I’m new to OpenHAB
. Hope this isn’t a duplicate question.
My Z-Way Server
panel says:
OpenHAB Connector doesn't exist in Z-Way server
I found from this post where z-way binding was originally introduced last year that OpenHAB Connector
needs to be source-downloaded. Then the README file on its repository says:
The preferred way of installing this module is via the "Z-Wave.Me App Store" available in 2.2.0 and higher.
My z-way panel at http : //RASPI_IP:8083/smarthome/#/admin says as following, so I assume it qualifies, but I don’t see “OpenHAB Connector” or anything similar on my Z-way apps page http : //RASPI_IP:8083/smarthome/#/apps/online:
Software info
Firmware version v2.3.4
UI version 1.7.0-RC-12
Built date 29-03-2017 15:36:36
Is getting it via source only available option with this situation?
Maybe let me tag @pathec the original developer of the binding.
Where OpenHAB runs:
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.2 LTS
Release: 16.04
Codename: xenial
$ apt-cache policy openhab2
openhab2:
Installed: 2.0.0-1
Candidate: 2.0.0-1
Version table:
*** 2.0.0-1 500
500 https://dl.bintray.com/openhab/apt-repo2 stable/main armhf Packages
100 /var/lib/dpkg/status
Thanks!
