I’m using an RPi 4 with Openhab 3.4.1 on it. No changes done on system level for a long time.
Yesterday I changed some Item configs and rebooted the RPi. OpenHab didn’t startup any more. If I start Openhab manually after a reboot, it gives me a Transport error, saying (probably) that the port is already in use.
And if I than try to stop Openhab via the cli interface, it gives me these messages:
openhabian@openHABianDevice:~ $ sudo openhab-cli stop
A systemd service configuration exists…
Use ‘sudo /bin/systemctl stop openhab.service’ to stop an openHAB service
Stopping any instance of openHAB…
/usr/share/openhab/runtime/bin/karaf: 115: [: Illegal number:
Exception in thread “main” java.lang.NumberFormatException: null
at java.base/java.lang.Integer.parseInt(Integer.java:614)
at java.base/java.lang.Integer.parseInt(Integer.java:770)
at org.apache.karaf.main.Stop.getPortFromShutdownPortFile(Stop.java:83)
at org.apache.karaf.main.Stop.main(Stop.java:47)
any ideas???
many thanks,
emiel
