Hello Guy´s
i need help at this step. I am a newbie in openhab
How and where do i check that the spotify_auth_code is set in OpenHab
How and where do i Set the REDIRECT_URI in spotify.py to the right value
How do i use the spotify.py
Thanks for the hard work, however i guess the spotify.py is for python 2x do any of you have the equivalent for python 3?
Never mind - bodged shuffle functionality myself
Shuffle on is:
/usr/bin/python /etc/openhab2/scripts/spotify.py shuffle
Shuffle off is:
/usr/bin/python /etc/openhab2/scripts/spotify.py shuffleoff
Didn’t checkout any repos - will wait for an official release:
Here is my current script
Thisis an edit of one of the scripts referenced above - very little of it is my own code.
All credit to @pmpkk
# Use the Spotify Web Connect API using credentials auth code and tokens.
import json
import requests
import time
import urlparse
import sys
from myopenhab import openhab
from myopenhab import mapValues
from myopenhab import getJSONValue
# API Gateway
ACCOUNT_URL = 'https://accounts.spotify.com/api/token'
API_ROOT_URL = 'https://api.spotify.com/v1/me/player/'
REDIRECT_URI = 'http://192.168.0.131:8080/static/spotify-auth.html'
RAW_ROOT_URL = 'https://api.spotify.com/v1/me/'
class spotify(object):
A wrapper for the Spotify Web Connect API
https://developer.spotify.com/web-api/web-api-connect-endpoint-reference/
def __init__(self):
self.debug = False
self.oh = openhab()
self.client_id = self.oh.getState('spotify_client_id')
self.client_secret = self.oh.getState('spotify_client_secret')
self.access_token = self.oh.getState('spotify_access_token')
self.refresh_token = self.oh.getState('spotify_refresh_token')
self.token_issued = self.oh.getState('spotify_token_issued')
self.token_expiry = self.oh.getState('spotify_token_expiry')
if(self.token_expiry == "NULL"):
self.refreshCredentials()
if (self.access_token == "NULL"):
self.generateCredentials()
else:
if (time.time() > float(self.token_expiry)):
def generateCredentials(self):
Generate auth and refresh token for the very first time.
# Send OAuth payload to get access_token
payload = { 'code':self.oh.getState('spotify_auth_code'), 'client_id':self.client_id, 'client_secret':self.client_secret, 'redirect_uri':REDIRECT_URI, 'grant_type':'authorization_code' }
print "-- Calling Token Service for the first time"
try:
r = requests.post(ACCOUNT_URL, data=payload, allow_redirects=False)
if (self.debug): print r.headers
if (self.debug): print r.json()
resp = r.json()
if(r.status_code == 200):
access_token = resp['access_token']
refresh_token = resp['refresh_token']
expires_in = resp['expires_in']
# Set and Save the access token
self.access_token = access_token
self.refresh_token = refresh_token
self.token_expiry = time.time() + float(expires_in)
self.token_issued = time.strftime("%Y-%m-%dT%H:%M:%S")
self.saveCredentials()
else:
print " -> Error getting token:" + str(resp)
except:
print " -> Error getting token:" + str(sys.exc_info()[1])
def refreshCredentials(self):
If previous auth token expired, get a new one with refresh token.
payload = { 'refresh_token':self.refresh_token, 'client_id':self.client_id, 'client_secret':self.client_secret, 'redirect_uri':REDIRECT_URI, 'grant_type':'refresh_token' }
print "-- Calling Token Refresh Service"
try:
resp = r.json()
if('refresh_token' in resp):
else:
print " -> Error refreshing token:" + str(resp)
except:
print " -> Error refreshing token:" + str(sys.exc_info()[1])
def saveCredentials(self):
Save current tokens to the openhab.
self.oh.sendCommand('spotify_access_token',self.access_token)
self.oh.sendCommand('spotify_refresh_token',self.refresh_token)
self.oh.sendCommand('spotify_token_expiry',self.token_expiry)
self.oh.sendCommand('spotify_token_issued',self.token_issued)
def call(self, path, mode=None, payload=None):
Call the API at the given path.
