- Platform information:
- Hardware: Rasberry arm64v8
- OS: raspian / debian
- openHAB version: 3.0.0 Snapshot #2050
- Issue of the topic: openHAB does not launch with host volume binding.
When creating volumes within the docker volume, openHAB works fine and stores the configurations persistently. But as soon as I try to map or bind to /opt/openhab/ /with my non-docker openHAB config added) on the host machine for better backup accessibility (see second screenshot) the installation crashes (see log below).
- Please post configurations (if applicable): see screenshot
2020-12-09T13:47:47.800044016Z logs,
2020-12-09T13:47:47.800065349Z mqttembedded.bin,
2020-12-09T13:47:47.800086682Z openhabcloud,
2020-12-09T13:47:47.800107626Z persistence,
2020-12-09T13:47:47.800128626Z secrets,
2020-12-09T13:47:47.800149515Z tmp,
2020-12-09T13:47:47.800170533Z uuid,
2020-12-09T13:47:47.800191755Z zwave' ']',
2020-12-09T13:47:47.800926743Z ++ cmp /openhab/userdata/etc/version.properties /openhab/dist/userdata/etc/version.properties,
2020-12-09T13:47:47.803053025Z cmp: /openhab/userdata/etc/version.properties: No such file or directory,
2020-12-09T13:47:47.803389650Z + '[' '!' -z ']',
2020-12-09T13:47:47.803555647Z + chown -R openhab:openhab /openhab,
2020-12-09T13:47:50.282688275Z + sync,
2020-12-09T13:47:50.311296983Z + '[' -d /etc/cont-init.d ']',
2020-12-09T13:47:50.311408370Z + sync,
2020-12-09T13:47:50.319624614Z + '[' false == false ']',
2020-12-09T13:47:50.320348010Z ++ IFS=' ',
2020-12-09T13:47:50.320446786Z ++ echo gosu openhab tini -s ./start.sh,
2020-12-09T13:47:50.320954927Z + '[' 'gosu openhab tini -s ./start.sh' == 'gosu openhab tini -s ./start.sh' ']',
2020-12-09T13:47:50.320999019Z + command=($@ server),
2020-12-09T13:47:50.321063592Z + exec gosu openhab tini -s ./start.sh server,
2020-12-09T13:47:50.327880246Z Launching the openHAB runtime...,
2020-12-09T13:47:51.519917043Z null,
2020-12-09T13:47:51.527233468Z Error occurred shutting down framework: java.lang.NumberFormatException: null,
2020-12-09T13:47:51.527696609Z java.lang.NumberFormatException: null,
2020-12-09T13:47:51.528651427Z at java.base/java.lang.Integer.parseInt(Integer.java:614),
2020-12-09T13:47:51.528723056Z at java.base/java.lang.Integer.parseInt(Integer.java:770),
2020-12-09T13:47:51.528853276Z at org.apache.karaf.main.ConfigProperties.<init>(ConfigProperties.java:235),
2020-12-09T13:47:51.528932071Z at org.apache.karaf.main.Main.updateInstancePidAfterShutdown(Main.java:227),
2020-12-09T13:47:51.529032144Z at org.apache.karaf.main.Main.main(Main.java:192),
2020-12-09T14:06:53.003190295Z ++ test -t 0,
2020-12-09T14:06:53.003285236Z ++ echo false,
2020-12-09T14:06:53.005227314Z + interactive=false,
2020-12-09T14:06:53.005388012Z + set -euo pipefail,
2020-12-09T14:06:53.005432548Z + IFS=',
2020-12-09T14:06:53.005458695Z ',
2020-12-09T14:06:53.005546858Z + '[' limited = unlimited ']',
2020-12-09T14:06:53.005648540Z + rm -f /openhab/runtime/instances/instance.properties,
2020-12-09T14:06:53.008923792Z + rm -f /openhab/userdata/tmp/instances/instance.properties,
2020-12-09T14:06:53.012033606Z + NEW_USER_ID=9001,
2020-12-09T14:06:53.012125325Z + NEW_GROUP_ID=9001,
2020-12-09T14:06:53.012151379Z + echo 'Starting with openhab user id: 9001 and group id: 9001',
2020-12-09T14:06:53.012089011Z Starting with openhab user id: 9001 and group id: 9001,
2020-12-09T14:06:53.012345280Z + id -u openhab,
