Hi, Hello and Ho Ho Ho!
Was looking at the openHAB.log file and noticed that every minute or so something related to the PLM is creating an entry.
Is the related to the PLM being polled every 10 minutes?
Is this reading the state of the devices or is it setting them to off?
…set device 00.00.00 to OFF
…set device 00.00.00 to level 0
Does the PLM need to be polled and if so why?
insteonplm.cfg
poll_interval=600000
#refresh=600000
openhab.log
2019-12-24 15:15:05.687 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - devices: 12 configured, 12 polling, msgs received: 24
2019-12-24 15:15:06.826 [INFO ] [onplm.internal.device.MessageHandler] - SwitchRequestReplyHandler: set device 00.00.00 to OFF
2019-12-24 15:15:52.981 [INFO ] [onplm.internal.device.MessageHandler] - DimmerRequestReplyHandler: set device 00.00.00 to level 0
2019-12-24 15:16:39.149 [INFO ] [onplm.internal.device.MessageHandler] - DimmerRequestReplyHandler: set device 00.00.00 to level 0
2019-12-24 15:17:25.302 [INFO ] [onplm.internal.device.MessageHandler] - DimmerRequestReplyHandler: set device 00.00.00 to level 0
2019-12-24 15:18:11.459 [INFO ] [onplm.internal.device.MessageHandler] - SwitchRequestReplyHandler: set device 00.00.00 to OFF
2019-12-24 15:18:57.610 [INFO ] [onplm.internal.device.MessageHandler] - SwitchRequestReplyHandler: set device 00.00.00 to OFF
2019-12-24 15:19:43.774 [INFO ] [onplm.internal.device.MessageHandler] - SwitchRequestReplyHandler: set device 00.00.00 to OFF
2019-12-24 15:20:29.927 [INFO ] [onplm.internal.device.MessageHandler] - DimmerRequestReplyHandler: set device 00.00.00 to level 0
2019-12-24 15:21:16.085 [INFO ] [onplm.internal.device.MessageHandler] - SwitchRequestReplyHandler: set device 00.00.00 to OFF
2019-12-24 15:22:02.240 [INFO ] [onplm.internal.device.MessageHandler] - DimmerRequestReplyHandler: set device 00.00.00 to level 0
2019-12-24 15:22:48.394 [INFO ] [onplm.internal.device.MessageHandler] - DimmerRequestReplyHandler: set device 00.00.00 to level 0
2019-12-24 15:23:34.557 [INFO ] [onplm.internal.device.MessageHandler] - DimmerRequestReplyHandler: set device 00.00.00 to level 0
2019-12-24 15:25:05.691 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - devices: 12 configured, 12 polling, msgs received: 12
2019-12-24 15:25:06.821 [INFO ] [onplm.internal.device.MessageHandler] - SwitchRequestReplyHandler: set device 00.00.00 to OFF
2019-12-24 15:25:52.989 [INFO ] [onplm.internal.device.MessageHandler] - DimmerRequestReplyHandler: set device 00.00.00 to level 0
2019-12-24 15:26:39.289 [INFO ] [onplm.internal.device.MessageHandler] - DimmerRequestReplyHandler: set device 00.00.00 to level 0
2019-12-24 15:27:25.305 [INFO ] [onplm.internal.device.MessageHandler] - DimmerRequestReplyHandler: set device 00.00.00 to level 0
2019-12-24 15:28:11.462 [INFO ] [onplm.internal.device.MessageHandler] - SwitchRequestReplyHandler: set device 00.00.00 to OFF
2019-12-24 15:28:57.618 [INFO ] [onplm.internal.device.MessageHandler] - SwitchRequestReplyHandler: set device 00.00.00 to OFF
2019-12-24 15:29:45.836 [INFO ] [onplm.internal.device.MessageHandler] - SwitchRequestReplyHandler: set device 00.00.00 to OFF
2019-12-24 15:30:30.440 [INFO ] [onplm.internal.device.MessageHandler] - DimmerRequestReplyHandler: set device 00.00.00 to level 0
2019-12-24 15:31:16.083 [INFO ] [onplm.internal.device.MessageHandler] - SwitchRequestReplyHandler: set device 00.00.00 to OFF
2019-12-24 15:32:02.239 [INFO ] [onplm.internal.device.MessageHandler] - DimmerRequestReplyHandler: set device 00.00.00 to level 0
2019-12-24 15:32:48.393 [INFO ] [onplm.internal.device.MessageHandler] - DimmerRequestReplyHandler: set device 00.00.00 to level 0
2019-12-24 15:33:34.546 [INFO ] [onplm.internal.device.MessageHandler] - DimmerRequestReplyHandler: set device 00.00.00 to level 0
2019-12-24 15:35:05.696 [INFO ] [g.insteonplm.InsteonPLMActiveBinding] - devices: 12 configured, 12 polling, msgs received: 12
