Anytime I try to create items from channels… I get the following error…
Error running command openhab.command.items.addToSitemap: Running the contributed command: ‘openhab.command.items.addToSitemap’ failed… This is likely caused by the extension that contributes openhab.command.items.addToSitemap.
I installed the openHab extension through the VS application. I have read there was an issue in doing this. Is this part of my issue…
