In OH2 I use the log viewer a lot on port 9001. I’m now testing/migrating to OH3 on Docker (OH2 is running in pi3). Is this Log Viewer still present, because I Cant found any info about it?
Hey,
Yes… it is still there.
You can install the log viewer manually, it can also be used for other logs, see Here.
That was an option to install in openHABian and is not part of openHAB.
Thx for the info! Didn’t knew this was a separate thing. Will install it in a different container, so I can use this for other apps top!
