I’m trying to run the official openHAB 2.4 Docker Image in a Linux container in Docker on Windows 10. The container itself starts, creates all the files in the mounted volumes, but hangs at Launching the openHAB runtime...
I tried this on 2 different Windows 10 machines and even waited for hours.
This is my docker-compose.yml
openhab:
container_name: "openhab"
image: "openhab/openhab:2.4.0"
restart: always
network_mode: host
volumes:
- "./openhab/addons:/openhab/addons"
- "./openhab/conf:/openhab/conf"
- "./openhab/userdata:/openhab/userdata"
environment:
OPENHAB_HTTP_PORT: "8080"
OPENHAB_HTTPS_PORT: "8443"
EXTRA_JAVA_OPTS: "-Duser.timezone=Europe/Berlin"
Here is the log from Docker:
++ test -t 0
++ echo false
+ interactive=false
+ set -euo pipefail
+ IFS='
+ '[' limited = unlimited ']'
+ rm -f /openhab/runtime/instances/instance.properties
+ rm -f /openhab/userdata/tmp/instances/instance.properties
+ NEW_USER_ID=9001
+ NEW_GROUP_ID=9001
+ echo 'Starting with openhab user id: 9001 and group id: 9001'
+ id -u openhab
++ getent group 9001
+ '[' -z '' ']'
+ echo 'Create group openhab with id 9001'
+ groupadd -g 9001 openhab
+ echo 'Create user openhab with id 9001'
+ adduser -u 9001 --disabled-password --gecos '' --home /openhab --gid 9001 openhab
Warning: The home dir /openhab you specified already exists.
Adding user `openhab' ...
Adding new user `openhab' (9001) with group `openhab' ...
adduser: Warning: The home directory `/openhab' does not belong to the user you are currently creating.
The home directory `/openhab' already exists. Not copying from `/etc/skel'.
+ groupadd -g 14 uucp2
+ groupadd -g 16 dialout2
+ groupadd -g 18 dialout3
+ groupadd -g 32 uucp3
+ groupadd -g 997 gpio
+ adduser openhab dialout
Adding user `openhab' to group `dialout' ...
Adding user openhab to group dialout
Done.
+ adduser openhab uucp
Adding user `openhab' to group `uucp' ...
Adding user openhab to group uucp
Done.
+ adduser openhab uucp2
Adding user `openhab' to group `uucp2' ...
Adding user openhab to group uucp2
Done.
+ adduser openhab dialout2
Adding user `openhab' to group `dialout2' ...
Adding user openhab to group dialout2
Done.
+ adduser openhab dialout3
Adding user `openhab' to group `dialout3' ...
Adding user openhab to group dialout3
Done.
+ adduser openhab uucp3
Adding user `openhab' to group `uucp3' ...
Adding user openhab to group uucp3
Done.
+ adduser openhab gpio
Adding user `openhab' to group `gpio' ...
Adding user openhab to group gpio
Done.
+ case ${OPENHAB_VERSION} in
++ ls -A /openhab/userdata
+ '[' -z '' ']'
+ echo 'No userdata found... initializing.'
+ cp -av /openhab/userdata.dist/. /openhab/userdata/
'/openhab/userdata.dist/./etc' -> '/openhab/userdata/./etc'
'/openhab/userdata.dist/./etc/all.policy' -> '/openhab/userdata/./etc/all.policy'
'/openhab/userdata.dist/./etc/branding-ssh.properties' -> '/openhab/userdata/./etc/branding-ssh.properties'
'/openhab/userdata.dist/./etc/branding.properties' -> '/openhab/userdata/./etc/branding.properties'
'/openhab/userdata.dist/./etc/com.eclipsesource.jaxrs.connector.cfg' -> '/openhab/userdata/./etc/com.eclipsesource.jaxrs.connector.cfg'
'/openhab/userdata.dist/./etc/com.eclipsesource.jaxrs.swagger.config.cfg' -> '/openhab/userdata/./etc/com.eclipsesource.jaxrs.swagger.config.cfg'
'/openhab/userdata.dist/./etc/config.properties' -> '/openhab/userdata/./etc/config.properties'
'/openhab/userdata.dist/./etc/custom.properties' -> '/openhab/userdata/./etc/custom.properties'
'/openhab/userdata.dist/./etc/custom.system.properties' -> '/openhab/userdata/./etc/custom.system.properties'
'/openhab/userdata.dist/./etc/distribution.info' -> '/openhab/userdata/./etc/distribution.info'
'/openhab/userdata.dist/./etc/equinox-debug.properties' -> '/openhab/userdata/./etc/equinox-debug.properties'
'/openhab/userdata.dist/./etc/java.util.logging.properties' -> '/openhab/userdata/./etc/java.util.logging.properties'
'/openhab/userdata.dist/./etc/jmx.acl.org.apache.karaf.bundle.cfg' -> '/openhab/userdata/./etc/jmx.acl.org.apache.karaf.bundle.cfg'
'/openhab/userdata.dist/./etc/jmx.acl.org.apache.karaf.config.cfg' -> '/openhab/userdata/./etc/jmx.acl.org.apache.karaf.config.cfg'
'/openhab/userdata.dist/./etc/jre.properties' -> '/openhab/userdata/./etc/jre.properties'
'/openhab/userdata.dist/./etc/keys.properties' -> '/openhab/userdata/./etc/keys.properties'
