openHAB Google Assistant Integration v2.0
@michikrug
I´m not sure if this is a openhab issue or Google issue or perhaps a mix. But something is wrong somewhere. And I dont see others mentioning the same issue. But…
I´ll try explain as clear as I can… Hold tight, cause it is quite confusing.
Google Home app on my iphone no longer recognize my IHC dimmers lights, which are tag´d through openhab. The app see the light as simple on/off. (no cogwheel to change the dimming).
But…
Google Home app on my Android phone my IHC dimmers works fine. There is a cogwheel and dimmer works fine…
This could sound like a GH app failer on the iphone, right?
But…
Google Home app on my iphone works fine with my Philips Hue lights (with dimmer/cogwheel)…
Differences:
Hue is directly connected to Google Home via the app services…
IHC dimmers are connected through openhab service.
Then I´m no longer sure if this is really a iphone app issue anymore… Sounds very odd…
It gets more strange…
On my Google Nest Hub:
Hue lights works fine (dimmer and cogwheel). But all my IHC dimmers do not work at all. The Nest Hub tries to connect to the dimmer, but returns back to main screen.
And just to make things even worse:
Using voice control works fine, both controlling, turn on/off or dimming IHC dimmers. So it may seem it´s a visual problem in the iphone app and the Google Nest Hub.
:astonished:
This is how I have tagged my IHC dimmers. They have worked just fine for several months, just untill you made the lasted update.
Dimmer    stort_badDimmerLys    "Loftlys i Stort Bad [%.0f %%]"      <cu_spot>     (vLys)       [ "Lighting" ]     { channel="ihc:controller:elko:stortbad_dimmer", autoupdate="false" }