print path
if path == "playlists" :
print "playlists"
else:
path = "player/" + path
print RAW_ROOT_URL + path
if (time.time() > self.token_expiry):
headers = {"Authorization": "Bearer " + self.access_token, "Content-Type": "application/json" }
if mode == "POST":
r = requests.post(RAW_ROOT_URL + path, headers=headers, data=payload)
if(r.status_code != 202):
print r.content
return r.status_code
elif mode == "PUT":
r = requests.put(RAW_ROOT_URL + path, headers=headers, data=payload)
print r.content
else:
r = requests.get(RAW_ROOT_URL + path, headers=headers)
if(r.status_code != 202 and r.status_code != 200 and r.status_code != 201 ):
print r.content
return r.json()
def update(self):
Get a current player state.
print "-- Calling Service: Update"
try:
resp = self.call("")
if (self.debug): print resp
if ('item' in resp):
self.oh.sendCommand('spotify_current_track', getJSONValue(resp, ['item','name']))
self.oh.sendCommand('spotify_current_artist', getJSONValue(resp, ['item', 'artists', 0, 'name']))
self.oh.sendCommand('spotify_current_cover', getJSONValue(resp, ['item', 'album', 'images', 1, 'url']))
self.oh.sendCommand('spotify_current_duration', getJSONValue(resp, ['item', 'duration_ms']))
self.oh.sendCommand('spotify_current_progress', getJSONValue(resp, ['progress_ms']))
self.oh.sendCommand('spotify_current_playing', mapValues(getJSONValue(resp, ['is_playing']), { 'True': 'ON', 'False': 'OFF' }))
self.oh.sendCommand('spotify_current_device', getJSONValue(resp, ['device', 'name']))
self.oh.sendCommand('spotify_current_volume', getJSONValue(resp, ['device', 'volume_percent']))
self.oh.sendCommand('spotify_current_device_id', getJSONValue(resp, ['device', 'id']))
print " -> Success"
else:
print " -> Item node missing from response :("
except:
print " -> Failure: ", sys.exc_info()[0]
resp = ""
return resp
def volumeAdjust(self, adjustment = None):
Volume adjust by adjustment
print "-- Calling Service: Volume Up"
try:
vol = int(self.oh.getState('spotify_current_volume'))
vol = int(round(vol/10)*10 + adjustment)
if(vol>100):
vol = 100
resp = self.volume(vol)
except:
print " -> VolumeUp Failure: ", sys.exc_info()[0]
resp = ""
return resp
def volume(self, newVol = None):
Volume to newVol
print "-- Calling Service: Volume set"
try:
print "Volume To:" + str(newVol)
resp = self.call("volume?volume_percent=" + str(newVol),"PUT" )
self.oh.sendCommand('spotify_current_volume',newVol)
except:
print " -> VolumeDown Failure: ", sys.exc_info()[0]
resp = ""
return resp
def pause(self):
Pause player
print "-- Calling Service: Pause"
try:
resp = self.call("pause","PUT")
self.oh.sendCommand('spotify_current_playing',"OFF")
except:
print " -> Pause Failure: ", sys.exc_info()[0]
resp = ""
return resp
def play(self, context_uri = None, new_device = None):
Resume player device
print "-- Calling Service: Play device"
if (new_device is None or len(new_device)==0):
action_url = "play"
print "basic url match"
print action_url
if (context_uri is None):
payload = {}
else:
payload = json.dumps({ 'context_uri': context_uri })
else:
payload = json.dumps({ 'device_ids': [new_device] })
action_url = ""
else:
action_url = "play?device_id=" + str(new_device)
print payload
print action_url
try:
resp = self.call(action_url,"PUT", payload = payload)
self.update()
except:
print " -> Play Failure: ", sys.exc_info()[0]
resp = ""
return resp
def previous(self):
Skip to previous track
print "-- Calling Service: Previous"
try:
resp = self.call("previous","POST")
self.update()
except:
print " -> Previous Failure: ", sys.exc_info()[0]
resp = ""
return resp
def next(self):
Skip to next track
print "-- Calling Service: Next"
try:
resp = self.call("next","POST")
self.update()
except:
print " -> Next Failure: ", sys.exc_info()[0]
resp = ""
return resp
def shuffle(self):
Shuffle track
print "-- Calling Service: Shuffle"
try:
resp = self.call("shuffle?state=true","PUT")
self.update()
except:
print " -> Shuffle Failure: ", sys.exc_info()[0]
resp = ""
return resp
def shuffleoff(self):
Don't Shuffle track
print "-- Calling Service: Shuffle Off"
try:
resp = self.call("shuffle?state=false","PUT")
self.update()
except:
resp = ""
return resp
def device_match(self, device_pick = None):
Identify device input type,(name, id or index).
