Openhab Docker | Upgrade 3.2 to 3.3
A couple of weeks from now.
I have shut down the OH3.2 and also my both tests.
I have copied the openhab data to the test folder. I’ve started a new OH 3.4.0.M5 test. But the same… Update will not run… Binding are not able to download, again. Internet from inside the container is available.
$ docker exec -it oh33test /bin/bash
root@f2cf4162ecc3:/openhab# ping google.de
PING google.de (142.251.36.3) 56(84) bytes of data.
64 bytes from ams15s44-in-f3.1e100.net (142.251.36.3): icmp_seq=1 ttl=118 time=9.73 ms
64 bytes from ams15s44-in-f3.1e100.net (142.251.36.3): icmp_seq=2 ttl=118 time=9.39 ms
^C
--- google.de ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1002ms
rtt min/avg/max/mdev = 9.385/9.555/9.726/0.170 ms
==> openhab/userdata/logs/update.log <==
Replacing userdata system files with newer versions...
Clearing cache...
Performing post-update tasks for version 3.3.0:
Performing post-update tasks for version 3.4.0:
SUCCESS: openHAB updated from 3.2.0 to 3.4.0.M5
==> openhab/userdata/logs/openhab.log <==
2022-12-05 21:54:32.182 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-package-standard': Error:
	Error downloading mvn:org.eclipse.jetty.websocket/websocket-common/9.4.43.v20210629
	Error downloading mvn:org.eclipse.jetty.websocket/websocket-client/9.4.43.v20210629
	Error downloading mvn:org.eclipse.jetty/jetty-util/9.4.43.v20210629
	Error downloading mvn:org.eclipse.jetty.websocket/websocket-api/9.4.43.v20210629
	Error downloading mvn:org.eclipse.jetty/jetty-http/9.4.43.v20210629
	Error downloading mvn:org.eclipse.jetty/jetty-io/9.4.43.v20210629
	Error downloading mvn:org.eclipse.jetty/jetty-proxy/9.4.43.v20210629
	Error downloading mvn:org.eclipse.jetty/jetty-client/9.4.43.v20210629
2022-12-05 21:54:33.691 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-hue, openhab-binding-modbus, openhab-persistence-mapdb, openhab-binding-webthing, openhab-binding-amazondashbutton, openhab-misc-openhabcloud, openhab-binding-tplinksmarthome, openhab-transformation-javascript, openhab-persistence-influxdb, openhab-transformation-regex, openhab-ui-habpanel, openhab-transformation-jsonpath, openhab-automation-jsscripting, openhab-binding-shelly, openhab-binding-mqtt, openhab-persistence-rrd4j, openhab-transformation-map, openhab-ui-basic, openhab-binding-smartmeter, openhab-binding-astro, openhab-binding-telegram, openhab-transformation-jinja': Error:
2022-12-05 21:54:35.269 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed to refresh bundles after processing config update
org.apache.karaf.features.internal.util.MultiException: Error:
	at org.apache.karaf.features.internal.download.impl.MavenDownloadManager$MavenDownloader.<init>(MavenDownloadManager.java:91) ~[?:?]
	at org.apache.karaf.features.internal.download.impl.MavenDownloadManager.createDownloader(MavenDownloadManager.java:72) ~[?:?]
	at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:457) ~[?:?]
	at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:452) ~[?:?]
	at org.apache.karaf.features.internal.region.SubsystemResolver.resolve(SubsystemResolver.java:224) ~[?:?]
	at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:399) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1069) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:1004) ~[?:?]
	Suppressed: java.io.IOException: Error downloading mvn:org.eclipse.jetty.websocket/websocket-api/9.4.43.v20210629
		at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:77) ~[?:?]
		at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
	Caused by: java.io.IOException: Error resolving artifact org.eclipse.jetty.websocket:websocket-api:jar:9.4.43.v20210629: [Could not find artifact org.eclipse.jetty.websocket:websocket-api:jar:9.4.43.v20210629 in openhab (https://openhab.jfrog.io/openhab/libs-milestone/)]
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.configureIOException(AetherBasedResolver.java:803) ~[?:?]
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:774) ~[?:?]
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:657) ~[?:?]
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:598) ~[?:?]
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:565) ~[?:?]
		at org.apache.karaf.features.internal.download.impl.MavenDownloadTask.download(MavenDownloadTask.java:52) ~[?:?]
		at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:60) ~[?:?]
