I’ve tried Eclipse OpenHab designer on 2 computers, both macs.
On the first, the program is working, but I get tons of errors when editing rules that are obviously correct (run just fine in OpenHab).
On the 2nd, I get an error right on startup:
!SESSION 2016-11-05 17:04:44.969 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_91
java.vendor=Oracle Corporation
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Command-line arguments: -os macosx -ws cocoa -arch x86_64
!ENTRY org.eclipse.core.runtime 4 0 2016-11-05 17:04:50.819
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.core.runtime [2]
Unresolved requirement: Require-Bundle: javax.annotation; bundle-version="1.1.0"; visibility:="reexport"; resolution:="optional"
Unresolved requirement: Require-Bundle: javax.inject; bundle-version="1.0.0"; visibility:="reexport"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.equinox.common; bundle-version="[3.6.100,4.0.0)"; visibility:="reexport"
at org.eclipse.osgi.container.Module.start(Module.java:434)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
I’ve upgraded to the latest jvm
java version "1.8.0_91"
Java(TM) SE Runtime Environment (build 1.8.0_91-b14)
Java HotSpot(TM) 64-Bit Server VM (build 25.91-b14, mixed mode)
I am getting these problems with the stable and snapshot versions.
