OH3 - After restart the Raspberry Pi4 (Power off, power on)
Then the logging is fine OK !
But after some days the logging stopped en I only see on the screen :
" ==> /var/log/openhab/openhab.log <== "
β frontail.service - Frontail openHAB instance, reachable at http://openhabian:9001
Loaded: loaded (/etc/systemd/system/frontail.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2021-05-10 21:33:30 CEST; 5 days ago
Docs: GitHub - mthenw/frontail: π streaming logs to the browser
Main PID: 887 (node)
Tasks: 12 (limit: 4915)
CGroup: /system.slice/frontail.service
ββ 887 node /usr/lib/node_modules/frontail/bin/frontail --disable-usage-stats --ui-highlight --ui-high
ββ1072 tail -n 200 -F /var/log/openhab/openhab.log /var/log/openhab/events.log
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
