Openhab just collapsed
I am running the latest openhab version (stable) on docker. It just collapsed with the following errors.
What happened?
Daniel
ps. By collapsed I mean not starting anymore.
pps. culprit might be watchtower auto-update tonight
2019-12-15 21:21:00 (info): Found new openhab/openhab:latest image (sha256:478da8fa1f4b3772ca51da8f0ec6be1d3db90259102d80754f7ff27c153c19e8)
2019-12-15 21:21:27 (info): Stopping /openhab (3bfc92cee8f5daa03b17c7fd13294d5adff7d76a088bc093aaf65dfd4840d7aa) with SIGTERM
2019-12-15 21:21:37 (info): Creating /openhab
Error logs
2019-12-15 22:32:47.464 [ERROR] [.eclipse.smarthome.io.transport.mdns] - FrameworkEvent ERROR - org.eclipse.smarthome.io.transport.mdns
org.osgi.framework.BundleException: Unable to acquire the state change lock for the module: osgi.identity; osgi.identity="org.eclipse.smarthome.io.transport.mdns"; type="osgi.bundle"; version:Version="0.10.0.oh240" [id=126] STOPPED [STOPPED]
	at org.eclipse.osgi.container.Module.lockStateChange(Module.java:337) ~[?:?]
	at org.eclipse.osgi.container.Module.stop(Module.java:490) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.decStartLevel(ModuleContainer.java:1675) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1594) ~[?:?]
	at org.eclipse.osgi.container.SystemModule.stopWorker(SystemModule.java:270) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule.stopWorker(EquinoxBundle.java:147) ~[?:?]
	at org.eclipse.osgi.container.Module.doStop(Module.java:636) ~[?:?]
	at org.eclipse.osgi.container.Module.stop(Module.java:498) ~[?:?]
	at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165) ~[?:?]
	at java.lang.Thread.run(Thread.java:748) ~[?:?]
Caused by: java.util.concurrent.TimeoutException: Timeout after waiting 5 seconds to acquire the lock.
	at org.eclipse.osgi.container.Module.lockStateChange(Module.java:334) ~[?:?]
	... 10 more
2019-12-15 22:35:08.003 [WARN ] [org.apache.felix.fileinstall        ] - /usr/share/openhab2/addons does not exist, please create it.
2019-12-15 22:35:08.009 [ERROR] [org.apache.felix.fileinstall        ] - Cannot create folder /var/lib/openhab2/tmp/bundles. Is the folder write-protected?
2019-12-15 22:35:08.010 [ERROR] [org.apache.felix.configadmin        ] - [org.osgi.service.cm.ManagedServiceFactory, id=38, bundle=10/mvn:org.apache.felix/org.apache.felix.fileinstall/3.6.4]: Unexpected problem updating configuration org.apache.felix.fileinstall.c6e5ae20-7800-490d-9b88-c49da0b155eb
java.lang.RuntimeException: Cannot create folder: /var/lib/openhab2/tmp/bundles
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.prepareDir(DirectoryWatcher.java:647) ~[?:?]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.prepareTempDir(DirectoryWatcher.java:627) ~[?:?]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.<init>(DirectoryWatcher.java:179) ~[?:?]
	at org.apache.felix.fileinstall.internal.FileInstall.updated(FileInstall.java:248) ~[?:?]
	at org.apache.felix.fileinstall.internal.FileInstall$ConfigAdminSupport$Tracker.updated(FileInstall.java:378) ~[?:?]
	at org.apache.felix.cm.impl.helper.ManagedServiceFactoryTracker.updated(ManagedServiceFactoryTracker.java:159) ~[bundleFile:?]
	at org.apache.felix.cm.impl.helper.ManagedServiceFactoryTracker.provideConfiguration(ManagedServiceFactoryTracker.java:93) [bundleFile:?]
	at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceFactoryUpdate.provide(ConfigurationManager.java:1253) [bundleFile:?]
	at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceFactoryUpdate.run(ConfigurationManager.java:1197) [bundleFile:?]
	at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:138) [bundleFile:?]
	at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105) [bundleFile:?]
	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
2019-12-15 22:35:10.931 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
org.apache.karaf.features.internal.util.MultiException: Error:
	Error downloading mvn:org.openhab.ui.bundles/org.openhab.ui.dashboard/2.5.0
	at org.apache.karaf.features.internal.download.impl.MavenDownloadManager$MavenDownloader.<init>(MavenDownloadManager.java:91) ~[?:?]
	at org.apache.karaf.features.internal.download.impl.MavenDownloadManager.createDownloader(MavenDownloadManager.java:72) ~[?:?]
	at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:457) ~[?:?]
	at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:452) ~[?:?]
	at org.apache.karaf.features.internal.region.SubsystemResolver.resolve(SubsystemResolver.java:224) ~[?:?]
	at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:393) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1062) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:998) ~[?:?]
	at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_232]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_232]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_232]
	Suppressed: java.io.IOException: Error downloading mvn:org.openhab.ui.bundles/org.openhab.ui.dashboard/2.5.0
		at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:77) ~[?:?]
		at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_232]
		at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_232]
		at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:1.8.0_232]
	Caused by: java.io.IOException: Error resolving artifact org.openhab.ui.bundles:org.openhab.ui.dashboard:jar:2.5.0: [Could not transfer artifact org.openhab.ui.bundles:org.openhab.ui.dashboard:jar:2.5.0 from/to openhab (https://api.bintray.com/maven/openhab/mvn/online-repo/2.5/): Not authorized]
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.configureIOException(AetherBasedResolver.java:803) ~[?:?]
