Is there a helpful step by step manual to configure zoneminder and openhab2 to communicate between each other?
I’ve installed zoneminder on one pi, my openhab is on another one. Zoneminder works and my openhab are working fine too.
On my openhab I’ve installed the zoneminder binding and made the configure settings for the server thing. (Yes I’ve read the instructions of the binding)
end with a 404 on my zoneminer pi.
The ‘OPT_USE_API’ in ZoneMinder must is enabled). The option ‘OPT_TRIGGERS’ also.
I’ve added an extra user in Zoneminder too.
Does anyone have an step by step manual, with all steps on zoneminder and openhab?
… and http://localhost/zm/api/ gives you a 404? The only thing I can guess is that something went wrong with your ZM install (it didn’t install CakePHP).
I too am struggling. Added the binding. The documentation for the binding says “The Bridge must therefore be added manually, this can be done from PaperUI.” OK, perhaps a little clue should be given as to how?
I see the binding in PaperUI, but there is nothing to configure.
Searches of the file structure under /etc/openhab2 and /var/lib/openhab2 find nothing related to zoneminder.
Ultimate goal - when my OH rules turn lights on and off, it triggers the ZM motion detection, so I want to script alarm suppression in ZM just before I change a light setting.