'/openhab/userdata.dist/./etc/keystore' -> '/openhab/userdata/./etc/keystore'
'/openhab/userdata.dist/./etc/org.apache.felix.eventadmin.impl.EventAdmin.cfg' -> '/openhab/userdata/./etc/org.apache.felix.eventadmin.impl.EventAdmin.cfg'
'/openhab/userdata.dist/./etc/org.apache.felix.fileinstall-deploy.cfg' -> '/openhab/userdata/./etc/org.apache.felix.fileinstall-deploy.cfg'
'/openhab/userdata.dist/./etc/org.apache.karaf.command.acl.bundle.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.command.acl.bundle.cfg'
'/openhab/userdata.dist/./etc/org.apache.karaf.command.acl.config.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.command.acl.config.cfg'
'/openhab/userdata.dist/./etc/org.apache.karaf.command.acl.feature.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.command.acl.feature.cfg'
'/openhab/userdata.dist/./etc/org.apache.karaf.command.acl.jaas.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.command.acl.jaas.cfg'
'/openhab/userdata.dist/./etc/org.apache.karaf.command.acl.kar.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.command.acl.kar.cfg'
'/openhab/userdata.dist/./etc/org.apache.karaf.command.acl.scope_bundle.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.command.acl.scope_bundle.cfg'
'/openhab/userdata.dist/./etc/org.apache.karaf.command.acl.shell.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.command.acl.shell.cfg'
'/openhab/userdata.dist/./etc/org.apache.karaf.command.acl.system.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.command.acl.system.cfg'
'/openhab/userdata.dist/./etc/org.apache.karaf.features.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.features.cfg'
'/openhab/userdata.dist/./etc/org.apache.karaf.features.repos.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.features.repos.cfg'
'/openhab/userdata.dist/./etc/org.apache.karaf.jaas.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.jaas.cfg'
'/openhab/userdata.dist/./etc/org.apache.karaf.kar.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.kar.cfg'
'/openhab/userdata.dist/./etc/org.apache.karaf.log.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.log.cfg'
'/openhab/userdata.dist/./etc/org.apache.karaf.shell.cfg' -> '/openhab/userdata/./etc/org.apache.karaf.shell.cfg'
'/openhab/userdata.dist/./etc/org.eclipse.smarthome.audio.cfg' -> '/openhab/userdata/./etc/org.eclipse.smarthome.audio.cfg'
'/openhab/userdata.dist/./etc/org.eclipse.smarthome.voice.cfg' -> '/openhab/userdata/./etc/org.eclipse.smarthome.voice.cfg'
'/openhab/userdata.dist/./etc/org.jupnp.cfg' -> '/openhab/userdata/./etc/org.jupnp.cfg'
'/openhab/userdata.dist/./etc/org.ops4j.pax.logging.cfg' -> '/openhab/userdata/./etc/org.ops4j.pax.logging.cfg'
'/openhab/userdata.dist/./etc/org.ops4j.pax.url.mvn.cfg' -> '/openhab/userdata/./etc/org.ops4j.pax.url.mvn.cfg'
'/openhab/userdata.dist/./etc/org.ops4j.pax.web.cfg' -> '/openhab/userdata/./etc/org.ops4j.pax.web.cfg'
'/openhab/userdata.dist/./etc/overrides.properties' -> '/openhab/userdata/./etc/overrides.properties'
'/openhab/userdata.dist/./etc/profile.cfg' -> '/openhab/userdata/./etc/profile.cfg'
'/openhab/userdata.dist/./etc/scripts' -> '/openhab/userdata/./etc/scripts'
'/openhab/userdata.dist/./etc/scripts/shell.colors.script' -> '/openhab/userdata/./etc/scripts/shell.colors.script'
'/openhab/userdata.dist/./etc/scripts/shell.completion.script' -> '/openhab/userdata/./etc/scripts/shell.completion.script'
'/openhab/userdata.dist/./etc/shell.init.script' -> '/openhab/userdata/./etc/shell.init.script'
'/openhab/userdata.dist/./etc/startup.properties' -> '/openhab/userdata/./etc/startup.properties'
'/openhab/userdata.dist/./etc/system.properties' -> '/openhab/userdata/./etc/system.properties'
'/openhab/userdata.dist/./etc/users.properties' -> '/openhab/userdata/./etc/users.properties'
'/openhab/userdata.dist/./etc/version.properties' -> '/openhab/userdata/./etc/version.properties'
'/openhab/userdata.dist/./logs' -> '/openhab/userdata/./logs'
'/openhab/userdata.dist/./logs/openhab.log' -> '/openhab/userdata/./logs/openhab.log'
'/openhab/userdata.dist/./tmp' -> '/openhab/userdata/./tmp'
'/openhab/userdata.dist/./tmp/README' -> '/openhab/userdata/./tmp/README'
++ cmp /openhab/userdata/etc/version.properties /openhab/userdata.dist/etc/version.properties
+ '[' '!' -z ']'
++ ls -A /openhab/conf
+ '[' -z '' ']'
+ echo 'No configuration found... initializing.'