		... 6 more
		Suppressed: shaded.org.eclipse.aether.transfer.ArtifactNotFoundException: Could not find artifact org.eclipse.jetty.websocket:websocket-api:jar:9.4.43.v20210629 in openhab (https://openhab.jfrog.io/openhab/libs-milestone/)
			at shaded.org.eclipse.aether.connector.basic.ArtifactTransportListener.transferFailed(ArtifactTransportListener.java:48) ~[?:?]
			at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$TaskRunner.run(BasicRepositoryConnector.java:368) ~[?:?]
			at shaded.org.eclipse.aether.util.concurrency.RunnableErrorForwarder$1.run(RunnableErrorForwarder.java:75) ~[?:?]
			at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$DirectExecutor.execute(BasicRepositoryConnector.java:642) ~[?:?]
			at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector.get(BasicRepositoryConnector.java:262) ~[?:?]
			at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.performDownloads(DefaultArtifactResolver.java:489) ~[?:?]
			at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:390) ~[?:?]
			at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifacts(DefaultArtifactResolver.java:215) ~[?:?]
			at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifact(DefaultArtifactResolver.java:192) ~[?:?]
			at shaded.org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveArtifact(DefaultRepositorySystem.java:247) ~[?:?]
			at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:767) ~[?:?]
	Caused by: shaded.org.eclipse.aether.resolution.ArtifactResolutionException: Error resolving artifact org.eclipse.jetty.websocket:websocket-api:jar:9.4.43.v20210629
		at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:413) ~[?:?]
		... 6 more
Can you ping https://mvnrepository.com/? I think that’s where it’s trying to download from requirements some of your add-ons depend upon I think. Maybe there is something funky going on with your firewall, DNS, etc.
Yes. Ping is working …
root@f413dad7c239:/openhab# ping mvnrepository.com
PING mvnrepository.com (172.67.28.102) 56(84) bytes of data.
64 bytes from 172.67.28.102 (172.67.28.102): icmp_seq=1 ttl=55 time=7.24 ms
64 bytes from 172.67.28.102 (172.67.28.102): icmp_seq=2 ttl=55 time=7.13 ms
64 bytes from 172.67.28.102 (172.67.28.102): icmp_seq=3 ttl=55 time=7.46 ms
^C
--- mvnrepository.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 7.129/7.276/7.460/0.137 ms
I tried now another test … stopped all OH containers.
  • Copied current “oh” data to the test (3.4.0.M5) .
  • Added .kar file to the addons folder.
  • chown openhab.openhab to all files/folders.
The shit is going on… Should I remove some data in another folder, too?
Cache cleaning will be done by the upgrade script.
If I call this URL (JFrog [release] or JFrog [M5]) using a UI brower I need to login… If I use the mouse back button I can see the listing. But first I get the login screen. Can this be also a reason? Or is OH using a (public) key to prevent the login screen?
Only if the version reported in userdata/etc/versions.properties is different from the version in the image. In this case, since it’s the same version no upgrade occurs.
There’s an “x” in the upper right corner to close the login screen. Click that and you’ll get the file listing. I’m not sure why jFrog added that annoying login screen like that.
It’s all built into the web page. It won’t prevent OH from downloading.
And thus far you are the only one reporting anything like these sorts of problems so we have to assume there is something unique about your environment that is causing the problems.
Ok. Tried from inside the container to download a file directly… This was working … It the same filesize as I already put from outside to this path.
root@f413dad7c239:/openhab/addons# wget https://openhab.jfrog.io/artifactory/libs-milestone/org/openhab/distro/openhab-addons/3.4.0.M5/openhab-addons-3.4.0.M5.kar
--2022-12-05 22:52:36--  https://openhab.jfrog.io/artifactory/libs-milestone/org/openhab/distro/openhab-addons/3.4.0.M5/openhab-addons-3.4.0.M5.kar
Resolving openhab.jfrog.io (openhab.jfrog.io)... 34.139.10.89
Connecting to openhab.jfrog.io (openhab.jfrog.io)|34.139.10.89|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 371638583 (354M) [application/octet-stream]
Saving to: ‘openhab-addons-3.4.0.M5.kar.1’
openhab-addons-3.4.0.M5.kar.1                                      100%[================================================================================================================================================================>] 354.42M  14.8MB/s    in 25s
2022-12-05 22:53:01 (14.3 MB/s) - ‘openhab-addons-3.4.0.M5.kar.1’ saved [371638583/371638583]
root@f413dad7c239:/openhab/addons# ls -la
total 725880
drwxr-xr-x 2 openhab openhab      4096 Dec  5 22:52 .
drwxr-xr-x 1 openhab openhab      4096 Dec  5 22:50 ..
