I have a door sensor and an alarm integrated in Homegear. When directly connected to homegear, I can trigger the alarm with homegear -e rc '$hg->setValue(0x40000013, 1, "STATE", true);'
On the homegear board I also found the info “Of course you can call “setValue” over RPC, too.”
Now I am wondering how to do that in OpenHab; where and how would I enter that command?
I have already created a switch item as a thing in the Eclipse Smarthome Designer with “parameter=STATE” for the alarm and integrated it in the sitemap. Just moving the slider doesnt do anything. Can you guys help out?
As far as I know it is currently not possible to trigger the alarm in openHAB. The reason ist that the CCU does not support it (at least for the HM-SEC-SCo). Therefore it has not been implemented yet.
@gerrieg What do you think about it? Does it make sens to implement this function but only if Homegear is used?
First assumption was, that it’s not possible as well, but as I tested, the CCU (Raspberry Pi3 with hm-mod-rpi-pcb-board from ELV) can trigger the alarm - in the homegear terminal at least.
EDIT: It’s working now. When I added the fire alarm to homegear, it automatically created a fire alarm group, as here is the result excerpt:
ID │ Name │ Address │ Serial Number │ Type │ Type String │ Firmware │ Config Pending │ Unreach │ Low Bat
1 │ Door_Entrance │ 58BA29 │ OEQ0392086 │ 00C7 │ HM-Sec-SCo │ 1.0 │ No │ No │ No
2 │ Alarm_Entrance │ 4C724C │ NEQ0443157 │ 00AA │ HM-Sec-SD-2 │ 1.0 │ No │ No │ No
0x40000002 │ │ 4C724C │ *NEQ0443157 │ 00AA │ HM-Sec-SD-2-Team │ ? │ No │ No │ No
Now that I added the device in Habmin, it shows up in PaperUI:
Using the “State” button in PaperUI I can trigger the alarm. I configured the thing as Switch Alarm_Test_1 "Alarm_Test_1" <fire> { channel="homematic:HG-HM-Sec-SD-2-Team:HMCFGUSB2:T-NEQ0443157:1#STATE" }
Hitting the Button in the Sitemap now triggers the alarm and also stops it.
