openHAB cloud connector is not working
Hello everybody,
I can’t get my Cloud Connector to work. I installed the addon via the Paper UI and then created an account on openhab.org. There I entered the UUID and the Secret as described in the manual. But the status is still offline. I have de- and installed it several times and deleted and recreated my openhab.org account several times. Unfortunately no improvement. Then I gave it up for a few months. And now I tried it again, but come to the same result. Does anyone have an explanation or an idea how to fix it? I would be really grateful!
I want to use my Google Assistant to control devices via openHAB via voice. Unfortunately you can’t avoid the openHAB cloud… :frowning:
Many Greetings
Which java version do you have installed.
I’ve installed Zulu JDK V 192 manually via this tutorial: HowTo: Install Zulu Embedded Java on Raspberry Pi 3 - #47 by Benjy
The Log shows the following:
2019-02-23 01:00:09.880 [DEBUG] [org.openhab.io.openhabcloud ] - BundleEvent INSTALLED - org.openhab.io.openhabcloud
2019-02-23 01:00:10.265 [DEBUG] [org.openhab.io.openhabcloud ] - BundleEvent RESOLVED - org.openhab.io.openhabcloud
2019-02-23 01:00:10.275 [DEBUG] [org.openhab.io.openhabcloud ] - BundleEvent [unknown:512] - org.openhab.io.openhabcloud
2019-02-23 01:00:10.307 [DEBUG] [org.openhab.io.openhabcloud ] - ServiceEvent REGISTERED - {org.osgi.service.cm.ManagedService}={service.id=417, service.bundleid=258, service.scope=singleton} - org.openhab.io.openhabcloud
2019-02-23 01:00:10.388 [DEBUG] [org.openhab.io.openhabcloud ] - BundleEvent STARTING - org.openhab.io.openhabcloud
2019-02-23 01:00:10.395 [DEBUG] [org.openhab.io.openhabcloud ] - BundleEvent STARTED - org.openhab.io.openhabcloud
2019-02-23 01:00:10.412 [DEBUG] [o.openhabcloud.internal.CloudService] - openHAB Cloud connector activated
2019-02-23 01:00:10.418 [DEBUG] [o.openhabcloud.internal.CloudService] - Using secret at ‘/var/lib/openhab2/openhabcloud/secret’ with content ‘*******************’
2019-02-23 01:00:10.421 [DEBUG] [o.openhabcloud.internal.CloudService] - UUID = *****************, secret = *******************
2019-02-23 01:00:10.432 [DEBUG] [o.openhabcloud.internal.CloudService] - Using secret at ‘/var/lib/openhab2/openhabcloud/secret’ with content '
2019-02-23 01:00:10.502 [DEBUG] [org.openhab.io.openhabcloud ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.events.EventSubscriber, org.eclipse.smarthome.model.script.engine.action.ActionService}={service.id=418, mode=remote, service.bundleid=258, service.scope=bundle, expose=Hue_Play_Computer_Schalter, component.name=org.openhab.openhabcloud, service.config.label=openHAB Cloud, component.id=255, baseURL=https://www.myopenhab.org/, service.config.category=io, service.config.description.uri=io:openhabcloud, service.pid=org.openhab.openhabcloud} - org.openhab.io.openhabcloud
2019-02-23 01:01:08.284 [DEBUG] [org.openhab.io.openhabcloud ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.core.events.EventSubscriber, org.eclipse.smarthome.model.script.engine.action.ActionService}={service.id=418, mode=remote, service.bundleid=258, service.scope=bundle, expose=Hue_Play_Computer_Schalter, component.name=org.openhab.openhabcloud, service.config.label=openHAB Cloud, component.id=255, baseURL=https://www.myopenhab.org/, service.config.category=io, service.config.description.uri=io:openhabcloud, service.pid=org.openhab.openhabcloud} - org.openhab.io.openhabcloud
2019-02-23 01:01:08.289 [DEBUG] [o.openhabcloud.internal.CloudService] - openHAB Cloud connector deactivated
2019-02-23 01:01:08.291 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2019-02-23 01:01:08.312 [DEBUG] [o.openhabcloud.internal.CloudService] - openHAB Cloud connector activated
2019-02-23 01:01:08.317 [DEBUG] [o.openhabcloud.internal.CloudService] - Using secret at ‘/var/lib/openhab2/openhabcloud/secret’ with content ‘
2019-02-23 01:01:08.319 [DEBUG] [o.openhabcloud.internal.CloudService] - UUID = ********************************************, secret = *******************
2019-02-23 01:01:08.322 [DEBUG] [o.openhabcloud.internal.CloudService] - Using secret at ‘/var/lib/openhab2/openhabcloud/secret’ with content '
2019-02-23 01:01:08.342 [DEBUG] [org.openhab.io.openhabcloud ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.events.EventSubscriber, org.eclipse.smarthome.model.script.engine.action.ActionService}={service.id=419, mode=remote, service.bundleid=258, service.scope=bundle, expose=[Hue_Play_Computer_Schalter], component.name=org.openhab.openhabcloud, service.config.label=openHAB Cloud, component.id=255, baseURL=https://www.myopenhab.org/, service.config.category=io, service.config.description.uri=io:openhabcloud, service.pid=org.openhab.openhabcloud} - org.openhab.io.openhabcloud
Is that an actual log? Sounds old to me.
