Everytime I start up (or reboot) OpenHab2, I get the following error:
2017-02-22 12:16:30.812 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed uninstalling 'openhab-binding-tcp1': Feature named 'openhab-binding-tcp1/0.0.0' is not installed
I have the following binding “binding-tcp1 - 1.9.0”.
I think this binding came out of-the-box with my OpenHab2, since I don’t recall installing it myself.
According to PaperUI it is already installed. Uninstalling via PaperUI does not work.
Take a look at your addons.cfg if it is installed through text file:
binding = tcp1
If not go to your /userdata/etc/org.openhab.addons.cfg and take a look.
In both cases uncomment the line or delete the tcp1 part if you need it uninstalled.
Last chance: take a look into your /addons folder if you have the .jar placed in there.
My last idea: log into your karaf console, do a bundle:list, note the number most left to the line with the tcp binding (if any) then do a bundle:uninstall xxx where xxx is the number for the tcp binding.
Thank you.
I’ve logged on to the karaf console, and I’ve found the tcp binding (ID 188).
I uninstalled it (bundle:uninstall 188).
It doesn’t show up anymore. So whatever I’ve done, seems to be successfull.
However, when I reboot OpenHAB, I still get:
2017-02-22 15:02:30.165 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed uninstalling 'openhab-binding-tcp1': Feature named 'openhab-binding-tcp1/0.0.0' is not installed
Also via PaperUI it is still installed. Uninstalling via PaperUI does not work.
