HI,
i have deployed an openHAB instance in Docker (https://hub.docker.com/r/openhab/openhab/), and started the openHAB Docker with parameter --net=host.
In logfile i have found that openhab found 4 Interfaces, and ingores 3 of them - but binds the Dahsboard to the wrong interface.
i allready tried to edit org.ops4j.pax.web.cfg in “userdata/etc”, but after restart nothing has changed in log file (org.ops4j.pax.web.listening.addresses = “ip address”)
is there another config or maybe a environment parameter i have to change to bind openHAB in Docker to a specific ip address?
I have exactly the same problem and tried to find out where I can set up the binding interface for the Dashboard.
I use the OpenHAB docker version 2.3.0-amd64-debian and the interface used is the docker bridge, which is un reachable from my desktop. Aka I can not connect to the Dashboard.
Here are the logs:
2018-10-28 10:18:09.714 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 192.168.10.3
2018-10-28 10:18:09.720 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 10.0.0.3
2018-10-28 10:18:12.717 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-10-28 10:18:13.351 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 192.168.10.3
2018-10-28 10:18:13.352 [WARN ] [g.eclipse.smarthome.core.net.NetUtil] - Found multiple local interfaces - ignoring 10.0.0.3
2018-10-28 10:18:13.363 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://172.17.0.1:8080
2018-10-28 10:18:13.364 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://172.17.0.1:8443
set OPENHAB_HTTPS_PORT=8448
set OPENHAB_HTTP_ADDRESS=127.0.0.1
After that OH only listen to ip-address 127.0.0.1 and HTTPS-port is changed to 8448. The log file tells, that more ip-addresses are found and only one is used. This message is wrong, but if I check it with netstat -a all went as exspected.
Having the same problem. Dashboard is always connecting to the wrong IP address. Changing network.config did not make a difference. Any more ideas how to fix this?
Without being able to bind OH to the correct network, the Docker implementation is pretty useless…
Has anyone found a fix for this?
Changing the network.config file doesnt do anything for me, the behaviour stays exactly the same.
Openhab is still ignoring 3 interfaces and choosing the wrong one
