Could you please format your post like you did here
Did you try to execute the command as user openhabian as explained?
This is a crucial step to make sure openhab is able to execute the command! Make sure to take the right user openhab for self installed, openhabian for openhabian.
Make sure to add openhab/openhabian to the group which is necessary to execute your commands. Most probably gpio. I don’t know what kind off 433MHz transciever you use.
Second you don’t need the shell Skript. Put your call to codesend in the thing as explained above in the tutorial. Have a closer look there.
Please post the output of
- Executions as user openhabian from commandline.
- After adding openhabian to the right group and successful executing 1. the output of the log from the rule.
