I have installed the openhab-cloud locally with docker according to instructions on DockerHub.
The local setup works.
I registered an email address, the uuid and secret.
I have setup the correct address for the openHab cloud connector
But the local openhab-cloud keeps telling me: "Your openHAB is not online. Please check if your installation is running or recheck the openHAB settings in your account"
If I connect the cloud connector to https://myopenhab.org/ (and use exactly the same uuid and secret), it works perfectly.
All I can see in the openhab.log when connecting to the local cloud is:
Since it was not working. I have set the domain ${DOMAIN_NAME} to a fixed local ip in both docker-compose.yml, config.json and -of course- in the cloud connector in openhab.
Also, all the docker containers are running on the same (local) machine.
Suggestions about how to debug where the problem is, are welcome.
Have a look at apps.js.
This code snippet might not be taken from the latest release so yours might look different:
if (taskEnv === 'main') {
setInterval(function () {
logger.debug('openHAB-cloud: Checking for offline openHABs (' + Object.keys(offlineOpenhabs).length + ')');
for (var offlineOpenhabUuid in offlineOpenhabs) {
if (Date.now() - offlineOpenhabs[offlineOpenhabUuid] < 5 * 60 * 1000) {
continue;
delete offlineOpenhabs[offlineOpenhabUuid];
logger.debug('openHAB-cloud: openHAB with ' + offlineOpenhabUuid + ' is offline > 300 sec, time to notify the owner');
Openhab.findOne({
uuid: offlineOpenhabUuid
}).exec(function (error, openhab) {
if (!openhab || error) {
return;
//if this has not connected to another server, then notify
if(openhab.serverAddress == internalAddress){
notifyOpenHABOwnerOffline(openhab);
}, 60000);
You could add additional debug output statements to detect at which step your cloud instance is detected to be offline.
As far as I understand the code if openhab server address is the internal address the code assumes it is offline.
