openHAB 5.2 SNAPSHOT discussion
Please discuss openHAB 5.2 SNAPSHOT related stuff here.
Upgraded from 5.2.0-SNAPSHOT #5051 to SNAPSHOT #5090.
Have pages with floorplans. They have changed after the upgrade. Lettering (items) have an offset now against the background picture and against the icons. See the screenshot below. This is a map of my heatpump (eBUS binding). To be honest: its not 100% clear what has an offset against what :-), but it doesn’t look like before.
If this is intended or necessary for some reason, my pages will need a rework?
It should look similar to this page:
Icons and items should basically be inline. Other items should be somehow centric to the clouds.
When reporting issues with pages or widgets, please always provide the YAML.
Okay, here is the YAML. Crosschecked this file with the last one which worked out and they are absolutely identical.
Further analysis:
  1. The position of the magenta colored tooltips (items) changed slightly by 5px. Here “Always display the tooltip” is enabled.
  2. Icons have a different offset against these tooltips than before the OH upgrade (approx. 15px in X and Y).
  3. Black/green/red colored tooltips (items) changed their position. Here “Always display the tooltip” is disabled and “Use tooltip as label” is enabled.
  backgroundColor: white
  imageHeight: 480
  imageUrl: /static/VML105_6_out.png
  imageWidth: 640
  label: WĂ€rmepumpe VML105/6 Outdoor
  order: "2"
  sidebar: true
markers:
  - component: oh-plan-marker
      coords: 379.1924793102342,44.321198880416986
      iconUseState: false
      item: Vaillant_HMU_Main_Board_Luft_Einlass_Temperatur
      tooltipFontSize: 20px
      tooltipPermanent: false
      useTooltipAsLabel: true
    slots:
      default: []
      coords: 414.89566729723674,550.93712497185
      item: Vaillant_HMU_Main_Board_Vorlauf_Temperatur
      name: Vorlauftemperatur Heizkreis
    slots:
      default: []
      coords: 439.51855556413506,193.9052451018243
      item: Vaillant_HMU_Main_Board_Schaltzustand_4WegeVentil
      name: Schaltstellung 4-Wege Inverter Ventil
    slots:
      default: []
      coords: 306.5549589228841,581.1001630988004
      item: Vaillant_HMU_Main_Board_Leistung_Gebaudepumpe
      name: Leistung WILO-GebÀudepumpe
    slots:
      default: []
      coords: 317.6352586429884,218.52813336872262
      item: Vaillant_HMU_Main_Board_Kompressor_Einlass_Temperatur
      name: Kompressor Einlasstemperatur
    slots:
      default: []
      coords: 303.4770978895218,216.68141674870526
      item: Vaillant_HMU_Main_Board_Niederdruck_Kaltekreis
      name: Niederdruck KĂ€ltekreis (Kompressor Einlass)
    slots:
      default: []
      coords: 220.99042219541246,379.80805151690663
      item: Vaillant_HMU_Main_Board_Kompressor_Auslass_Temperatur
      name: Kompressor Auslasstemperatur
    slots:
      default: []
      coords: 206.83226144194592,372.42118503683713
      item: Vaillant_HMU_Main_Board_Hochdruck_Kaltekreis
      name: Hochdruck KĂ€ltekreis
    slots:
      default: []
      coords: 233.91743853553407,224.06828322877476
      item: VaillantHMUMainBoard_KompressorModulation
      name: Kompressor Modulation
    slots:
      default: []
      coords: 219.14370557539507,219.75927778206753
      item: Vaillant_HMU_Main_Board_Kompressor_Drehzahl
    slots:
      default: []
      coords: 181.59380096837515,289.9345093427278
      item: VaillantHMUMainBoard_AktuelleStromaufnahme
      name: Aktuelle Stromaufnahme Kompressor
      tooltipColor: red
    slots:
      default: []
      coords: 181.59380096837515,31.39418254029536
      item: VaillantHMUMainBoard_AktuelleLeistungausderLuft
      tooltipColor: green
    slots:
      default: []
      coords: 243.15102163562094,142.8127519480103
      item: Vaillant_HMU_Main_Board_VerdampfungsTemperatur
    slots:
      default: []
      coords: 243.15102163562094,460.44801059099865
      item: Vaillant_HMU_Main_Board_KondensationsTemperatur
    slots:
      default: []
      coords: 80.02438686741955,580.484590892128
      item: VaillantHMUMainBoard_HeizwasserDurchflussrate
      name: Durchflußrate Heizkreis