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:774) ~[?:?]
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:657) ~[?:?]
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:598) ~[?:?]
		at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:565) ~[?:?]
		at org.apache.karaf.features.internal.download.impl.MavenDownloadTask.download(MavenDownloadTask.java:52) ~[?:?]
		at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:60) ~[?:?]
		... 7 more
		Suppressed: shaded.org.eclipse.aether.transfer.ArtifactTransferException: Could not transfer artifact org.openhab.ui.bundles:org.openhab.ui.dashboard:jar:2.5.0 from/to openhab (https://api.bintray.com/maven/openhab/mvn/online-repo/2.5/): Not authorized
			at shaded.org.eclipse.aether.connector.basic.ArtifactTransportListener.transferFailed(ArtifactTransportListener.java:52) ~[?:?]
			at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$TaskRunner.run(BasicRepositoryConnector.java:368) ~[?:?]
			at shaded.org.eclipse.aether.util.concurrency.RunnableErrorForwarder$1.run(RunnableErrorForwarder.java:75) ~[?:?]
			at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$DirectExecutor.execute(BasicRepositoryConnector.java:642) ~[?:?]
			at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector.get(BasicRepositoryConnector.java:262) ~[?:?]
			at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.performDownloads(DefaultArtifactResolver.java:489) ~[?:?]
			at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:390) ~[?:?]
			at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifacts(DefaultArtifactResolver.java:215) ~[?:?]
			at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifact(DefaultArtifactResolver.java:192) ~[?:?]
			at shaded.org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveArtifact(DefaultRepositorySystem.java:247) ~[?:?]
			at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:767) ~[?:?]
		Caused by: shaded.org.apache.maven.wagon.authorization.AuthorizationException: Not authorized
			at shaded.org.apache.maven.wagon.shared.http.AbstractHttpClientWagon.fillInputData(AbstractHttpClientWagon.java:1123) ~[?:?]
			at shaded.org.apache.maven.wagon.shared.http.AbstractHttpClientWagon.fillInputData(AbstractHttpClientWagon.java:1072) ~[?:?]
			at shaded.org.apache.maven.wagon.StreamWagon.getInputStream(StreamWagon.java:126) ~[?:?]
			at shaded.org.apache.maven.wagon.StreamWagon.getIfNewer(StreamWagon.java:88) ~[?:?]
			at shaded.org.apache.maven.wagon.StreamWagon.get(StreamWagon.java:61) ~[?:?]
			at shaded.org.eclipse.aether.transport.wagon.WagonTransporter$GetTaskRunner.run(WagonTransporter.java:567) ~[?:?]
			at shaded.org.eclipse.aether.transport.wagon.WagonTransporter.execute(WagonTransporter.java:435) ~[?:?]
			at shaded.org.eclipse.aether.transport.wagon.WagonTransporter.get(WagonTransporter.java:412) ~[?:?]
			at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$GetTaskRunner.runTask(BasicRepositoryConnector.java:456) ~[?:?]
			at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$TaskRunner.run(BasicRepositoryConnector.java:363) ~[?:?]
			... 21 more
	Caused by: shaded.org.eclipse.aether.resolution.ArtifactResolutionException: Error resolving artifact org.openhab.ui.bundles:org.openhab.ui.dashboard:jar:2.5.0
		at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:413) ~[?:?]
		... 7 more
2019-12-15 22:36:02.018 [WARN ] [org.apache.felix.fileinstall        ] - /usr/share/openhab2/addons does not exist, please create it.
2019-12-15 22:36:02.029 [ERROR] [org.apache.felix.fileinstall        ] - Cannot create folder /var/lib/openhab2/tmp/bundles. Is the folder write-protected?
2019-12-15 22:36:02.031 [ERROR] [org.apache.felix.configadmin        ] - [org.osgi.service.cm.ManagedServiceFactory, id=39, bundle=10/mvn:org.apache.felix/org.apache.felix.fileinstall/3.6.4]: Unexpected problem updating configuration org.apache.felix.fileinstall.c6e5ae20-7800-490d-9b88-c49da0b155eb
2019-12-15 22:36:05.399 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
		... 7 more
			... 21 more
		... 7 more
Did you updated to the recent stable 2.5 version?
It has some issues right now, don’t use it until further notice
It’s really a bad idea to auto-update on the latest tag since you’ve probably automatically updated to 2.5.0. :open_mouth:
There may also be manual update steps (see Release Notes) involved and there was a bug with the repo URLs that got fixed now. It’s probably best to restore the automatically generated backup.
Thanks for the quick reply!
Where would I find the auto-backups and how do I roll back?
What would be the right way to do the upgrade to 2.5.0 with docker? In the release notes I did not see anything I could do to fix the installation?
Daniel
You can also fix it by updating the version in /openhab/userdata/etc/version.properties to 2.4.0 and then recreate the container using the updated image. That way it will redo the upgrade and fix the files with the wrong URLs.
Ok, I am back to 2.4 again. 2.5 seems to have messed around with the permissions of the persistent folders (setting user and group to 9001, ignoring environment variables set in the docker container). Everything else works now.
Daniel
edit: internally openhab seems to ignore the environment variables on user_id and group_id. I just had to change the system IDs for my openhab user to 9001 else I had error messages in the logs
Did you try uppercasing them? It’s Linux so that matters.
