A new version of our Android app has been pushed to the Google play store. This release addresses mostly bug fixes, better openHAB 2.0 compatibility and introduces an optional black/amoled theme. The full list of changes can be seen on the project milestone page. As always you can find the latest nightly builds here.
Calling all Android, IOS and Java Developers! If you have a fix or new feature you think would benefit the community please submit a PR and contribute to our mobile clients!
Since the update to the new 1.8.0, the charts are flashing on every status change received.
So the chart disappears and reappears after a second.
I have a PV chart with production and consumption displaying together with a number of decimals and text items.
And a web view for the weather forecast is also being shown.
Since the last update I have a problem opening group widget, which contains few dimmer items. It starts opening it (starts scrolling from right to left), then stops, and after a few seconds just hangs with “Unfortunately Openhab has stopped” message. I haven’t changed items or sitemaps for at least a year, so I guess the problem is in new version of HABDroid.
I’ve opened an issue on github, attached a screenshot and part of the sitemap configuration. Also, I’ve found out it only crashes if some of the lights/dimmers are on.