print "-- Calling Service: devices_match"
device_id_match=""
index_test=""
array_index=-1
#Dynamic check of id length against current id, with backup test if current id is null.
try:
if(device_pick):
current_device_id = self.oh.getState('spotify_current_device_id')
if( len(device_pick) == len(current_device_id) or len(device_pick) == 40):
array_index=1
print "id: ", device_pick
else:
if (device_pick.isdigit() and len(device_pick) < 3):
array_index=2
print "index: ", device_pick
else:
print "name: ", device_pick
array_index=0
except:
return array_index
def playlists(self):
Get users recent playlists
print "-- Calling Service: get playlists"
try:
resp = self.call("playlists")
self.oh.sendCommand('spotify_playlists', json.dumps(resp))
except:
resp = ""
return resp
def devices(self, name = None, idNum = None, devIndex = None):
Get a current player devices and helper function to play device.
print "-- Calling Service: get devices"
exitStatus=" -> Success"
selected_device=""
if (name) or (idNum) or (devIndex): exitStatus = ""
if (devIndex) : iIndex = int(devIndex)
else: iIndex = -1
arrayDesc=[name,idNum,iIndex]
try:
resp = self.call("devices")
if ('devices' in resp):
self.oh.sendCommand('spotify_devices', json.dumps(resp))
initOrder = 0
partial = ""
j = 0
k = 1
while(exitStatus == ""):
idx = 1
searchName = arrayDesc[(j%3)]
print "Match :", searchName , " or ", arrayDesc[((1 + j)%3)], "index: ", iIndex
intmed = str(searchName)
print intmed
print json.dumps(searchName)
for i in resp['devices']:
loopName = getJSONValue(i, ['name'])
searchid = getJSONValue(i, ['id'])
print idx, "Device : " , loopName , "id :" ,searchid
if (arrayDesc[(j%3)] == loopName) or (arrayDesc[((1 + j)%3)] == searchid) or (iIndex == idx ):
self.oh.sendCommand('spotify_device_name', loopName)
self.oh.sendCommand('spotify_device_id', searchid)
self.oh.sendCommand('spotify_device_index', idx)
exitStatus="Match Sucess"
selected_device = searchid
return selected_device
#Performs partial match serach if no results found
if (searchName):
if searchName.lower() in loopName.lower():
partial = searchid
idx = idx + 1
#Looks at the various inputs and seraches on each input in various fields
iIndex=""
j+=1
if( j > 3): exitStatus="FAILED"
if (j == k):
k = 2
dev_desp=""
if (idNum):
dev_desp = idNum
idNum=""
j = 0
initOrder = 1
print "idNum serach"
elif (devIndex) :
dev_desp = devIndex
devIndex=""
j = 0
iIndex=-1
initOrder = 2
print "devinx serach"
elif (name) :
dev_desp = name
j = 0
name = ""
initOrder = 0
print "name serach"
if (dev_desp):
smart_index = self.device_match(dev_desp)
if(smart_index > 0):
arrayDesc[smart_index] = dev_desp
if (smart_index == 2):
iIndex = int(dev_desp)
if (smart_index == initOrder): j = j + 1
elif (partial):
k = 10
j = 3
arrayDesc[1] = partial
print "partial serach"
print exitStatus
else:
print " -> Device list error :("
