speedtest:speedtest:glasfaser
label: Ookla Speedtest
thingTypeUID: speedtest:speedtest
configuration:
  refreshInterval: 0
channels:
  - id: server
    channelTypeUID: speedtest:server
    label: Server
    description: The remote server that the Speedtest was run against
    configuration: {}
  - id: timestamp
    channelTypeUID: speedtest:timestamp
    label: Timestamp
    description: Timestamp of the Speedtest run
    configuration: {}
  - id: pingJitter
    channelTypeUID: speedtest:pingJitter
    label: Ping Jitter
    description: Ping Jitter - the variation in the response time
    configuration: {}
  - id: pingLatency
    channelTypeUID: speedtest:pingLatency
    label: Ping Latency
    description: Ping Latency - the reaction time of your internet connection
    configuration: {}
  - id: downloadBandwidth
    channelTypeUID: speedtest:downloadBandwidth
    label: Download Bandwidth
    description: Download bandwidth, e.g. in Mbit/s
    configuration: {}
  - id: downloadBytes
    channelTypeUID: speedtest:downloadBytes
    label: Downloaded Bytes
    description: Amount of data that was used for the last upload bandwidth test
    configuration: {}
  - id: downloadElapsed
    channelTypeUID: speedtest:downloadElapsed
    label: Download Elapsed Time
    description: Time spent for the last download bandwidth test
    configuration: {}
  - id: uploadBandwidth
    channelTypeUID: speedtest:uploadBandwidth
    label: Upload Bandwidth
    description: Upload bandwidth, e.g. in Mbit/s
    configuration: {}
  - id: uploadBytes
    channelTypeUID: speedtest:uploadBytes
    label: Uploaded Bytes
    configuration: {}
  - id: uploadElapsed
    channelTypeUID: speedtest:uploadElapsed
    label: Upload Elapsed Time
    description: Time spent for the last upload bandwidth test
    configuration: {}
  - id: isp
    channelTypeUID: speedtest:isp
    label: ISP
    description: Your Internet Service Provider (ISP) as calculated by Ookla
    configuration: {}
  - id: interfaceInternalIp
    channelTypeUID: speedtest:interfaceInternalIp
    label: Interface Internal IP
    description: IP address of the internal interface that was used for the test
    configuration: {}
  - id: interfaceExternalIp
    channelTypeUID: speedtest:interfaceExternalIp
    label: Interface External IP
    description: IP address of the external interface that was used for the test
    configuration: {}
  - id: resultUrl
    channelTypeUID: speedtest:resultUrl
    label: Result URL
    description: The URL to the Speedtest results in HTML on the Ookla webserver
    configuration: {}
  - id: resultImage
    channelTypeUID: speedtest:resultImage
    label: Result Image
    description: The Speedtest results as image
    configuration: {}
  - id: triggerTest
    channelTypeUID: speedtest:triggerTest
    label: Trigger Test
    description: Trigger in order to run Speedtest manually
    configuration: {}
Items
String OoklaSpeedtestServer "Server" {channel="speedtest:speedtest:glasfaser:server"}
DateTime OoklaSpeedtestTimestamp "Timestamp [%1$td.%1$tm. %1$tH:%1$tM]" {channel="speedtest:speedtest:glasfaser:timestamp"}
Number:Time OoklaSpeedtestPingLatency "Ping latency" {channel="speedtest:speedtest:glasfaser:pingLatency"}
Number:DataTransferRate OoklaSpeedtestDownloadBandwidth "Download bandwidth" {channel="speedtest:speedtest:glasfaser:downloadBandwidth"}
Number:DataTransferRate OoklaSpeedtestUploadBandwidth "Upload bandwidth" (gMariaDB,gRestore) {channel="speedtest:speedtest:glasfaser:uploadBandwidth"}
Switch OoklaSpeedtestTriggerTest "Start" <wss3_speedtest_reload> {channel="speedtest:speedtest:glasfaser:triggerTest"}
Sitemap
Text label="Speedtest" icon="server" {
Default item=OoklaSpeedtestServer
Default item=OoklaSpeedtestTimestamp
Default item=OoklaSpeedtestPingLatency
Default item=OoklaSpeedtestDownloadBandwidth
Default item=OoklaSpeedtestUploadBandwidth
Default item=OoklaSpeedtestTriggerTest
Cron triggered rule:
rule "start speedtest on specific times"
Time cron "0 15 8,18 ? * * *"
OoklaSpeedtestTriggerTest.sendCommand(ON)
Icons are from here:
Edit: something weird is going on with formatting in the forum, please shout if something is not working because of bad quotes or similar …
