Hi there!
I was able to successfully do a lot of cool things with Z-Wave switches and combined those with Harmony activities, which worked really well, to my surprise. Since I also own three thermostats from Popp/Devolo I wanted to get them included, too, and set them via Alexa.
So I configured everything like described in the official announcement from @digitaldan (Official Alexa Smart Home Skill for openHAB 2).
I could then ask Alexa to get me the different temperatures of my rooms, but setting the temperature always resulted in “I am sorry, there was some problem.”. After checking a few things, I gave up. To my surprise, though, the temperature was set, but Alexa replied with the “issue” message.
Is there anything I can do to find out more? Looking into Karaf (as an absolute beginner) + in my openHAB logs, there is nothing noteworthy to find out…
Group gBadezimmerThermostat "Badezimmer Thermostat" (gBadezimmer) ["Thermostat"]
Number BadezimmerThermostatCurrentTemp "Badezimmer Thermostat Aktuelle Temperatur" (gBadezimmerThermostat) ["CurrentTemperature"] {channel="zwave:device:b3c6347d:node8:sensor_temperature"}
Number BadezimmerThermostatTargetTemperature "Badezimmer Thermostat Ziel Temperatur" (gBadezimmerThermostat) ["TargetTemperature"] {channel="zwave:device:b3c6347d:node8:thermostat_setpoint_heating"}
String BadezimmerThermostatHeatingCoolingMode "Badezimmer Thermostat Heizen/Kuehlen Modus" (gBadezimmerThermostat) ["homekit:HeatingCoolingMode"]
EDIT: I also tried using rules, by setting a Number value via Alexa and then use a “changed” rule to update the zwave device (using a new item - not listed above). Which also resulted in the same issue message from Alexa.
rule "Wohnzimmer - set temperature"
WohnzimmerThermostatTargetTemperature received update
WohnzimmerThermostatSetPointHeating.postUpdate((WohnzimmerThermostatTargetTemperature.state as DecimalType).floatValue)
Thank you!
