I am currently running OpenHAB 2.5.2 in a docker container. Had it running like this without an issue for the laste 50+ days. Now I wanted to make changes to the config and that’s when I ran into my issue.
If I remove/ add anything in the config files, those changes won’t be applied.
Example: I removed a couple of lines in my .sitemap, but those lines I just removed are still visible in the sitemap across all devices. Same goes with adding lines to the sitemap, but the changes are nowhere to be seen.
What I tried so far:
Updating container
Checking Read/Write permissions
Restarting container
Deleting tmp and cache directory of openhab
Please keep in mind the config files have been migrated from an bear metal install to a docker instance.
You have folders /openhab/addons, openhab/conf, and /openhab/userdata created on your machine and owned my user ID 111. Correct? I would also be sure the /openhab folder is owned by that user too, and all the files too
sudo chown -R 111:113 /openhab should make sure. At least I think you can use UID & GID with chown…
The issue still persists. Weird enough, like I said before, the config inside the container shows the changes, but those changes are not reflected in the sitemap or paperui