2020-12-09T14:06:53.017090183Z + initialize_volume /openhab/conf /openhab/dist/conf,
2020-12-09T14:06:53.017174587Z + volume=/openhab/conf,
2020-12-09T14:06:53.017298972Z + source=/openhab/dist/conf,
2020-12-09T14:06:53.017789917Z ++ ls -A /openhab/conf,
2020-12-09T14:06:53.021382010Z + '[' -z 'html,
2020-12-09T14:06:53.021479191Z icons,
2020-12-09T14:06:53.021503061Z items,
2020-12-09T14:06:53.021525042Z misc,
2020-12-09T14:06:53.021546985Z persistence,
2020-12-09T14:06:53.021568299Z rules,
2020-12-09T14:06:53.021589576Z scripts,
2020-12-09T14:06:53.021610539Z services,
2020-12-09T14:06:53.021631686Z sitemaps,
2020-12-09T14:06:53.021652556Z sounds,
2020-12-09T14:06:53.021673851Z things,
2020-12-09T14:06:53.021695387Z transform' ']',
2020-12-09T14:06:53.021829901Z + initialize_volume /openhab/userdata /openhab/dist/userdata,
2020-12-09T14:06:53.021863085Z + volume=/openhab/userdata,
2020-12-09T14:06:53.021885158Z + source=/openhab/dist/userdata,
2020-12-09T14:06:53.022157482Z ++ ls -A /openhab/userdata,
2020-12-09T14:06:53.025514676Z + '[' -z 'backup,
2020-12-09T14:06:53.025587765Z backup.properties,
2020-12-09T14:06:53.025610024Z config,
2020-12-09T14:06:53.025631005Z etc,
2020-12-09T14:06:53.025651948Z hs_err_pid524.log,
2020-12-09T14:06:53.025672948Z jsondb,
2020-12-09T14:06:53.025693817Z logs,
2020-12-09T14:06:53.025714557Z mqttembedded.bin,
2020-12-09T14:06:53.025735371Z openhabcloud,
2020-12-09T14:06:53.025756408Z persistence,
2020-12-09T14:06:53.025777296Z secrets,
2020-12-09T14:06:53.025798054Z tmp,
2020-12-09T14:06:53.025818831Z uuid,
2020-12-09T14:06:53.025839553Z zwave' ']',
2020-12-09T14:06:53.026919217Z ++ cmp /openhab/userdata/etc/version.properties /openhab/dist/userdata/etc/version.properties,
2020-12-09T14:06:53.029370666Z cmp: /openhab/userdata/etc/version.properties: No such file or directory,
2020-12-09T14:06:53.029680433Z + '[' '!' -z ']',
2020-12-09T14:06:53.029857963Z + chown -R openhab:openhab /openhab,
2020-12-09T14:06:53.152170591Z + sync,
2020-12-09T14:06:53.179420720Z + '[' -d /etc/cont-init.d ']',
2020-12-09T14:06:53.179678174Z + sync,
2020-12-09T14:06:53.194581044Z + '[' false == false ']',
2020-12-09T14:06:53.194793721Z ++ IFS=' ',
2020-12-09T14:06:53.194829479Z ++ echo gosu openhab tini -s ./start.sh,
2020-12-09T14:06:53.195534158Z + '[' 'gosu openhab tini -s ./start.sh' == 'gosu openhab tini -s ./start.sh' ']',
2020-12-09T14:06:53.195705299Z + command=($@ server),
2020-12-09T14:06:53.195742854Z + exec gosu openhab tini -s ./start.sh server,
2020-12-09T14:06:53.204589998Z Launching the openHAB runtime...,
2020-12-09T14:06:54.367546548Z null,
2020-12-09T14:06:54.374824471Z Error occurred shutting down framework: java.lang.NumberFormatException: null,
2020-12-09T14:06:54.375543093Z java.lang.NumberFormatException: null,
2020-12-09T14:06:54.376626388Z at java.base/java.lang.Integer.parseInt(Integer.java:614),
2020-12-09T14:06:54.376874212Z at java.base/java.lang.Integer.parseInt(Integer.java:770),
2020-12-09T14:06:54.378052873Z at org.apache.karaf.main.ConfigProperties.<init>(ConfigProperties.java:235),
2020-12-09T14:06:54.378385269Z at org.apache.karaf.main.Main.updateInstancePidAfterShutdown(Main.java:227),
2020-12-09T14:06:54.380286256Z at org.apache.karaf.main.Main.main(Main.java:192),
If I change the mapped volume to /home/pi/openhab - everything works fine. There must be something wrong specifically with /opt/openhab - as I am more than sure that it has the appropriate permissions.