Is the Zulu version a Java 8 one? openHAB is known not to work on Java 9 and Java 10.
I have openJDK 1.8.0 192 installed, so I think it’s Java 8. Zulu Version is 8.33.0.134
No it’s a log from febuary, when I tried it the first time. This is the log from today:
2019-05-30 12:15:36.907 [DEBUG] [org.openhab.io.openhabcloud ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.core.events.EventSubscriber, org.eclipse.smarthome.model.script.engine.action.ActionService}={service.id=949, mode=remote, service.bundleid=277, service.scope=bundle, expose=[Hue_Play_Computer_Schalter], component.name=org.openhab.openhabcloud, service.config.label=openHAB Cloud, component.id=322, baseURL=https://www.myopenhab.org, service.config.category=io, service.config.description.uri=io:openhabcloud, service.pid=org.openhab.openhabcloud} - org.openhab.io.openhabcloud
2019-05-30 12:15:36.924 [DEBUG] [o.openhabcloud.internal.CloudService] - openHAB Cloud connector deactivated
2019-05-30 12:15:36.927 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2019-05-30 12:15:36.960 [DEBUG] [o.openhabcloud.internal.CloudService] - openHAB Cloud connector activated
2019-05-30 12:15:36.967 [DEBUG] [o.openhabcloud.internal.CloudService] - Using secret at ‘/var/lib/openhab2/openhabcloud/secret’ with content ‘asdfsadfasdfasdfsdf’
2019-05-30 12:15:36.970 [DEBUG] [o.openhabcloud.internal.CloudService] - UUID = asdsafsdfdsfadsfasdfasdfsadfsdaf, secret = asdasdasdasdsad
2019-05-30 12:15:36.974 [DEBUG] [o.openhabcloud.internal.CloudService] - Using secret at ‘/var/lib/openhab2/openhabcloud/secret’ with content ‘asdfdasfsadfdsfdsfdsf’
2019-05-30 12:15:37.016 [DEBUG] [org.openhab.io.openhabcloud ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.events.EventSubscriber, org.eclipse.smarthome.model.script.engine.action.ActionService}={service.id=953, mode=remote, service.bundleid=277, service.scope=bundle, expose=[Hue_Play_Computer_Schalter], component.name=org.openhab.openhabcloud, service.config.label=openHAB Cloud, component.id=322, baseURL=https://www.myopenhab.org, service.config.category=io, service.config.description.uri=io:openhabcloud, service.pid=org.openhab.openhabcloud} - org.openhab.io.openhabcloud
To you see any problems there?
Thanks!
Actually I don’t see any problem.
Too bad
Do you know any other options to provide the openHAB API to the Google Assistent? Without the need of a custom cloud running on some linux server?
Or do you know an alternative to openHAB with the same or similar features and freedom than openHAB? (and with a working cloud connection)?
Most of my devices are from Devolo and using Zwave, so I could use the devolo Home Control Central Unit, but there a do not have the many possibilities than with openHAB :frowning:
The cloud connection via myopenhab.org is working, for me and lots of others.
You are using this one and not your local instance of a cloud, please confirm.
Please provide more detail what is not working for you.
Yes I’m using https://myopenhab.org/ for the connection.
The connection is not working. My openHAB is offline on the myopenhab-cloud-account-site.
What I’ve done:
  1. PaperUI → Add-Ons → MISC → openHAB Cloud Connector (misc-openhabcloud-2.4.0) → Install
    The log shows the following:
2019-05-31 20:28:42.362 [DEBUG] [org.openhab.io.openhabcloud ] - BundleEvent INSTALLED - org.openhab.io.openhabcloud
2019-05-31 20:28:43.531 [DEBUG] [org.openhab.io.openhabcloud ] - BundleEvent RESOLVED - org.openhab.io.openhabcloud
2019-05-31 20:28:43.610 [DEBUG] [org.openhab.io.openhabcloud ] - ServiceEvent REGISTERED - {org.osgi.service.cm.ManagedService}={service.id=426, service.bundleid=278, service.scope=singleton} - org.openhab.io.openhabcloud
2019-05-31 20:28:43.713 [DEBUG] [org.openhab.io.openhabcloud ] - BundleEvent STARTING - org.openhab.io.openhabcloud
2019-05-31 20:28:43.726 [DEBUG] [org.openhab.io.openhabcloud ] - BundleEvent STARTED - org.openhab.io.openhabcloud
2019-05-31 20:28:43.743 [DEBUG] [o.openhabcloud.internal.CloudService] - openHAB Cloud connector activated
2019-05-31 20:28:43.761 [DEBUG] [o.openhabcloud.internal.CloudService] - New secret = aughbrbgösegfag
2019-05-31 20:28:43.765 [DEBUG] [o.openhabcloud.internal.CloudService] - Created file ‘/var/lib/openhab2/openhabcloud/secret’ with content ‘adfgfdgsafdgf’
2019-05-31 20:28:43.768 [DEBUG] [o.openhabcloud.internal.CloudService] - UUID = aegagrdgdsrgsdg, secret = agargrdsagsdgsdgr
2019-05-31 20:28:43.782 [DEBUG] [o.openhabcloud.internal.CloudService] - Using secret at ‘/var/lib/openhab2/openhabcloud/secret’ with content ‘aegaesgfaesg’
2019-05-31 20:28:43.877 [DEBUG] [org.openhab.io.openhabcloud ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.events.EventSubscriber, org.eclipse.smarthome.model.script.engine.action.ActionService}={service.id=427, mode=remote, service.bundleid=278, service.scope=bundle, expose=Hue_Play_Computer_Schalter, component.name=org.openhab.openhabcloud, service.config.label=openHAB Cloud, component.id=258, baseURL=https://www.myopenhab.org, service.config.category=io, service.config.description.uri=io:openhabcloud, service.pid=org.openhab.openhabcloud} - org.openhab.io.openhabcloud
2019-05-31 20:28:43.889 [DEBUG] [org.openhab.io.openhabcloud ] - BundleEvent [unknown:512] - org.openhab.io.openhabcloud
2019-05-31 20:28:44.045 [thome.event.ExtensionEvent] - Extension ‘misc-openhabcloud’ has been installed.
