openHAB - Filtering event logs
Ultimately, I think the root cause is the fact that Rules DSL Rules are not thread safe (a problem that doesn’t exist in Scripted Automation) so my recommendation for the fix would be to rewrite the Rule in Scripted Automation, probably Python at this point.
When/if you do, you might consider using Item Metadata instead of Groups which might give you a bit more control over how the Rule triggers which in turn will simplify the code itself. See Jython Drop-in Replacement for Expire 1.x Binding for an example of doing just that to replace the Expire binding using Rules.
