OpenHab Guru Chatbot
Recently I discovered something that has been a major game changer for me using Opehab. I have a decent background on coding and understand logic well but sometimes I get stuck on code and need some help. I used to fall back and rely on forums like this one. The OpenHab community has been awesome! But often times I have limited time to work on projects and need an answer right away.
In my day job, I discovered and use ChatGPT on a regular basis. After reigniting an old project I had been working on, I decided to have Chat help me with OpenHab. Undenounced to me, I discovered that Chat has a custom Chatbot called OpenHab Guru.
OpenHab Guru is fantastic! You can have it help you figure out just about any issues in OpenHab. I have used it to design and create an OpenHab panel to control a passive solar hot water heater and help with perfecting the algorithm used for controlling my pump relay and tracking temperatures over time.
I would highly recommend using ChatGPT and OpenHab Guru if you need help designing your next project. I will warn you that there is a bit of trial and error with this, but if you are patient, it is very worth the effort.
Cheers!
A quick google did not reveal anything specific. A fully trained OpenHAB AI would be great
had another experience with OpenHab Guru, I was having a problem where a persistant write with a specific timestamp didn’t work every now and than. Nothing I could figure out worked, so called the Guru for help. The second answer did the trick, in only 5 minutes and the solution was to not have a default datetime stamp in the sql database, so not even OH’s problem. Guru is absolutely one of my best personal AI friends :star_struck:.
I started using Grok two months ago, which has so far nailed every OH query. :slight_smile:
Grok has outperformed any other AI I have tested.
I am going through my all my controller code (some 70 projects) with Grok. The collaboration has been awesome, as it does not hold back identifying issues and improvements.
I’ll have to check Grok out. Openhab Guru is about 80% accurate.
I do have the paid version of ChatGPT and use it daily with my work. You can find the guru under Explore GPTs.
