OpenHAB Alexa Skill
I have found various instructions here on how I should be able to deploy openhab-alexa myself. Now all tutorials are relatively old. I have also tried one or the other very unsuccessfully.
But now I have a general question about this. Can I deploy this at all without AWS? AWS costs yes. Apparently it is only free for the first 12 months. In the latest version of the repository, I don’t see any way to deploy this via NodeJS. I have my own server, so why should Amazon make money from me? Is there a tutorial where you can only deploy via your own server and NodeJS? Can this work at all, or has Amazon virtually denied this option again with an update?
Kind regards
You should use the instructions on the project GitHub page.
https://github.com/openhab/openhab-alexa
You could deployed the skill using an https endpoint but you will have to do it manually as I don’t believe the ASK CLI tool supports that deploy method.
The AWS Lambda free tier should cover the cost of the skill usage.
