Trying to start openhab and it fails at the line “Restore item status from ‘26-Mar-2016 4:00:00 PM’ for ittem 'JF_Home_Away” -> ‘ON’. Then the log stops moving.
I had the hue binding and it showed connecting correctly but all of a sudden the web server stopped serving up the openhab page.
I must say I also tried to configure samba to share config folder with my windows machine but that’s when I started running into issues… Any guidance on how to get this up and running again would be great.
Thanks!
16:20:16.628 [INFO ] [uartz.impl.StdSchedulerFactory:1324 ] - Quartz scheduler ‘openHAB-job-scheduler’ initialized from specified file: '/etc/openhab/quartz.properties’
16:20:16.628 [INFO ] [uartz.impl.StdSchedulerFactory:1328 ] - Quartz scheduler version: 2.1.7
16:20:16.629 [INFO ] [rg.quartz.core.QuartzScheduler:534 ] - Scheduler openHAB-job-scheduler_$_NON_CLUSTERED started.
16:20:16.631 [DEBUG] [o.config.core.ConfigDispatcher:146 ] - Processing openHAB default configuration file ‘/usr/share/openhab/configurations/openhab_default.cfg’.
16:20:16.670 [DEBUG] [o.config.core.ConfigDispatcher:168 ] - Processing openHAB main configuration file ‘/etc/openhab/configurations/openhab.cfg’.
16:20:16.826 [DEBUG] [.o.core.internal.CoreActivator:93 ] - UUID file already exists at ‘/usr/share/openhab/webapps/static/uuid’ with content '86f6d651-efed-429c-95fb-08fb6853838c’
16:20:16.827 [DEBUG] [.o.core.internal.CoreActivator:115 ] - Created file ‘/usr/share/openhab/webapps/static/version’ with content '1.8.2’
16:20:16.827 [INFO ] [.o.core.internal.CoreActivator:61 ] - openHAB runtime has been started (v1.8.2).
16:20:16.860 [DEBUG] [a.internal.AutoUpdateActivator:31 ] - AutoUpdate binding has been started.
16:20:17.593 [DEBUG] [.p.i.PersistenceModelActivator:23 ] - Registered ‘persistence’ configuration parser
16:20:17.606 [DEBUG] [.c.t.i.TransformationActivator:38 ] - Transformation Service has been started.
16:20:17.633 [DEBUG] [m.internal.MultimediaActivator:34 ] - Multimedia I/O bundle has been started.
16:20:17.647 [DEBUG] [.s.i.DiscoveryServiceActivator:27 ] - Discovery service has been started.
16:20:17.651 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl:93 ] - mDNS service has been started
16:20:17.659 [DEBUG] [.io.transport.mqtt.MqttService:123 ] - Starting MQTT Service…
16:20:17.745 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl:53 ] - Service Discovery initialization completed.
16:20:17.752 [INFO ] [.io.transport.mqtt.MqttService:108 ] - MQTT Service initialization completed.
16:20:17.753 [INFO ] [o.i.t.m.i.MqttBrokerConnection:114 ] - Starting MQTT broker connection 'mqbroker’
16:20:17.758 [DEBUG] [o.i.t.m.i.MqttBrokerConnection:294 ] - Creating new client for ‘tcp://m10.cloudmqtt.com:15885’ using id ‘openhab.1459023617757’ and file store '/tmp/mqbroker’
16:20:17.765 [DEBUG] [.i.internal.ItemModelActivator:24 ] - Registered ‘item’ configuration parser
16:20:17.837 [DEBUG] [o.o.c.i.items.ItemRegistryImpl:137 ] - Item provider ‘GenericItemProvider’ has been added.
16:20:18.570 [DEBUG] [.o.m.s.i.SitemapModelActivator:23 ] - Registered ‘sitemap’ configuration parser
16:20:18.758 [DEBUG] [.r.internal.RuleModelActivator:42 ] - Registered ‘rules’ configuration parser
16:20:18.767 [DEBUG] [m.r.internal.engine.RuleEngine:77 ] - Started rule engine
16:20:22.166 [DEBUG] [.m.i.MyOpenHABServiceActivator:28 ] - MyOpenHAB service has been started.
16:20:22.184 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:300 ] - setEventPublisher
16:20:22.184 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:135 ] - my.openHAB service activated
16:20:22.185 [DEBUG] [.p.internal.PersistenceManager:146 ] - Initializing myopenhab persistence service.
