openHAB 5.1 SNAPSHOT Discussion
Please discuss openHAB 5.1 SNAPSHOT related stuff here.
 if (typeof timer === 'number')
I have a js rule which works in 5.0 milestone but not in 5.1 snapshot 4801
“typeof timer” returns “true” in OH 5.0 milestone , but in OH 5.1 Snap 4801 it returns “undefined”.
Any ideas what has changed.
regards Wolf
if (event.itemState.toString() == 'offen' ){         // WohnungstĂŒr öffnet
  items.TS03_OpenTimestamp.postUpdate(Date.now());  // Datum in Timestamp speichern
  //Meldung falls man abwesend ist
  if (iJemandAnwesend.state === 'OFF') OH_function.sendMessage(message_2);
  else {
    // Meldung falls anwesend und HaustĂŒr zu lange auf ist
    var timer = setTimeout(function() {OH_function.sendMessage(message_3)},1 * minute );
    //Meldung falls anwesend und Toilettenfenster offen ist
    if (iFenster.state === 'offen') OH_function.sendMessage(message_1);
} else{          //TĂŒr schliesst
  if (typeof timer === 'number') {
    clearTimeout (timer);
    timer = undefined ;
 items.TS03_CloseTimestamp.postUpdate(Date.now());  // Datum in Timestamp speichern
I know that JS is a little different from most languages in how it treats var, but even still shouldn’t timer be declared above the first if?
Furthermore, you almost certainly want to save this variable from one run to the next which means you need to put it into the cache.private.
I’m not sure why it worked before and doesn’t now, but I believe the current behavior is the correct behavior.
Looking at the release notes for 5.0.1 it looks like the version of JS was upgraded. Perhaps that’s the source of the changed behavior; the newer version of JS may be more strict about scope.
I updated the rule as you said, it’s proper working, but why does the new timerID counts up when using settimeout
var timerTuer = cache.private.get('timerTuer', () => 0);
console.log("timerTuer from cache -> " + timerTuer);
  if (iJemandAnwesend.state === 'OFF') OH_function.sendMessage(message_2);  //Meldung falls man abwesend ist
  else {
    timerTuer = setTimeout(function() {OH_function.sendMessage(message_3)},1 * minute );
    console.log('new timerTuer while open the door: ' + timerTuer);
    cache.private.put('timerTuer',timerTuer);
  if ( timerTuer != 0) {
    console.log("cache removed");
    clearTimeout (timerTuer);
    cache.private.remove('timerTuer');
ircle 17:45:07.603	INFO	org.openhab.automation.script.ui.TS03_Open_CLose	timerTuer from cache -> 0
info_circle 17:45:07.610	INFO	org.openhab.automation.script.ui.TS03_Open_CLose	new timerTuer while open the door: 1
info_circle 17:45:08.544	INFO	org.openhab.automation.script.ui.TS03_Open_CLose	timerTuer from cache -> 1
info_circle 17:45:08.548	INFO	org.openhab.automation.script.ui.TS03_Open_CLose	cache removed
info_circle 17:45:11.154	INFO	org.openhab.automation.script.ui.TS03_Open_CLose	timerTuer from cache -> 0
info_circle 17:45:11.165	INFO	org.openhab.automation.script.ui.TS03_Open_CLose	new timerTuer while open the door: 2
info_circle 17:45:12.150	INFO	org.openhab.automation.script.ui.TS03_Open_CLose	timerTuer from cache -> 2
info_circle 17:45:12.153	INFO	org.openhab.automation.script.ui.TS03_Open_CLose	cache removed
info_circle 17:46:58.186	INFO	org.openhab.automation.script.ui.TS03_Open_CLose	timerTuer from cache -> 0
info_circle 17:46:58.194	INFO	org.openhab.automation.script.ui.TS03_Open_CLose	new timerTuer while open the door: 3
info_circle 17:47:05.671	INFO	org.openhab.automation.script.ui.TS03_Open_CLose	timerTuer from cache -> 3
info_circle 17:47:05.673	INFO	org.openhab.automation.script.ui.TS03_Open_CLose	cache removed
That’s how JS setTimeout works. When you call setTimeout it creates a new timer and returns a number as the ID of the timer. Every time you call it, a new timer is created so there’s a new ID, every time. These IDs don’t need to be globally unique over all software running everywhere in the world so using a one-up number is a reasonable approach for the ID.
If you want to reuse the timer or have more controls you need to use an OH timer instead of setTimeout.
Thank‘s Rich, my question aims more to the use of the timerID. Is it resettable (not only by restoring the rule) , is it a random number or does it always counts up by one and whats the limit (16 bits ?) . Couldn‘t find any information on this,
No.
Looks like it always counts up by one but that could just be how the implementation of JS we are using does it. I don’t think that is defined in the ECMAScript spec. I certainly wouldn’t try to rely on it for anything.
I don’t know if it returns a Number or a BigInt. If the former it’s 53 bits If the latter there is no upper bound. I suspect it uses a Number.