    slots:
      default: []
      coords: 29.54746592027799,145.2750407747001
      item: Vaillant_HMU_Main_Board_EEV_Auslass_Temperatur
      name: EEV Auslasstemperatur
    slots:
      default: []
      coords: 28.93189371360553,305.3238145095392
      item: Vaillant_HMU_Main_Board_Position_Expansionsventil
    slots:
      default: []
      coords: 29.54746592027799,449.98328307756685
      item: Vaillant_HMU_Main_Board_Kondensator_Auslass_Temperatur
      name: Kondensator Auslasstemperatur
    slots:
      default: []
      coords: 350, -18
      icon: oh:fan
      item: Vaillant_HMU_Main_Board_Leistung_Lufter_1
      name: Leistung LĂŒfter 1
      tooltipColor: magenta
      tooltipDirection: right
      tooltipOffsetX: 15
      tooltipPermanent: true
    slots:
      default: []
      coords: 145,-18
      icon: oh:fan
      item: Vaillant_HMU_Main_Board_Leistung_Lufter_2
      name: Leistung LĂŒfter 2
      tooltipOffsetX: 15
    slots:
      default: []
      coords: 300,-18
      icon: oh:time
      item: VaillantHMUMainBoard_BetriebsstundenLufter1
      name: Betriebsstunden LĂŒfter 1
      tooltipOffsetX: 15
    slots:
      default: []
      coords: 275,-18
      icon: classic:start
      item: VaillantHMUMainBoard_StartsLufter1
      name: Starts LĂŒfter 1
      tooltipOffsetX: 15
    slots:
      default: []
      coords: 95,-18
      icon: oh:time
      item: VaillantHMUMainBoard_BetriebsstundenLufter2
      name: Betriebsstunden LĂŒfter 2
      tooltipOffsetX: 15
    slots:
      default: []
      coords: 70,-18
      icon: classic:start
      item: VaillantHMUMainBoard_StartsLufter2
      name: Starts LĂŒfter 2
      tooltipOffsetX: 15
    slots:
      default: []
      coords: 139,290
      icon: oh:time
      item: VaillantHMUMainBoard_BetriebsstundenKompressor
      name: Kompressor Betriebsstunden
      tooltipOffsetX: 15
    slots:
      default: []
      coords: 139,365
      icon: classic:start
      item: VaillantHMUMainBoard_KompressorStarts
      tooltipOffsetX: 15
    slots:
      default: []
      coords: 180.97822876170267,576.1755854454208
      item: Heizleistung_Waermepumpe
      name: Heizleistung WĂ€rmepumpe
      tooltipColor: darkred
    slots:
      default: []
      coords: 229.60843308882687,643.8885281793912
      tooltip: "COP:"
      tooltipColor: blue
    slots:
      default: []
      coords: 229.60843308882687,676.5138551330315
      item: COP_VaillantWaermepumpe
      tooltipColor: blue
    slots:
      default: []
      coords: 226.53057205546457,547.8592639384877
      item: Vaillant_HMU_Main_Board_Rucklauf_Temperatur
      name: RĂŒcklauftemperatur Heizkreis
    slots:
      default: []
      coords: 354,655
      icon: oh:pressure
      iconRotation: 0
      item: VaillantVRC700general_Waterpressure
      tooltipOffsetX: 15
      tooltipOffsetY: 0
      useTooltipAsLabel: false
    slots:
      default: []
      coords: 267.7739099025193,538.6256808384009
      tooltip: 100% = Warmwasser
    slots:
      default: []
      coords: 136.5,225
      tooltip: "Kompressor:"
    slots:
      default: []
      coords: 291.7812259627451,356.4163076633532
      item: Vaillant_HMU_Main_Board_Kompressor_Heizwendel
      name: Heizwendel Kompressor
      tooltipDirection: bottom
      tooltipOffsetY: 15
    slots:
      default: []
      coords: 425.975967017341,8.618010893414413
      icon: oh:line
      item: VaillantHMUMainBoard_EnergieIntegral
      tooltipOffsetX: 15
    slots:
      default: []
      coords: 448.75213866422195,9.849155306759329
      name: Energie Integral Text
      tooltip: "Energie Integral:"
    slots:
      default: []
      coords: 291.1656537560727,571.8665799987135
      item: VaillantHMUMainBoard_BetriebsstundenGebaudepumpe
      name: Betriebsstunden GebÀudepumpe
    slots:
      default: []
      coords: 422.8981059839787,177.9003677283404
      item: VaillantHMUMainBoard_Schaltvorgange4WegeVentil
      name: Schaltspiele 4-Wege Inverter Ventil
    slots:
      default: []
      coords: 422.8981059839787,202.5232559952387
      name: Schaltspiele VUV Label
      tooltip: Schaltsp.
