Openhab-cli console gets JAVA_HOME is not valid
Dear all,
  • Platform information:
    • Hardware: VM on QNAP NAS
    • OS: UBUNTO LTS 18.04.3
    • Java Runtime Environment: ZULU 8 installed as part of openhabian
    • openHAB version: 2.5 stable
  • Issue of the topic: OpenHAB itself works perfectly. I do use KNX, SONOS, email bindings. Sitemmaps and fronttail look good. However when I want to start the openhab-cli console I do get the following error
“JAVA_HOME is not valid: /usr/lib/JVM/java-8-openjdk-amd64”
The JAVA_HOME path is set and as I mentioned OH works. But I wanted to use the console to set some debugging for a specific add-on I do have trouble with.
Is there another way to enable debug mode without the console in the meantime?
You can set it in the config file. See Log4j2 Sample Config for a good example.
Hi Rich,
works like a charm, many thanks for pointing me in the right direction.
Quite case sensitive though :slight_smile:
cheers
You can assume that anything having to do with openHAB or Linux is going to be case sensitive.