+ cp -av /openhab/conf.dist/. /openhab/conf/
'/openhab/conf.dist/./html' -> '/openhab/conf/./html'
'/openhab/conf.dist/./html/index.html' -> '/openhab/conf/./html/index.html'
'/openhab/conf.dist/./html/readme.txt' -> '/openhab/conf/./html/readme.txt'
'/openhab/conf.dist/./icons' -> '/openhab/conf/./icons'
'/openhab/conf.dist/./icons/classic' -> '/openhab/conf/./icons/classic'
'/openhab/conf.dist/./icons/classic/readme.txt' -> '/openhab/conf/./icons/classic/readme.txt'
'/openhab/conf.dist/./items' -> '/openhab/conf/./items'
'/openhab/conf.dist/./items/readme.txt' -> '/openhab/conf/./items/readme.txt'
'/openhab/conf.dist/./persistence' -> '/openhab/conf/./persistence'
'/openhab/conf.dist/./persistence/readme.txt' -> '/openhab/conf/./persistence/readme.txt'
'/openhab/conf.dist/./rules' -> '/openhab/conf/./rules'
'/openhab/conf.dist/./rules/readme.txt' -> '/openhab/conf/./rules/readme.txt'
'/openhab/conf.dist/./scripts' -> '/openhab/conf/./scripts'
'/openhab/conf.dist/./scripts/readme.txt' -> '/openhab/conf/./scripts/readme.txt'
'/openhab/conf.dist/./services' -> '/openhab/conf/./services'
'/openhab/conf.dist/./services/addons.cfg' -> '/openhab/conf/./services/addons.cfg'
'/openhab/conf.dist/./services/readme.txt' -> '/openhab/conf/./services/readme.txt'
'/openhab/conf.dist/./services/runtime.cfg' -> '/openhab/conf/./services/runtime.cfg'
'/openhab/conf.dist/./sitemaps' -> '/openhab/conf/./sitemaps'
'/openhab/conf.dist/./sitemaps/readme.txt' -> '/openhab/conf/./sitemaps/readme.txt'
'/openhab/conf.dist/./sounds' -> '/openhab/conf/./sounds'
'/openhab/conf.dist/./sounds/barking.mp3' -> '/openhab/conf/./sounds/barking.mp3'
'/openhab/conf.dist/./sounds/doorbell.mp3' -> '/openhab/conf/./sounds/doorbell.mp3'
'/openhab/conf.dist/./things' -> '/openhab/conf/./things'
'/openhab/conf.dist/./things/readme.txt' -> '/openhab/conf/./things/readme.txt'
'/openhab/conf.dist/./transform' -> '/openhab/conf/./transform'
'/openhab/conf.dist/./transform/de.map' -> '/openhab/conf/./transform/de.map'
'/openhab/conf.dist/./transform/en.map' -> '/openhab/conf/./transform/en.map'
'/openhab/conf.dist/./transform/readme.txt' -> '/openhab/conf/./transform/readme.txt'
+ chown -R openhab:openhab /openhab
+ sync
+ '[' -d /etc/cont-init.d ']'
+ sync
+ '[' false == false ']'
++ IFS=' '
++ echo gosu openhab tini -s ./start.sh
+ '[' 'gosu openhab tini -s ./start.sh' == 'gosu openhab tini -s ./start.sh' ']'
+ command=($@ server)
+ exec gosu openhab tini -s ./start.sh server
