- Platform information:
- Hardware:
I5 3450 - Openhab running on Docker - 8Go RAM - OS: what OS is used and which version
Linux Debian - Java Runtime Environment: which java platform is used and what version
running in Container - openHAB version:
running OH 2.4 in container
- Hardware:
- Issue of the topic:
My openhab is running into a Container (it works perfectly) and I’ve now integrated Influx DB with Grafana, each of them in containers as well, everything is working smoothly.
My issues comes when I want to integrate via an Iframe the Grafana Diagrams.
I can easily setup the grafana system (running on port 3000 on the same machine, docker gives an easy way to manage this), but when I want to integrate the diagrams in the OH pages, and that’s where it’s stuck.
I do believe that the Openhab Container is not able to “see” the Grafana container (but maybe I’m wrong) which leads to a blak page in Basic UI.
When I load my URL to integrata (from Grafana) directly in a browser, it works perfectly, but when I want to integrate it into a webview in BasicUI, I just basically get… nothing.
Did you experienced the same ?
thanks,
Thierry.
