2019-12-20 10:41:01.707 [ERROR] [b.core.service.AbstractActiveService] - Error while executing background thread HTTP Refresh Service
java.util.UnknownFormatConversionException: Conversion = '2'
at java.util.Formatter.checkText(Formatter.java:2579) ~[?:1.8.0_222]
at java.util.Formatter.parse(Formatter.java:2565) ~[?:1.8.0_222]
at java.util.Formatter.format(Formatter.java:2501) ~[?:1.8.0_222]
at java.util.Formatter.format(Formatter.java:2455) ~[?:1.8.0_222]
at java.lang.String.format(String.java:2940) ~[?:1.8.0_222]
at org.openhab.binding.http.internal.HttpBinding.execute(HttpBinding.java:148) ~[?:?]
at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:146) ~[bundleFile:?]
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:169) [bundleFile:?]
2019-12-20 22:03:04.234 [ERROR] [b.core.service.AbstractActiveService] - Error while executing background thread HTTP Refresh Service
This is caused by +%26+ in the URL, which represents the escaped & character in URLs. The String.format method doesn’t like that since % has a special meaning for that method.
btw: You should edit your last post if the addresses are non fictional.
Bottom line: Just remove the mentioned part in the URL, your destination will be found by google maps anyway.
2019-12-22 14:36:16.088 [ERROR] [b.core.service.AbstractActiveService] - Error while executing background thread HTTP Refresh Service
java.lang.IllegalArgumentException: Invalid uri 'https://maps.googleapis.com/maps/api/distancematrix/json?origins=XXXXXXXXXX+4,+14558+Nuthetal&destinations=XXXXXXX,+XXXXXXXXXXXX,+Berlin&language=DE&departure_time=now&traffic_model=best_guess&mode=driving&key=XXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXX': Invalid query
at org.apache.commons.httpclient.HttpMethodBase.<init>(HttpMethodBase.java:222) ~[bundleFile:?]
at org.apache.commons.httpclient.methods.GetMethod.<init>(GetMethod.java:89) ~[bundleFile:?]
at org.openhab.io.net.http.HttpUtil.createHttpMethod(HttpUtil.java:303) ~[bundleFile:?]
at org.openhab.io.net.http.HttpUtil.executeUrl(HttpUtil.java:164) ~[bundleFile:?]
at org.openhab.io.net.http.HttpUtil.executeUrl(HttpUtil.java:129) ~[bundleFile:?]
at org.openhab.binding.http.internal.HttpBinding.execute(HttpBinding.java:176) ~[?:?]