'/openhab/dist/conf/./icons/classic' -> '/openhab/conf/./icons/classic'
'/openhab/dist/conf/./icons/classic/readme.txt' -> '/openhab/conf/./icons/classic/readme.txt'
'/openhab/dist/conf/./items' -> '/openhab/conf/./items'
'/openhab/dist/conf/./items/readme.txt' -> '/openhab/conf/./items/readme.txt'
'/openhab/dist/conf/./persistence' -> '/openhab/conf/./persistence'
'/openhab/dist/conf/./persistence/readme.txt' -> '/openhab/conf/./persistence/readme.txt'
'/openhab/dist/conf/./rules' -> '/openhab/conf/./rules'
'/openhab/dist/conf/./rules/readme.txt' -> '/openhab/conf/./rules/readme.txt'
'/openhab/dist/conf/./scripts' -> '/openhab/conf/./scripts'
'/openhab/dist/conf/./scripts/readme.txt' -> '/openhab/conf/./scripts/readme.txt'
'/openhab/dist/conf/./services' -> '/openhab/conf/./services'
'/openhab/dist/conf/./services/addons.cfg' -> '/openhab/conf/./services/addons.cfg'
'/openhab/dist/conf/./services/readme.txt' -> '/openhab/conf/./services/readme.txt'
'/openhab/dist/conf/./services/runtime.cfg' -> '/openhab/conf/./services/runtime.cfg'
'/openhab/dist/conf/./sitemaps' -> '/openhab/conf/./sitemaps'
'/openhab/dist/conf/./sitemaps/readme.txt' -> '/openhab/conf/./sitemaps/readme.txt'
'/openhab/dist/conf/./sounds' -> '/openhab/conf/./sounds'
'/openhab/dist/conf/./sounds/barking.mp3' -> '/openhab/conf/./sounds/barking.mp3'
'/openhab/dist/conf/./sounds/doorbell.mp3' -> '/openhab/conf/./sounds/doorbell.mp3'
'/openhab/dist/conf/./things' -> '/openhab/conf/./things'
'/openhab/dist/conf/./things/readme.txt' -> '/openhab/conf/./things/readme.txt'
'/openhab/dist/conf/./transform' -> '/openhab/conf/./transform'
'/openhab/dist/conf/./transform/de.map' -> '/openhab/conf/./transform/de.map'
'/openhab/dist/conf/./transform/en.map' -> '/openhab/conf/./transform/en.map'
'/openhab/dist/conf/./transform/readme.txt' -> '/openhab/conf/./transform/readme.txt'
+ '[' -z '' ']'
+ echo 'Initializing empty volume /openhab/userdata ...'
+ cp -av /openhab/dist/userdata/. /openhab/userdata/
'/openhab/dist/userdata/./etc' -> '/openhab/userdata/./etc'
'/openhab/dist/userdata/./etc/all.policy' -> '/openhab/userdata/./etc/all.policy'
'/openhab/dist/userdata/./etc/branding-ssh.properties' -> '/openhab/userdata/./etc/branding-ssh.properties'
'/openhab/dist/userdata/./etc/branding.properties' -> '/openhab/userdata/./etc/branding.properties'
'/openhab/dist/userdata/./etc/config.properties' -> '/openhab/userdata/./etc/config.properties'
'/openhab/dist/userdata/./etc/custom.properties' -> '/openhab/userdata/./etc/custom.properties'
'/openhab/dist/userdata/./etc/custom.system.properties' -> '/openhab/userdata/./etc/custom.system.properties'
'/openhab/dist/userdata/./etc/distribution.info' -> '/openhab/userdata/./etc/distribution.info'
'/openhab/dist/userdata/./etc/equinox-debug.properties' -> '/openhab/userdata/./etc/equinox-debug.properties'
'/openhab/dist/userdata/./etc/java.util.logging.properties' -> '/openhab/userdata/./etc/java.util.logging.properties'
'/openhab/dist/userdata/./etc/jmx.acl.org.apache.karaf.bundle.cfg' -> '/openhab/userdata/./etc/jmx.acl.org.apache.karaf.bundle.cfg'
'/openhab/dist/userdata/./etc/jmx.acl.org.apache.karaf.config.cfg' -> '/openhab/userdata/./etc/jmx.acl.org.apache.karaf.config.cfg'
'/openhab/dist/userdata/./etc/jre.properties' -> '/openhab/userdata/./etc/jre.properties'
'/openhab/dist/userdata/./etc/keys.properties' -> '/openhab/userdata/./etc/keys.properties'
'/openhab/dist/userdata/./etc/keystore' -> '/openhab/userdata/./etc/keystore'
'/openhab/dist/userdata/./etc/log4j2.xml' -> '/openhab/userdata/./etc/log4j2.xml'
'/openhab/dist/userdata/./etc/org.apache.aries.jax.rs.whiteboard.default.cfg' -> '/openhab/userdata/./etc/org.apache.aries.jax.rs.whiteboard.default.cfg'
'/openhab/dist/userdata/./etc/org.apache.felix.eventadmin.impl.EventAdmin.cfg' -> '/openhab/userdata/./etc/org.apache.felix.eventadmin.impl.EventAdmin.cfg'
'/openhab/dist/userdata/./etc/org.apache.felix.fileinstall-deploy.cfg' -> '/openhab/userdata/./etc/org.apache.felix.fileinstall-deploy.cfg'