except:
resp = ""
def removequotes(self,s): return "".join(i for i in s if i != "\"")
def argsort(self, theargs = None):
spotifyString="spotify:"
myargs = ["",""]
for i in range(2, len(theargs)):
print theargs[i]
stream=self.removequotes(theargs[i]).strip()
if spotifyString in theargs[i].lower():
myargs[0] = myargs[0] + stream + " "
else:
myargs[1] = myargs[1] + stream + " "
return self.removeEmpty(myargs)
def removeEmpty(self, inString = None):
print inString
for i in range(len(inString)):
if(inString[i] == ""): inString[i] = None
else: inString[i]=inString[i].strip()
return inString
def sanitiseActions(self, uristring = None, device_string = None):
new_device_id = self.devices(device_string)
current_device = self.oh.getState('spotify_current_device_id')
currently_playing = self.oh.getState('spotify_current_playing')
ma=[uristring,device_string]
if (current_device == new_device_id):
ma[1]=""
return ma
def updateConnectionDateTime(self):
self.oh.sendCommand('spotify_lastConnectionDateTime',time.strftime("%Y-%m-%dT%H:%M:%S.000+0000",time.gmtime(time.time())))
# self.oh.sendCommand('spotify_lastConnectionDateTime',time.strftime("%Y-%m-%dT%H:%M:%S+0000",time.gmtime(time.time())))
def main():
t1 = time.time()
c = spotify()
args = sys.argv
if(len(args) == 1):
c.update()
else:
if(args[1] == "volume_up"):
c.volumeAdjust(10)
if(args[1] == "volume_down"):
c.volumeAdjust(-10)
if(args[1] == "volume"):
c.volume(args[2])
if(args[1] == "mute"):
c.volume("0")
if(args[1] == "play"):
if(len(args)>2):
ma = c.argsort(args)
c.play(ma[0],c.devices(ma[1]))
else:
c.play()
if(args[1] == "playlists"):
c.playlists()
if(args[1] == "pause"):
c.pause()
if(args[1] == "previous"):
c.previous()
if(args[1] == "next"):
c.next()
if(args[1] == "shuffle"):
c.shuffle()
if(args[1] == "shuffleoff"):
c.shuffleoff()
if(args[1] == "devices"):
if(len(args)>2):
c.devices(ma[1])
else:
c.devices()
if(args[1] == "device_id"):
if(len(args)>2):
c.devices(None,args[2])
else:
c.devices()
if(args[1] == "device_name"):
if(len(args)>2):
c.devices(ma[1])
else:
c.devices()
if(args[1] == "device_index"):
if(len(args)>2):
c.devices(None, None, args[2])
else:
c.devices()
if(args[1] == "play_device"):
c.play(ma[0], c.devices(ma[1]))
if(args[1] == "play_device_name"):
c.updateConnectionDateTime()
t2 = time.time()
print "Done in " + str(t2-t1) + " seconds"
if __name__ == '__main__':
main()
HI guys
I already have the spotify web api running, but on every startup i lost the auth.
I saw in the configuration that you have to enable presistence but i dont know how to do that, can you help me please?
Best regards
For MySQL see e.g. this tutorial, it did work out for me: openHAB2 & MySQL persistence setup
Same problem @OliM! Have you already found a solution?
Hello! Please I need help, following the tutorial I have a problem at the end, I copy the result below.
