I just upgraded (apt-get) from 1.8.0 to 1.8.1 and there are no logs (openhab.log nor events.log) being written anymore. Openhab is working though…
Any ideas?
Any ideas?
Anything unexpected about the ownership and permissions of /var/log/openhab, the existing files there, or parent directories? Does the user that’s running the openHAB server have needed permissions/ownership?
Everything normal, openhab user owns them with all privileges and same user runs openhab.
I didn’t have logging problems specifically but was having what I think were permissions problems On Raspbery Pi.
I finally rebuilt from scratch and things are good now.
I should have rebuilt right away which only took a couple of hours versus the 10 hours or so trying to fix the old install.
I know that doesn’t help at all with your current installation.
I guess I’ll end up having to do that too
SOLVED, I edited /etc/init.d/openhab and removed --background , restarted openhab, re-edited the file including --background again and logging is back to normal. Weird stuff
I thought it was solved but it turns out that only when DEBUG=yes in /etc/default/openhab do I get logs to be written…
Just adding a me too on this. Logging appeared to be working but now its stopped and I can’t see why its failed. followed the suggestions from federic0 but no joy. Might just do a reinstall as I’ve only just started playing. I’ll update if I figure anything out
