- Platform information:
- Hardware: AMD/8Mb RAM/SSD 512Gb PCIe3
- OS: W10Pro
- Java Runtime Environment: Zulu Java 17
- openHAB version: 4.1.1.
HI all
I am trying to clean the openhab.log file and I have managed to sort out almost all issues happening but there are sitill some I can’t understand and fix. Could somebody help?
2024-04-21 16:39:24.014 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.IllegalArgumentException: Invalid media type string: Content-Type: image/png
at org.apache.cxf.jaxrs.impl.MediaTypeHeaderProvider.internalValueOf(MediaTypeHeaderProvider.java:90) ~[?:?]
at org.apache.cxf.jaxrs.impl.MediaTypeHeaderProvider.valueOf(MediaTypeHeaderProvider.java:65) ~[?:?]
at org.apache.cxf.jaxrs.utils.JAXRSUtils.toMediaType(JAXRSUtils.java:1962) ~[?:?]
at org.apache.cxf.jaxrs.impl.ResponseImpl.getMediaType(ResponseImpl.java:313) ~[?:?]
at org.apache.cxf.jaxrs.impl.ResponseImpl.doReadEntity(ResponseImpl.java:431) ~[?:?]
at org.apache.cxf.jaxrs.impl.ResponseImpl.readEntity(ResponseImpl.java:410) ~[?:?]
at org.apache.cxf.jaxrs.impl.ResponseImpl.readEntity(ResponseImpl.java:400) ~[?:?]
at org.openhab.binding.sony.internal.net.HttpResponse.<init>(HttpResponse.java:90) ~[?:?]
at org.openhab.binding.sony.internal.net.HttpRequest.sendGetCommand(HttpRequest.java:100) ~[?:?]
at org.openhab.binding.sony.internal.transports.SonyHttpTransport.executeGet(SonyHttpTransport.java:272) ~[?:?]
at org.openhab.binding.sony.internal.transports.SonyHttpTransport.execute(SonyHttpTransport.java:112) ~[?:?]
at org.openhab.binding.sony.internal.transports.SonyHttpTransport.execute(SonyHttpTransport.java:242) ~[?:?]
at org.openhab.binding.sony.internal.transports.SonyHttpTransport.execute(SonyHttpTransport.java:225) ~[?:?]
at org.openhab.binding.sony.internal.transports.SonyHttpTransport.executeGet(SonyHttpTransport.java:165) ~[?:?]
at org.openhab.binding.sony.internal.net.NetUtil.getRawType(NetUtil.java:262) ~[?:?]
at org.openhab.binding.sony.internal.scalarweb.protocols.ScalarWebAppControlProtocol.refreshAppIcon(ScalarWebAppControlProtocol.java:345) ~[?:?]
at org.openhab.binding.sony.internal.scalarweb.protocols.ScalarWebAppControlProtocol.refreshChannel(ScalarWebAppControlProtocol.java:224) ~[?:?]
at org.openhab.binding.sony.internal.scalarweb.protocols.ScalarWebAppControlProtocol.refreshState(ScalarWebAppControlProtocol.java:200) ~[?:?]
at org.openhab.binding.sony.internal.scalarweb.protocols.ScalarWebProtocolFactory.lambda$2(ScalarWebProtocolFactory.java:167) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
at java.lang.Thread.run(Thread.java:833) [?:?]
Regarding Sony binding [4.0.0.M1;4.1.0), I have updated since I had previous one [[3.2.0;4.0.0)], and thought that this could be the reason, but it is still logging the same.
Thank you and regards
Diego
