Sorry I’m a newbie…
Environment: PINE A64 2G, 5V/2.5A PSU, 8GB SanDisk Class 10 microSD card
openhabianpine64-xenial-201706161506-git7ff273e-crcadda6dbb.img, and openhabianpine64-xenial-20170317-git5125a3d-crcab2f3232.img
Ethernet and HDMI
After power up on the video port the messages of the boot process stop somewhere and after 15-20 minutes login prompts appear. After I logged in there is a loop of messages as shown below that I can see both on the video port and doing ssh into the SBC.
2017-10-07_17:43:04_UTC [openHABian] Ensuring network connectivity… 2017-10-07_18:12:13_UTC [openHABian] Starting the openHABian initial setup
. This might take a few minutes.
2017-10-07_18:12:13_UTC [openHABian] If you see this message more than once, something went wrong!
2017-10-07_18:12:13_UTC [openHABian] Storing configuration… OK
2017-10-07_18:12:14_UTC [openHABian] Changing default username and password… SKIPPED
2017-10-07_18:12:14_UTC [openHABian] Setting up Wifi connection… SKIPPED
2017-10-07_18:12:14_UTC [openHABian] Ensuring network connectivity…
2017-10-07_18:13:55_UTC [openHABian] Network unreachable, can’t continue. Please reboot and let me try again.
2017-10-07_18:13:55_UTC [openHABian] Initial setup exiting with an error.
2017-10-07_18:07:25_UTC [openHABian] Starting the openHABian initial setup. This might take a few minutes.
2017-10-07_18:07:25_UTC [openHABian] If you see this message more than once, something went wrong!
2017-10-07_18:07:25_UTC [openHABian] Storing configuration… OK
2017-10-07_18:07:25_UTC [openHABian] Changing default username and password… SKIPPED
2017-10-07_18:07:25_UTC [openHABian] Setting up Wifi connection… SKIPPED
2017-10-07_18:07:25_UTC [openHABian] Ensuring network connectivity…
2017-10-08_00:36:56_UTC [openHABian] Network unreachable, can’t continue. Please reboot and let me try again.
2017-10-08_00:36:56_UTC [openHABian] Initial setup exiting with an error.
Red LED stays on and Ethernet is up
The browser will return the followings:
This site can’t be reached
192.168.0.31 refused to connect.
Try:
Checking the connection
Checking the proxy and the firewall
ERR_CONNECTION_REFUSED
This is happening with both images I mentioned above and with different microSD cards.
BTW Q4OS burned with the same application boots and runs without any problem on this same configuration.