  1. PaperUI → Configuration → Services → openHAB Cloud → Configure:
    Mode: Notification & Remote Access
    Base URL: https://www.myopenhab.org
    Chosing of an item leads to this in the Log:
2019-05-31 20:33:14.264 [DEBUG] [org.openhab.io.openhabcloud ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.core.events.EventSubscriber, org.eclipse.smarthome.model.script.engine.action.ActionService}={service.id=427, mode=remote, service.bundleid=278, service.scope=bundle, expose=Hue_Play_Computer_Schalter, component.name=org.openhab.openhabcloud, service.config.label=openHAB Cloud, component.id=258, baseURL=https://www.myopenhab.org, service.config.category=io, service.config.description.uri=io:openhabcloud, service.pid=org.openhab.openhabcloud} - org.openhab.io.openhabcloud
2019-05-31 20:33:14.322 [DEBUG] [o.openhabcloud.internal.CloudService] - openHAB Cloud connector deactivated
2019-05-31 20:33:14.324 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2019-05-31 20:33:14.358 [DEBUG] [o.openhabcloud.internal.CloudService] - openHAB Cloud connector activated
2019-05-31 20:33:14.366 [DEBUG] [o.openhabcloud.internal.CloudService] - Using secret at ‘/var/lib/openhab2/openhabcloud/secret’ with content ‘awdwafawf’
2019-05-31 20:33:14.368 [DEBUG] [o.openhabcloud.internal.CloudService] - UUID = awdfawfawfawfwaf, secret = awfesagaesgaegs
2019-05-31 20:33:14.371 [DEBUG] [o.openhabcloud.internal.CloudService] - Using secret at ‘/var/lib/openhab2/openhabcloud/secret’ with content ‘aegesagsaegsreg’
2019-05-31 20:33:14.377 [DEBUG] [org.openhab.io.openhabcloud ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.events.EventSubscriber, org.eclipse.smarthome.model.script.engine.action.ActionService}={service.id=431, mode=remote, service.bundleid=278, service.scope=bundle, expose=[Hue_Play_Computer_Schalter], component.name=org.openhab.openhabcloud, service.config.label=openHAB Cloud, component.id=258, baseURL=https://www.myopenhab.org, service.config.category=io, service.config.description.uri=io:openhabcloud, service.pid=org.openhab.openhabcloud} - org.openhab.io.openhabcloud
  1. Go to https://www.myopenhab.org/ and Login → Account → Update UUID and secret
→ Still offline…
Is there ANYTHING else I have to do? E.g. port forwarding at router?
My settings:
  • AVM Fritzbox Router 7940 connected via DSL
  • Country: german
  • IPv4 & IPv6
  • Raspberry Pi 3 with openhabianpi 2.4.0
  • Connected via Ethernet
I do not have any item exposed, switching from a remote device is still possible.
I do not see any reason why your openHAB instance should not be online
ok thats very sad… Maybe then I should give Devolo a change.
Thanks anyway!
I’ve today installed the windows version of openHAB, running on localhost on my workstation PC. And from there I got a working connection to the myopenhab cloud service. So I think, the router should not be the problem..
But why is this not working for my Raspberry Pi, too? Do anyone have experience with the RP3, openHAB and the cloud?
My instance of openHAB is running on a Raspi 3B. Everything running smooth.
What Java version are you running on?
penjdk version “1.8.0_152”
OpenJDK Runtime Environment (Zulu Embedded 8.25.0.76-linux-a
arch32hf) (build 1.8.0_152-b76)
OpenJDK Client VM (Zulu Embedded 8.25.0.76-linux-aarch32hf)
(build 25.152-b76, mixed mode, Evaluation)
As posted before, I see no reason why it doesn’t work for you. If you managed to get it working from the windows installation, you must be doing something different on the raspi.