Resetting the ID is almost certainly not something you need to worry about. The chances that you’ll ave a single rule create 9 quadrillion timers before OH is restarted or the rule is reloaded is pretty much zero. The chances you’ll create even 10000 timers before that is pretty small. But even in that case, I’m willing to bet that the IDs will just start over at the lowest number that isn’t currently being used by an active timer.
UI-based rules are now being wrapped in a self invoking function, which allows the use of let, const, class, function and return keywords.
Absolutely agree, I wonder why it has worked before, as vars are normally local to the code block they are declared at. For code executed in the global context that might differ though, but than that’s not the behaviour I’d expect.
I have implemented the timers according to the mdn documentation: Window: setTimeout() method - Web APIs | MDN
There is no specification how to select a number in the mdn docs, just the typical range, which fits into a Java Integer, i.e. 32 bits.
Note that timeout IDs are local to the context and not globally unique.
Our implementation starts with 1 and then counts up.
Does this apply to script based transforms as well?
I ask because now that I’m on a recent snapshot (#4801) I was able to adjust my couple of rules that appeared impacted by this (again, mostly having to do with the event object). However, I have one managed jsscript transform that worked previously and now fails.
The transform calls an actions.HTTP.sendHttpPostRequest but now only results in
ReferenceError: "actions" is not defined in <eval> at line number 10 at column number 23
(the transform is applied to a link on a few string channels and sends an incoming string value to my local ollama for re-phrasing).
So is there something about the new wrapper that is impacting the actions object in transforms?
I recognize that there is approximately 0 reason to use the actions object in transforms (and my one unusual use case could also be a rule), so if actions have been intentionally removed that would make sense.
The wrapper is only applying to rules.
The library isn’t automatically injected anymore for transformations, as this — you noted it already — usually isn’t needed, and it should save both time and memory leaving stuff out you don’t need.
This would be a fairly significant breaking so it needs to be announced as such. A large number of users are depending on access to Items in their transformations so they can filter or modify the input based on the previous state of the Item or the state of some other Item and stuff like that.
The mitigation isn’t hard, we just need to require @runtime, right? But it will require manual changes to a lot of people’s transformations.
You only need to var { items } = require(„openhab“).
I also want to change the default to inject automatically everywhere, but have no access to my machine at the moment.
If I use it in a profil jsscript transformation (latest snapshot ) it creates an error.
Is it not installed at the moment or am I totally wrong again?
(function(data) {
  var { items} = require('openhab');
  itemname      = name + '_LifeCheck';
  itemname_time = name + '_LifeCheckTimestamp';
  items.getItem(itemname).postUpdate('aktiv');
  items.getItem(itemname_time).postUpdate(Date.now());
  if      (data == "false") return "nein";
  else if (data == "5633") return "gekippt";
  else if (data == "5632") return "offen";
  else if (data == "22") return "offen";
  else if (data == "23") return "zu";
  else return data;
})(input)
update : corrected the fault (quotes)
Shouldn’t you use ‘normal’ quotes instead of ‘special’ (curly and ‘lower’) quotes?
Thank’s , sometimes really blind. I’m using it quit often and didn’t saw the quotes
And the error?
Where does itemname come from? If you are passing this variable into your transformation using URL encoded parameters (see the docs) you need to pass it into your function in addition to input. You never declared this as a variable but maybe that was your intent? That’s why you must always post the error. It’s like going to the doctor and just saying “hurts” without even telling them where it hurts.
Overall, this transformation is really something that should be implemented as a rule. It’s a bad practice for a transformation on one Item to affect the states of other Items. A transformation should only affect the Item it applies to. Coordinating between Items belongs in a Rule. If you continue down this path you’ll end up with spaghetti code where it’s really hard to tell where update and change events to your Items are coming from.
A better implementation of the above would be to link the same Channel to the “_LifeCheck” Item with a Map Transformation that always returns “aktiv”. Link the same Channel to the “__LifeCheck_Timestamp” with the timestamp profile. And change to use the Map Transformation on the currently linked Item to convert the “false” and numbers to the text you want.
Not only is it less code, but you will always know where the states for these Items comes from because it’s right there configured on the Item itself, not in the profile of some other Item.
Thank’s Rich for your always well appreciated infos:
This was the error code without the library
Failed to process script 'config:js:LifeCheck_Timestamp?name=LS13' in link 'LS13_Temperatur -> mqtt:topic:MQTT_NAS:LS13:LS13_Temperatur': ReferenceError: "items" is not defined in <eval> at line number 7 at column number 3
Thing to Item Transformation is done by
I don’t know, why Using ‘username’ without declaration is working. ‘var username =
’ seems to be ok.
I used your version of Channel and item links while the above error was shown. You cannot link an existing time item to a number or string channel in the things declaration UI, therefore you will have to do it in the Items section. I was too lazy to do so, so I used these universal profile for mapping and setting these two lifecheck items.
getting this error latst snapshotbuild
ReferenceError: "rules" is not defined in /etc/openhab/automation/js/zwave.js at line number 4 at column number 1
Same here on 5.1.0.M1
How did you solve that?
