Hi, i´m new to OH2 and used FHEM till now.
I use a Raspberry Pi with a CUL-USB-Stick. How can I use this stick to work with the Somfy-Binding?
Hi Peter,
the Somfy binding is supposed to be used with the official URTSI Serial Interface by Somfy. It cannot work with the CUL USB Stick, as the CUL has a very different driver interface.
There’s currently no support for controlling Somfy devices via CUL in OpenHAB - although of course it’s possible if you manage to write or adapt a binding for this. You’ll need Java programming experience for this, though.
best regards
Bernhard
Hi Peter,
I have a basic working binding for Somfy RTS via CUL.
Cheers
Daniel
see
Ok cool, very cool! How do you add The shutters to OpenHab when its not possible to program them?
I added the shutters as things via the paper UI and then hardcoded the current address and the initial rolling code in a property file. The values were obtained via two different ways:
Could you please give a detailed description how you did this? I´m using FHEM but i don´t like it. Would be great to be able to switch to OpenHAB. Depends from my Somfys working or not.
you mean the implementation or the current configuration based on the code?
I mean the implementation, how to implement your somfy solution.
Hi Daniel,
some time is gone, this weekend i´ll have time to play around with OH.
How can I implement your solution?
Thx, Peter
Hi Peter,
sorry I was off for a while. As the solution is not perfect (yet) the solution existed of two steps:
Rollershutter Shutter_Room "Room" {channel="somfycul:somfydevice:a59165d2:position"}Hope this helps
Cheers
Daniel
Hi together,
I have a basic question regarding this topic: If I own e.g. a CC1101-USB-Lite 868MHz and I have a Somfy remote for my sunblind/marquise, would it be possible to just use OH2.3 to control the sunblind/marquise using the approach described above? Or do I need something in addition?
For now I have just the option to use the Somfy remote control manually if I want to drive the blind. Thanks for clarification!
Cheers,
Ben
Hi Ben,
with a couple of new additions I have a solution running just with a OpenHAB 2.2 / 2.3 instance.
Therefore I adapted a couple of things in the github repo mentioned above, packaged the binding and put it into the Eclipse marketplace: https://marketplace.eclipse.org/content/somfy-rts-cul-binding
The installation worked for me as follows:
somfycul:culdevice:cul [ port="/dev/ttyACM0" ]
somfycul:somfydevice:esslinks (somfycul:culdevice:cul)
Switch Shutter_Ess_Links "Eßzimmer links" (somfyFF) {channel="somfycul:somfydevice:esslinks:program"}
Rollershutter Shutter_Ess_Links "Eßzimmer links" (somfyFF) {channel="somfycul:somfydevice:esslinks:position"}
This is how I set up all my rollershutters in my house now via a CUL.
Cheers
Daniel
Hi Daniel,
thanks a lot for the explanation. I’m quite excited to try it. However, first I have to get the Stick and then I’m going to test it and will report back here.
Cheers,
Ben
I tried to learn in my marquise, however it didn’t work yet. The CUL is known to openhab, I have also added things and item. From the log everything seems to be fine. Where I struggle is the actual learning process. If I hold the “my” key on the remote there is no reaction of the actuator. If I press the “reset” Button on the backside of the remote the marquise is responding with a short up/down as supposed to with the “my” Button, I guess. What I also read in the manual of the remote is that for learning new devices, the new remote should be less than 30cm away from the receiver. Is that a constraint which must be met? Any ideas, why the my button is not acting as supposed?
Thanks again!
Cheers,
Ben
Hi Ben,
could you post the output from the logs?
As far as I understood the problem seems currently not with the OpenHab learning but setting the shutter to learning mode?
The constraint with the 30cm of the new remote is definitely not a problem. E.g. my remote (CUL stick) is at least 8m away from the shutter (with a couple of walls in between).
Cheers
Daniel
Hi Daniel,
thanks for your reply. I guess it is no issue with openhab or the binding, it seems indeed to be a problem in setting the shutter to learning mode. However, here is the log output:
2018-03-02 22:27:43.791 [INFO ] [ing.somfycul.handler.SomfyCULHandler] - channelUID: somfycul:somfydevice:terrasseMarqu:program, command: ON
2018-03-02 22:27:43.794 [INFO ] [.binding.somfycul.handler.CulHandler] - Send message YsA1800006000001 for thing somfyDeviceLabel
2018-03-02 22:27:43.804 [vent.ItemStateChangedEvent] - Shutter_Terrasse changed from OFF to ON
2018-03-02 22:28:23.802 [INFO ] [ing.somfycul.handler.SomfyCULHandler] - channelUID: somfycul:somfydevice:terrasseMarqu:program, command: OFF
2018-03-02 22:28:23.806 [INFO ] [.binding.somfycul.handler.CulHandler] - Send message YsA1800007000001 for thing somfyDeviceLabel
2018-03-02 22:28:23.802 [ome.event.ItemCommandEvent] - Item ‘Shutter_Terrasse’ received command OFF
2018-03-02 22:28:23.816 [vent.ItemStateChangedEvent] - Shutter_Terrasse changed from ON to OFF
I think it is looking normal.
Nevertheless, I’m glad that the 30cm rule is not to be taken that serious, I rather wont dismount my RPi and carry it to the shutter. I’ll try again to set the shutter to learning mode tomorrow, hopefully with a little bit more luck.