I do not know what to try
Blockquote
pi@Domotica:~ $ /usr/bin/python /etc/openhab2/scripts/spotify.py
Successfully got state from OpenHab: spotify_client_id
Successfully got state from OpenHab: spotify_client_secret
Successfully got state from OpenHab: spotify_access_token
Successfully got state from OpenHab: spotify_refresh_token
Successfully got state from OpenHab: spotify_token_issued
Successfully got state from OpenHab: spotify_token_expiry
– Calling Token Refresh Service
→ Error refreshing token:{u’error_description’: u’Invalid refresh token’, u’error’: u’invalid_grant’}
Successfully got state from OpenHab: spotify_auth_code
– Calling Token Service for the first time
Successfully posted state to OpenHab: spotify_access_token = XXXXXXXXXXXXXXXXXXXXGIE9oAsIPkvtNdrjL3km3i7B9g9x5kW379fAgC6PJOkmXe1PKYBFLjGIHQOqn8G02bjjCjhLj62aiQT7OWc5WMQxsH2w35H0-6dtvhDEpUNoSFd87FRLleFz9tY9thS0l5nA3QBTKlb9HH4
Successfully posted state to OpenHab: spotify_refresh_token = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXDt6cr-33Z9s0lXFR2sW4MO5pn6JCwegcSsacZV6VwH3DfUfH1g6Go3t3K8tS9nLqJZEpvdsPlqyYirIJjVfJsqHZX8K3YRw
Successfully posted state to OpenHab: spotify_token_expiry = 1516801970.35
Successfully posted state to OpenHab: spotify_token_issued = 2018-01-24T13:52:50
– Calling Service: Update
→ Failure: <class ‘simplejson.scanner.JSONDecodeError’>
Successfully posted state to OpenHab: spotify_lastConnectionDateTime = 2018-01-24T12:52:50.000+0000
Done in 1.43034410477 seconds
Where is the error?
Hi all!
If I click on the next song, I have to click on the update-button and then reload the page to see the new cover-image. Why?
Next song: ng-click="sendCmd(‘spotify_action’, ‘next’)"
Update: ng-click=“sendCmd(‘spotify_forceupadte’, ‘ON’)“
Cover-image: ng-style=”{‘background-image’: ‘url(’ + itemValue(‘spotify_current_cover’) + ‘)’}”
I got two rules:
Spotify-test:
rule “Spotify run script"
Time cron “0/1 * * * * ? *” or
Item spotify_forceupadte received update
val resp = executeCommandLine(”/usr/bin/python /etc/openhab2/scripts/spotify.py", 2000)
logInfo(“Spotify”, resp)
rule “Spotify Action"
Item spotify_action received update
val resp = executeCommandLine(”/usr/bin/python /etc/openhab2/scripts/spotify.py " + spotify_action.state.toString, 2000)
Spotify:
val resp = executeCommandLine(”/usr/bin/python /etc/openhab2/scripts/spotify.py", 5000)
val resp = executeCommandLine(”/usr/bin/python /etc/openhab2/scripts/spotify.py " + spotify_action.state.toString, 5000)
Not sure. I get the image to load pretty much instantly when I press next or back. Maybe 10 seconds or so. No need to update status or refresh the page.
You have a time cron running every second all the time which might be a bit much for the spotify servers so they are limiting your connection which you only notice when you try and get an image. I have one that runs once every 30 seconds, but if spotify is playing then it will update every 5 seconds. I then used js as posted above to smooth the progress bar over those 5 sec.
Edit: I lied only update every 30 when spotify is active and once every half an hour otherwise, which is probably too conservative.
rule "spotify live update"
Time cron "0/30 * * * * ?"
if ( spotify_current_playing.state == ON && parse(spotify_lastConnectionDateTime.state.toString).plusSeconds(20).isBefore(now)){
sendCommand(spotify_forceupadte, ON)
logInfo("Spotify", "Chrom live update run")
rule "spotify update"
Time cron "0 0/30 * * * ?"
logInfo("Spotify", "Chron prelock")
if (parse(spotify_lastConnectionDateTime.state.toString).plusSeconds(45).isBefore(now)){
logInfo("Spotify", "Chrom update run")
I have the same problem, I have set the Windows variables and can call python from the CMD line, but openHAB is still looking for its default path and resolving the variable;
Execution failed (Exit value: -559038737. Caused by java.io.IOException: Cannot run program "\usr\bin\python" (in directory ".")
