I am using chatGPT in my openhab 4.1.1 and I want to try to get some (longer) text results.
In 90% of my calls I always get an empty result - resp. no result into my string variable.
I turned on now my logs to TRACE for ChatGPT and now it writes down:
2024-01-20 19:26:35.074 [DEBUG] [ding.chatgpt.internal.ChatGPTHandler] - Request to OpenAI failed: Total timeout 10000 ms elapsed
java.util.concurrent.TimeoutException: Total timeout 10000 ms elapsed
at org.eclipse.jetty.client.HttpConnection$RequestTimeouts.onExpired(HttpConnection.java:334) ~[?:?]
at org.eclipse.jetty.client.HttpConnection$RequestTimeouts.onExpired(HttpConnection.java:314) ~[?:?]
at org.eclipse.jetty.io.CyclicTimeouts.onTimeoutExpired(CyclicTimeouts.java:110) ~[?:?]
at org.eclipse.jetty.io.CyclicTimeouts.access$100(CyclicTimeouts.java:50) ~[?:?]
at org.eclipse.jetty.io.CyclicTimeouts$Timeouts.onTimeoutExpired(CyclicTimeouts.java:196) ~[?:?]
at org.eclipse.jetty.io.CyclicTimeout$Wakeup.run(CyclicTimeout.java:298) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
at java.lang.Thread.run(Thread.java:833) [?:?]
Could it be necessary to increase the timeout in my http.cfg?
I did not configure any timeout there. At least from the standard documentation it says something about 5000msec. So I have no clue where these 10.000msec come from.
Any Ideas? Thx for your support