Cheers,
Ben
Hi Ben,
the log looks the same as my log file. So a trigger of the ON/OFF Event for programming and then the appropriate programming command (8 in the message - culfw reference).
For reference I’m working with a Somfy Oximo 50 RTS motor and a Somfy Centralis RTS remote.
Cheers
Daniel
Hi Daniel,
it took some time to try again, but still I’m not successful. I tried different things in order to put the shutter into learning mode. I don’t no the motor type, but I have the Somfy Telis 1 RTS Pure as remote control. I tried various methods to put the system into learning mode:
Thanks again,
Ben
2018-03-10 09:46:52.079 [INFO ] [ing.somfycul.handler.SomfyCULHandler] - channelUID: somfycul:somfydevice:terrasseMarqu:program, command: ON
2018-03-10 09:46:52.085 [DEBUG] [ing.somfycul.handler.SomfyCULHandler] - rolling code before command 0028
2018-03-10 09:46:52.091 [INFO ] [.binding.somfycul.handler.CulHandler] - Send message YsA1800028000001 for thing somfyDeviceLabel
2018-03-10 09:46:52.097 [DEBUG] [.binding.somfycul.handler.CulHandler] - Trying to write ‘YsA1800028000001’ to serial port /dev/ttyUSB0
2018-03-10 09:46:52.134 [DEBUG] [ing.somfycul.handler.SomfyCULHandler] - Updated rolling code to 0029
2018-03-10 09:47:06.723 [INFO ] [ing.somfycul.handler.SomfyCULHandler] - channelUID: somfycul:somfydevice:terrasseMarqu:program, command: OFF
2018-03-10 09:47:06.735 [DEBUG] [ing.somfycul.handler.SomfyCULHandler] - rolling code before command 0029
2018-03-10 09:47:06.748 [INFO ] [.binding.somfycul.handler.CulHandler] - Send message YsA1800029000001 for thing somfyDeviceLabel
2018-03-10 09:47:06.752 [DEBUG] [.binding.somfycul.handler.CulHandler] - Trying to write ‘YsA1800029000001’ to serial port /dev/ttyUSB0
2018-03-10 09:47:06.772 [DEBUG] [ing.somfycul.handler.SomfyCULHandler] - Updated rolling code to 002A
2018-03-10 09:47:19.323 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model ‘somfy.items’
2018-03-10 09:47:19.435 [INFO ] [ing.somfycul.handler.SomfyCULHandler] - channelUID: somfycul:somfydevice:terrasseMarqu:program, command: REFRESH
2018-03-10 09:47:19.438 [.ItemChannelLinkAddedEvent] - Link ‘Shutter_Terrasse-somfycul:somfydevice:terrasseMarqu:program’ has been added.
2018-03-10 09:47:19.455 [temChannelLinkRemovedEvent] - Link ‘Shutter_Terrasse_learn => somfycul:somfydevice:terrasseMarqu:program’ has been removed.
2018-03-10 09:48:23.876 [INFO ] [ing.somfycul.handler.SomfyCULHandler] - channelUID: somfycul:somfydevice:terrasseMarqu:program, command: DOWN
2018-03-10 09:48:34.181 [INFO ] [ing.somfycul.handler.SomfyCULHandler] - channelUID: somfycul:somfydevice:terrasseMarqu:program, command: UP
2018-03-10 09:48:46.101 [INFO ] [ing.somfycul.handler.SomfyCULHandler] - channelUID: somfycul:somfydevice:terrasseMarqu:program, command: DOWN
Hi Ben,
the rear button seems to be the right solution.
A short up and down of the shutter confirms the setting to program mode (at least with my shutters). When I then press the switch with the bound programming item the shutter moves up and down again to confirm that it recognized the new remote.
Cheers
Daniel
Hi Daniel, hi all
I try to install my selfmade CUL (433 Hz) in order to control my somfy rollershutters (remote: Telis 6 Chronis S RTS).
First I cannot install the binding from the marktplace. I have understood how to do it, and with another binding it works bot not with yours. So I downloaded the .jar file and placed it in the addon folder and rebooted the pi (openhabianpi, RP3b+).
I configured all the way you mentioned on your post from Feb 20.
When I set the rollershutter in programming mode via the switch at the wall after unmounting the cover (which leads to the programming mode without the remote), it goes up and down. After that, I press the switch in my sitemap, but nothing happened.
Is the remote necessary for the procedure?
Is the hole thing installed like it is described in the post from Feb 20?
Can I use your binding in addition to the Intertechno binding with one cul (for a control of a plug; If I installed only the Intertechno binding, the plug is reacting on the signals )?
Here an example of my logs:
2018-04-10 15:52:24.131 [vent.ItemStateChangedEvent] - Shutter_Ess_Links changed from NULL to ON
2018-04-10 15:52:26.505 [ome.event.ItemCommandEvent] - Item ‘Shutter_Ess_Links’ received command OFF
2018-04-10 15:52:26.524 [vent.ItemStateChangedEvent] - Shutter_Ess_Links changed from ON to OFF
2018-04-10 15:52:26.527 [INFO ] [ing.somfycul.handler.SomfyCULHandler] - channelUID: somfycul:somfydevice:esslinks:program, command: OFF
2018-04-10 15:52:26.533 [INFO ] [.binding.somfycul.handler.CulHandler] - Send message YsA180000F000001 for thing somfyDeviceLabel