-rw-r--r-- 1 openhab openhab 371638583 Nov 27 18:46 openhab-addons-3.4.0.M5.kar
-rw-r--r-- 1 root    root    371638583 Nov 27 18:28 openhab-addons-3.4.0.M5.kar.1
I also restarted the container again. Maybe sometimes things happens after a 2nd start… But no success.
oh33test     | uuid' ']'
oh33test     | ++ cmp /openhab/userdata/etc/version.properties /openhab/dist/userdata/etc/version.properties
oh33test     | + '[' '!' -z ']'
oh33test     | + chown -R openhab:openhab /openhab
oh33test     | + sync
oh33test     | + '[' -d /etc/cont-init.d ']'
oh33test     | + sync
oh33test     | + '[' false == false ']'
oh33test     | ++ IFS=' '
oh33test     | ++ echo tini -s ./start.sh server
oh33test     | + '[' 'tini -s ./start.sh server' == 'gosu openhab tini -s ./start.sh' ']'
oh33test     | + exec tini -s ./start.sh server
oh33test     | Launching the openHAB runtime...
oh33test     | org.apache.karaf.features.internal.util.MultiException: Error:
oh33test     | 	Error downloading mvn:org.eclipse.jetty.websocket/websocket-api/9.4.43.v20210629
oh33test     | 	Error downloading mvn:org.eclipse.jetty/jetty-proxy/9.4.43.v20210629
oh33test     | 	Error downloading mvn:org.eclipse.jetty/jetty-http/9.4.43.v20210629
oh33test     | 	Error downloading mvn:org.eclipse.jetty/jetty-client/9.4.43.v20210629
oh33test     | 	Error downloading mvn:org.eclipse.jetty.websocket/websocket-common/9.4.43.v20210629
oh33test     | 	Error downloading mvn:org.eclipse.jetty/jetty-util/9.4.43.v20210629
oh33test     | 	Error downloading mvn:org.eclipse.jetty.websocket/websocket-client/9.4.43.v20210629
oh33test     | 	Error downloading mvn:org.eclipse.jetty/jetty-io/9.4.43.v20210629
oh33test     | 	at org.apache.karaf.features.internal.download.impl.MavenDownloadManager$MavenDownloader.<init>(MavenDownloadManager.java:91)
oh33test     | 	at org.apache.karaf.features.internal.download.impl.MavenDownloadManager.createDownloader(MavenDownloadManager.java:72)
oh33test     | 	at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:457)
oh33test     | 	at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:452)
oh33test     | 	at org.apache.karaf.features.internal.region.SubsystemResolver.resolve(SubsystemResolver.java:224)
oh33test     | 	at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:399)
oh33test     | 	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1069)
oh33test     | 	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:1004)
oh33test     | 	at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
oh33test     | 	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
oh33test     | 	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
oh33test     | 	at java.base/java.lang.Thread.run(Thread.java:829)
oh33test     | 	Suppressed: java.io.IOException: Error downloading mvn:org.eclipse.jetty.websocket/websocket-api/9.4.43.v20210629
oh33test     | 		at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:77)
oh33test     | 		at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
oh33test     | 		at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304)
oh33test     | 		... 3 more
oh33test     | 	Caused by: java.io.IOException: Error resolving artifact org.eclipse.jetty.websocket:websocket-api:jar:9.4.43.v20210629: [Could not find artifact org.eclipse.jetty.websocket:websocket-api:jar:9.4.43.v20210629 in openhab (https://openhab.jfrog.io/openhab/libs-milestone/)]
I’m totally confused …
So am I.
Hmmmm. I tried to go find that websoket-api library at jFrog and it’s not there! There’s a different version, 9.4.38.v20210224/.
This isn’t a Docker specific issue. And I have to believe some people are still installing 3.3 so it’s weird you are the only one having the problem.
My recommendation at this point is to reply on the OH 3.3 thread to see if maybe someone failed to add a library there sometime after the upgrade.
Then see what happens with the latest 3.4 milestone release (5 I think). If it works you can upgrade to 3.4 release in a couple of weeks with minimal effort as there won’t be that many changes to deal with for such a small jump.
Yeah. Maybe there is something specific at my end I don’t know …
Is there a way to can export all data?
If yes, I’d import this to a new docker container. Yes. That makes so sense… But in case there is something historic in the background it will gone away …
Do you mean a specific thread?
btw … Last test was made with 3.4.0.M5 … But results in the same issue as 3.3.0.
All the data is stored in conf and userdata. You already have both of those folders so you already have all the data.
If it’s still happening with 3.4, use this thread.
Short Update. I’m now using OH3.4 without main issues during the migration.