16:20:22.187 [DEBUG] [c.internal.ModelRepositoryImpl:64 ] - Configuration model ‘myopenhab.persist’ can not be found
16:20:22.188 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:118 ] - config is null
16:20:22.189 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:176 ] - UUID file found at ‘/usr/share/openhab/webapps/static/uuid’ with content '86f6d651-efed-429c-95fb-08fb6853838c’
16:20:22.200 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:228 ] - Secret file already exists at ‘/usr/share/openhab/webapps/static/secret’ with content 'iVlLk7IyEQIPEGdMAeuJ’
16:20:22.200 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:120 ] - UUID = 86f6d651-efed-429c-95fb-08fb6853838c, secret = iVlLk7IyEQIPEGdMAeuJ
16:20:22.221 [DEBUG] [.m.internal.MqttitudeActivator:33 ] - Mqttitude binding has been started.
16:20:22.222 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:176 ] - UUID file found at ‘/usr/share/openhab/webapps/static/uuid’ with content '86f6d651-efed-429c-95fb-08fb6853838c’
16:20:22.222 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:228 ] - Secret file already exists at ‘/usr/share/openhab/webapps/static/secret’ with content 'iVlLk7IyEQIPEGdMAeuJ’
16:20:22.223 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:162 ] - Version file found at ‘/usr/share/openhab/webapps/static/version’ with content '1.8.2’
16:20:22.249 [DEBUG] [.b.m.internal.MqttitudeBinding:84 ] - Activating Mqttitude binding
16:20:22.261 [DEBUG] [.myopenhab.internal.MyOHClient:138 ] - Manager.EVENT_TRANSPORT
16:20:22.272 [DEBUG] [sqlPersistenceServiceActivator:32 ] - mySQL persistence bundle has been started.
16:20:22.283 [DEBUG] [.p.m.i.MysqlPersistenceService:475 ] - mySQL: Attempting to connect to database jdbc:mysql://localhost:3306/openhab
16:20:22.665 [DEBUG] [.myopenhab.internal.MyOHClient:143 ] - Transport.EVENT_REQUEST_HEADERS
16:20:22.907 [DEBUG] [.p.m.i.MysqlPersistenceService:478 ] - mySQL: Connected to database jdbc:mysql://localhost:3306/openhab
16:20:22.919 [DEBUG] [.p.m.i.MysqlPersistenceService:184 ] - mySQL configuration complete.
16:20:22.926 [DEBUG] [.p.internal.PersistenceManager:146 ] - Initializing mysql persistence service.
16:20:22.928 [DEBUG] [c.internal.ModelRepositoryImpl:64 ] - Configuration model ‘mysql.persist’ can not be found
16:20:22.941 [DEBUG] [.zwave.internal.ZWaveActivator:36 ] - Z-Wave binding has been started.
16:20:23.608 [DEBUG] [.myopenhab.internal.MyOHClient:138 ] - Manager.EVENT_TRANSPORT
16:20:23.611 [DEBUG] [.myopenhab.internal.MyOHClient:143 ] - Transport.EVENT_REQUEST_HEADERS
16:20:23.672 [DEBUG] [.myopenhab.internal.MyOHClient:143 ] - Transport.EVENT_REQUEST_HEADERS
16:20:27.577 [DEBUG] [.myopenhab.internal.MyOHClient:157 ] - Socket.IO connected
16:20:27.578 [INFO ] [.myopenhab.internal.MyOHClient:224 ] - Connected to my.openHAB service (UUID = 86f6d651-efed-429c-95fb-08fb6853838c, local base URL = http://localhost:8080)
16:20:27.591 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'home.sitemap’
16:20:27.819 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'new.sitemap’
16:20:27.872 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'mysql.persist’
16:20:27.939 [DEBUG] [.p.internal.PersistenceManager:428 ] - Scheduled strategy mysql.everyHour with cron expression 0 0 * * * ?
16:20:27.988 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'home.rules’
16:20:28.092 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'home.items’
16:20:28.113 [DEBUG] [i.internal.GenericItemProvider:154 ] - Processing binding configs for items from model 'home.items’
16:20:28.179 [DEBUG] [.b.m.internal.MqttitudeBinding:177 ] - Registering Mqttitude consumer for owntracks/jf/iPhone/event (on mqbroker)
16:20:28.180 [DEBUG] [o.i.t.m.i.MqttBrokerConnection:476 ] - Starting message consumer for broker ‘mqbroker’ on topic 'owntracks/jf/iPhone/event’
16:20:28.226 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'home.items’
16:20:28.232 [DEBUG] [.p.m.i.MysqlPersistenceService:565 ] - mySQL query: item is JF_Home_Away
16:20:28.232 [DEBUG] [.p.m.i.MysqlPersistenceService:625 ] - mySQL: query:SELECT Time, Value FROM Item1 ORDER BY Time DESC LIMIT 0,1
16:20:28.248 [DEBUG] [.p.m.i.MysqlPersistenceService:665 ] - mySQL: query returned 1 rows in 16ms
16:20:28.249 [DEBUG] [.p.internal.PersistenceManager:377 ] - Restored item state from ‘26-Mar-2016 4:00:00 PM’ for item ‘JF_Home_Away’ -> ‘ON’