'/openhab/dist/userdata/./etc/org.apache.karaf.command.acl.bundle.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.command.acl.bundle.cfg'
'/openhab/dist/userdata/./etc/org.apache.karaf.command.acl.config.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.command.acl.config.cfg'
'/openhab/dist/userdata/./etc/org.apache.karaf.command.acl.feature.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.command.acl.feature.cfg'
'/openhab/dist/userdata/./etc/org.apache.karaf.command.acl.jaas.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.command.acl.jaas.cfg'
'/openhab/dist/userdata/./etc/org.apache.karaf.command.acl.kar.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.command.acl.kar.cfg'
'/openhab/dist/userdata/./etc/org.apache.karaf.command.acl.scope_bundle.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.command.acl.scope_bundle.cfg'
'/openhab/dist/userdata/./etc/org.apache.karaf.command.acl.shell.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.command.acl.shell.cfg'
'/openhab/dist/userdata/./etc/org.apache.karaf.command.acl.system.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.command.acl.system.cfg'
'/openhab/dist/userdata/./etc/org.apache.karaf.features.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.features.cfg'
'/openhab/dist/userdata/./etc/org.apache.karaf.features.repos.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.features.repos.cfg'
'/openhab/dist/userdata/./etc/org.apache.karaf.features.xml' -> '/openhab/userdata/./etc/org.apache.karaf.features.xml'
'/openhab/dist/userdata/./etc/org.apache.karaf.jaas.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.jaas.cfg'
'/openhab/dist/userdata/./etc/org.apache.karaf.kar.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.kar.cfg'
'/openhab/dist/userdata/./etc/org.apache.karaf.log.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.log.cfg'
'/openhab/dist/userdata/./etc/org.apache.karaf.shell.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.shell.cfg'
'/openhab/dist/userdata/./etc/org.jupnp.cfg' -> '/openhab/userdata/./etc/org.jupnp.cfg'
'/openhab/dist/userdata/./etc/org.openhab.audio.cfg' -> '/openhab/userdata/./etc/org.openhab.audio.cfg'
'/openhab/dist/userdata/./etc/org.openhab.voice.cfg' -> '/openhab/userdata/./etc/org.openhab.voice.cfg'
'/openhab/dist/userdata/./etc/org.ops4j.pax.logging.cfg' -> '/openhab/userdata/./etc/org.ops4j.pax.logging.cfg'
'/openhab/dist/userdata/./etc/org.ops4j.pax.url.mvn.cfg' -> '/openhab/userdata/./etc/org.ops4j.pax.url.mvn.cfg'
'/openhab/dist/userdata/./etc/org.ops4j.pax.web.cfg' -> '/openhab/userdata/./etc/org.ops4j.pax.web.cfg'
'/openhab/dist/userdata/./etc/overrides.properties' -> '/openhab/userdata/./etc/overrides.properties'
'/openhab/dist/userdata/./etc/profile.cfg' -> '/openhab/userdata/./etc/profile.cfg'
'/openhab/dist/userdata/./etc/scripts' -> '/openhab/userdata/./etc/scripts'
'/openhab/dist/userdata/./etc/scripts/shell.colors.script' -> '/openhab/userdata/./etc/scripts/shell.colors.script'
'/openhab/dist/userdata/./etc/scripts/shell.completion.script' -> '/openhab/userdata/./etc/scripts/shell.completion.script'
'/openhab/dist/userdata/./etc/shell.init.script' -> '/openhab/userdata/./etc/shell.init.script'
'/openhab/dist/userdata/./etc/startup.properties' -> '/openhab/userdata/./etc/startup.properties'
'/openhab/dist/userdata/./etc/system.properties' -> '/openhab/userdata/./etc/system.properties'
'/openhab/dist/userdata/./etc/users.properties' -> '/openhab/userdata/./etc/users.properties'
'/openhab/dist/userdata/./etc/version.properties' -> '/openhab/userdata/./etc/version.properties'
'/openhab/dist/userdata/./logs' -> '/openhab/userdata/./logs'
'/openhab/dist/userdata/./logs/openhab.log' -> '/openhab/userdata/./logs/openhab.log'
'/openhab/dist/userdata/./tmp' -> '/openhab/userdata/./tmp'
'/openhab/dist/userdata/./tmp/README' -> '/openhab/userdata/./tmp/README'
+ '[' '!' -z ']'
+ sync
++ IFS=' '