Is there an option to change the biding or script to look for a Windows variables, or how can I get Windows to recognize that “\usr\bin\python” actually is C:\Python27. I am pretty sure that system variables cannot include "/"s
Whoops, this is clearly defined and can get set using true path in the spotify.rules file.
val resp = executeCommandLine("C:\\Python27\\python.exe D:\\openHAB\\conf\\scripts\\spotify.py", 5000)
I must have been getting tunnel vision on the actual scripts themselves - Cheers
Hi All,
It’s all working fine, thanks for the work!!
Except when I update the items file or reboot openhab I have to manually assign id and secret and then authenticate on spotify-auth.html.
Any solution for this, or am I missing something?
Thanks!
PS. Persistence is recording any change:
Strategies {
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
Items {
// persist everything when the value is updated, just a default, and restore them from database on startup
* : strategy = everyChange, everyMinute, restoreOnStartup
I´ve got always :
-> Failure: <type 'exceptions.ValueError'>
Is the redirect URI REDIRECT_URI = ‘http://openhabianpi.local:8080/static/spotify-auth.html’ correct in spotify.py ???
Thanks for help
Mad
Edit : Got it
I’m running this on a mac so I changed the redirect URI to http://localhost:8080/static/spotify-auth.html
Samanthas-iMac:scripts SamanthaAllen$ python spotify.py
-> Failure: <type ‘exceptions.ValueError’>
Error posting state to OpenHab: spotify_lastConnectionDateTime (HTTP Response State could not be parsed: 2018-02-20T16:33:17+0000)
Done in 1.39271020889 seconds
Thanks. I’m at the point where I need to configure a persistence db and when I try installing mysql in terminal for mac it asks for a password. I have no clue what this password could possibly be. It’s not my mac password and the habopen default password I read about is not working. Any ideas?
It took me a while to figure out that you have to set it in spotify.py, and also set it in the app settings in the Spotify developer dashboard. I don’t see that 2nd step identified anywhere here.
So I am having trouble with persistence. I have to re-auth every time Openhab restarts. Where can I put the values for spotify_client_id and spotify_client_secret so that they can be loaded when Openhab starts?
I’ve got some items updated on the startup, I’ve included Spotify id’s but I still have to re-authenticate…
Would love it to be a permanent thing
rule "Initialize items on startup"
System started
postUpdate(spotify_client_id, "99852********************923d5b")
postUpdate(spotify_client_secret, "c5a47bf********************69c039")
I don’t know why soo many people are having problems with persistence. It should work fine with any persistent setup. Here is my setup for reference.
Install MapDB persistence in PaperUI. Under settings set Persistence as MapDB. Then set mapdb.persist to
Strategies {
default = everyUpdate
Items {
* : strategy = everyChange, everyDay, restoreOnStartup
That should make sure all the key items are restored on restart. Note the client id and secret are for the initial authorisation. Its the auth token, etc that need to be persisted so you don’t have to manually re- auth each time.
/* Strings for Primary Auth */
String spotify_auth_code (sgstring)
String spotify_client_id (sgstring)
String spotify_client_secret (sgstring)
/* Strings for Token Auth */
String spotify_auth "http://debra.local:8080/static/spotify-auth.html" //This is likely a temp junk item I added that you don't need
String spotify_access_token "AccessToken [%s]" (sgstring)
String spotify_refresh_token "RefreshToken [%s]" (sgstring)
String spotify_token_expiry "TokenExpiry [%s]" (sgstring)
DateTime spotify_token_issued "TokenIssued [%s]"
Oh @mbibbey the readme is very clear with bullet points for all the steps. https://github.com/pmpkk/openhab_spotify-webconnect-api
* After registering as a Spotify developer, create a new App and retrieve client id and secret:
* Goto https://developer.spotify.com/my-applications/#!/applications
* Click "Create App"
* Provide a name and description
* **Set the Redirect URI to: http://openhabianpi.local:8080/static/spotify-auth.html**
* Save the Settings