    slots:
      default: []
      coords: 90.48911438085133,374.883473863527
      item: Vaillant_HMU_Main_Board_Kondensatwannen_Heizung
      name: Heizung Kondensatwanne
    slots:
      default: []
      coords: 305,655
      icon: classic:start
      item: VaillantHMUMainBoard_GebaudepumpeStarts
      name: Starts GebÀudepumpe
      tooltipOffsetX: 15
    slots:
      default: []
      coords: 325, -18
      icon: oh:fan
      item: Vaillant_HMU_Main_Board_Neu_2_Lufter_1_Speed
      name: Speed LĂŒfter 1
      tooltipOffsetX: 15
    slots:
      default: []
      coords: 120,-18
      icon: oh:fan
      item: Vaillant_HMU_Main_Board_Neu_2_Lufter_2_Speed
      name: Speed LĂŒfter 2
      tooltipOffsetX: 15
    slots:
      default: []
Thanks for the YAML.
A short git bisect session has quickly led to the change that caused this regression.
I have created a fix: oh-map-/oh-plan-marker: Fix incorrect marker/tooltip positioning by florian-h05 · Pull Request #3752 · openhab/openhab-webui · GitHub.
After it has been merged, it will be available in the snapshots.
Upgraded to 5.2.0 #5095. Issue is fixed again. Many thanks for quick reaction.
Im the new snapshot build
Starting openHAB 5.2.0 (Build #5108)
I get only this on Startup
core.karaf.internal.FeatureInstaller] - Some .kar files are not installed yet. Delaying add-on installation by 15s.
Not starting at all
Getting this error how to solve it?
2026-01-24 08:37:14.735 [ERROR] [.automation.jsscripting.file.deye.js] - Failed to execute script: TypeError: invokeMember (setTemplateUID) on com.oracle.truffle.host.adapters.SimpleRule$$Adapter failed due to: Unknown identifier: setTemplateUID
If you have a manually installed openhab-js version, make sure to upgrade to the latest version
I run snapshot openHAB 5.2.0 build #5113 with the fix ‘Pull request #3779 “oh-canvas-item: Fix f7-swiper autoplay”’. With the fix I discover the following behaviour:
  • When I start the page at the start of openHAB 5.2.0 the “autoplay” does not work
  • When I start the page from the sidebar the “autoplay” work!
I don’t know the technical difference between the two start methods. You may know what the problem could be.
I just had another look into this and now the autoplay works when reloading/starting at the page. I have created a fix oh-canvas-item: Fix f7-swiper autoplay not working on initial page rendering by florian-h05 · Pull Request #3860 · openhab/openhab-webui · GitHub and will make sure it is in openHAB 5.1.2
I updated to openHAB 5.2.0 snapshot Build #5244 earlier this day an there are some strange visual effects on all oh-gauge and oh-knob cards.
I am not able to edit them:
Additionally all my charts are not working anymore. No data is shown - neither lines nor bars are visible.
Are any there recent changes which might cause this regression?
@cweitkamp - are there any errors in the log?
No, nothing noticeable. Neither in openHAB log nor in Browser Console.
Just FYI, I was able to reproduce graphs not working in a built version of the UI but the issue is not present in a debug environment. I’ll look into it.
@florian-h05 - I’ve traced this back to the component registry change.We statically import OhChart in OhChartPage and it looks like it is undefined in the built version.
@florian-h05 - there’s a PR with a possible fix (#4010) for the chart-page issue. However, it is odd it was just affecting the chart - not sure if you can rationalize why a static import works sometimes - but not always? Not sure if we should always import from the component-registry?
@cweitkamp, can you confirm your problems with charts was just on oh-chart-pages - or were there other chart issues?
Lastly, while the PR just fixed the oh-chart-page issue, not sure what is causing your other issues, although it is probably related.
I can confirm that only chart pages are not working. Trendlines on cards or widgets or custom widgets using persisted date are working fine.
I was able to narrow it down my problem with gauge widgets to a specific configuration. Whenever I added an action to the gauge the design is broken. Without action the design looks like it should. Here is an example:
Working:
component: oh-gauge-card
  borderColor: gray
  item: electricityPowerConsumption
  min: -805
  type: semicircle
  valueTextColor: gray
Not working:
  action: navigate
  actionPage: page:electricityPowerConsumption
  actionPageTransition: f7-cover-v
  borderColor: gray
  min: -805
  type: semicircle
Thanks for pinning it down, I’ve implemented a fix:
