Hi everyone,
I’m trying to run Openhab Designer on macOS Sierra but the only thing I get is a blank window (see below).
Then I get a fairly huge log file. Here’s a small sample, but it goes that way for a few hundred lines.
!SESSION 2017-01-17 23:04:29.484 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_112
java.vendor=Oracle Corporation
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_CA
Framework arguments: -keyring /Users/jeffreychausse/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -keyring /Users/jeffreychausse/.eclipse_keyring -showlocation
!ENTRY org.eclipse.update.configurator 4 0 2017-01-17 23:04:34.803
!MESSAGE Could not install bundle plugins/ch.qos.logback.classic_1.0.7.v20121108-1250.jar Bundle "ch.qos.logback.classic" version "1.0.7.v20121108-1250" has already been installed from: reference:file:plugins/ch.qos.logback.classic_1.0.7.v20121108-1250.jar
!ENTRY org.eclipse.update.configurator 4 0 2017-01-17 23:04:34.805
!MESSAGE Could not install bundle plugins/ch.qos.logback.core_1.0.7.v20121108-1250.jar Bundle "ch.qos.logback.core" version "1.0.7.v20121108-1250" has already been installed from: reference:file:plugins/ch.qos.logback.core_1.0.7.v20121108-1250.jar
!ENTRY org.eclipse.update.configurator 4 0 2017-01-17 23:04:34.807
!MESSAGE Could not install bundle plugins/ch.qos.logback.slf4j_1.0.7.v20121108-1250.jar Bundle "ch.qos.logback.slf4j" version "1.0.7.v20121108-1250" has already been installed from: reference:file:plugins/ch.qos.logback.slf4j_1.0.7.v20121108-1250.jar
I’ve tried updating Java to latest version without any success. I’ve also tried installing on Windows 10 but I get the same error with the same log file. Please note that I am NOT using Openhab2. I just need to control a single light for a demo, so I’m looking for the simplest way to achieve this.
java version "1.8.0_112"
Java(TM) SE Runtime Environment (build 1.8.0_112-b16)
Java HotSpot(TM) 64-Bit Server VM (build 25.112-b16, mixed mode)
Thank you for your help!
Jeffrey
